Page 1 of 2 12 LastLast
Results 1 to 100 of 116
Thread: Ztherapy excitement
  1. #1
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default Ztherapy excitement
    Well I am over the top excited to be getting a set of 4 screw SU's done by Ztherapy! I kept my current set of carbs on the car as to have a good set to baseline all my readings, then I can get the new SU's on start tuning.
    I know the quality of the products put out by ZT, I am looking forward to getting them on, but any advice and things I should do first. Also any helpful advice on pitfalls in removing the intake?
    Thanks!
    Signed one excited Z car owner.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  2. #2
    Registered User 260zCaliCar's Avatar
    Member ID
    CZCC-18081
    Join Date
    Oct 2008
    Location
    Agoura Hills (Los Angeles Area)
    Age
    59
    Posts
    180
    Default
    I'll be interested in hearing other peoples tips and tricks for this also, I have a set of carbs/intake manifold out getting polished and look forward to putting them on. It look really straight forward unless a stud breaks...
  3. #3
    Registered User MikeW's Avatar
    Member ID
    CZCC-3294
    Join Date
    Dec 2002
    Location
    Atlanta, GA, USA
    Posts
    2,739
    Default
    Quote Originally Posted by Zedyone_kenobi View Post
    You're planning on removing the entire intake manifold and not just the carbs?
    -Mike
    Add your Z to my online spreadsheet registry
  4. #4
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    yup, I sent the intake and balance tube off to be polished and smoothed as well. THe whole kit and kaboodle is getting the treatment.
  5. #5
    Registered User 70 Cam Guy's Avatar
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    If the manifold is already off, you've already been through the toughest IMO. The exhaust bolts, and intake/exhaust studs are the main things I was worried about. I let the penetrating oil soak in a while before I tried cracking anything loose. I bought the stud kit from MSA. Studs for the intake manifold made installation much easier.
    My '73 had coolant through the manifold so I used a 1/2" pipe plug in the thermostat housing and a plug on the T before the cooling line is routed behind the head (passenger side)
    I don't know if this made a difference but I didn't tighten the balance tube completely when I re installed the manifold. My thinking was that the manifolds would install flat against the head
    -Andy
    1973 HLS30-166105
    RB20DET swap, HKS GT2530 turbo, HKS Actuator, Hallman MBC, ebay intake manifold, ebay dump pipe, straight pipe, 14 psi boost
  6. #6
    Registered User
    Member ID
    CZCC-5121
    Join Date
    Oct 2003
    Location
    Seattle, WA
    Posts
    2,362
    Default
    My main suggestion is do not use a "header" gasket. The paper ones suck. Use a Nissan or other foil and graphite manifold gasket.
    For the other guy, use a long extension with a U-joint and socket. You'll have to get in some fairly uncomfortable positions and there will likely be a little pain along with stuffing your hands in tight spaces. It's not that big a deal though.
    Jon
  7. #7
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Hi Jon, have you had bad experience with the MSA intake/exhaust gasket? If I understand you, you're referring to a paper style like you might see from Mr Gasket
    just as a quick side note, I finally bought my Energy poly bushings so everything is in place to do the coil overs... just need time. I'll send you a picture when I do finally install everything.
    As far as the u-joint and socket, I agree. I believe it was the 2nd or 3rd cylinder that has a stud that is impossible to reach with a normal socket. It was even a pain with a shallow universal. Getting the stock manifold unstuck from the head took some convincing with a pry bar. Just take your time.
    -Andy
    1973 HLS30-166105
  8. #8
    Registered User
    Member ID
    CZCC-5121
    Join Date
    Oct 2003
    Location
    Seattle, WA
    Posts
    2,362
    Default
    If you're referring to the POS gasket that comes with their 6-1 header, yes I had problems with it. I actually bought the header from Arizona Z Car, but it's the same header, and yeah, I drove the car once and it cracked. Never had any trouble with a graphite gasket.
    Jon
  9. #9
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Where would one source this uber Graphite gasket. I know the exact ones your talking about. Would Felpro make one.
  10. #10
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    I've had good luck with the three-piece Hooker gasket set. They aren't paper, but are more normal laminated gaskets. Only for square port heads.
    http://www.summitracing.com/parts/HOK-10852HKR/
    Info from Hooker's site:
    This OEM quality gasket is constructed of a thick (.070") laminated, graphite impregnated substrate. The substrate combined with a perforated aluminum core provides superior grip and adhesion.
    http://www.holley.com/10852HKR.asp
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  11. #11
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Quote Originally Posted by jmortensen View Post
    I should have taken a picture of mine. The msa gaskets I used on my car were not a simple paper gasket, more like a sandwhich of paper and foil in the middle. I doubled them up, gluing them together with copper RTV, then glued the header to the gasket. Got everything mounted, then snug, then I torqued in stages. I let the rtv dry a good half hour before doing the last torquing.
    My header leak is fixed, with the header simply resting on the studs, the 2nd primary was too low to seal so with a little tweaking of that primary and keeping the header lifted, everything sealed. Keep in mind this is a who-knows-how-old Clifford header and one of the previous owners cut the flange between the primaries.
    Arne, great link!
    -Andy
    1973 HLS30-166105
  12. #12
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Carbs shipped today. Looking forward to this VERY much.
  13. #13
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Tuscaloosa/Winfield, AL
    Age
    31
    Posts
    221
    Default
    I know the feeling. I got my ZTherapy carbs about 2 months ago, and it's been perfect ever since. Hope you'll be as happy with yours as I am with mine.
  14. #14
    Registered User mlc240z's Avatar
    Member ID
    CZCC-7517
    Join Date
    Dec 2004
    Location
    Central NJ
    Posts
    779
    Default
    Just get ready to spend a lot of time freshening up everything under the hood.
    the ZT carbs look SOOOO damn good, it'll make everything else look shabby by comparison.
    big difference in idle and smoothness of engine, and my original carbs ran pretty well.
    probably some of the best money i've spent on the Z
    Bart
    5/71 240z, HLS30-31306, mostly stock, ZTherapy SU's, Pertronix, Eibach ProKit, KYB, Poly bushings, 60 amp alternator w/Dave's plug bypass, headlight and parking light harness upgrades.
  15. #15
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    All music to my ears. I was thinking I would send a large order of parts to be powercoated and cad plated, while I am there.
  16. #16
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    SU's are in! My Gosh they are beautiful... cannot wait to watch the SU's video and put them on.
  17. #17
    Member ID
    CZCC-3294
    Join Date
    Dec 2002
    Location
    Atlanta, GA, USA
    Posts
    2,739
    Default
    That was quick. I didn't realize they could do them that fast. I'll be sending mine off at some point. In the past I've resisted because I didn't want the car not drivable for a period of time but the sad reality is that I just haven't driven it in months anyhow.
    -Mike
  18. #18
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    I had a spare intake and carbs I used as a core. My current carbs which work pretty good are still on the car. I will take some vacuum readings and use my uni-syn on it before I remove them to see what difference these carbs make. Also, would like to know how off sync my current set of carbs are. Actually, I think they are pretty good. But to have a working baseline is always good to have.
  19. #19
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Looks familiar!
    Make sure before you install them that the small little fuel delivery hoses at the bottom of the carbs aren't kinked. One of mine must have gotten budged during shipping, so I had to take the clamp off and reposition it. The video and paperwork tells you all of this though.
  20. #20
    DMC-Z DMC-Z's Avatar
    Member ID
    CZCC-14351
    Join Date
    Apr 2007
    Location
    Denver, Colorado
    Age
    45
    Posts
    37
    Default
    WOW! Looks awesome. Is that the shack-daddy $630 + Core treatment listed on the price list? It looks amazing!
    1970 Datsun 240Z HLS30-05389; 6/70 Build Date
  21. #21
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    yup, it is the 630 dollar core, plus the intake and balance tube polishing. I also picked up a new PVC valve and PVC hose to the crankcase. OH and got a unisyn while I was at it. Cannot wait to get the PB blaster on the bolts and get that intake/exhaust off.
  22. #22
    Member ID
    CZCC-18081
    Join Date
    Oct 2008
    Location
    Age
    59
    Posts
    180
    Default
    Is that what a polished intake manifold and balance tube are supposed to look like? Huh, I've been polishing mine and they're sort of looking like the attached, wonder what I'm doing wrong?? Honestly, your new carbs look amazing. I've been seriously considering sending my polished stuff off to Bruce for final assembly and tuning. I'm sure he will do a much better job then I ever could... I look forward to hearing about how your final installation turns out.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	polished carbs.jpg
ID:	32068   Click image for larger version.
  23. #23
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Yours are definitely more polished than mine buddy! Great job. I would highly recommend clear coating those to prevent tarnish after your done. So much work should be protected.
    I think the word polish in Z therapy speak is more of a tumble - polish - clean. I think you have taken it to the extreme...I am sure Bruce has experimented with the best polish he can offer to his clients and still make money. Obviously he could not do what your doing to yours and charge so little.
    Keep it up!!
  24. #24
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Just to freshen up this topic, our carb pieces are run through a high impact machine polish which is designed to close up the cell structure of the aluminum replicating the finish when new. It is not our intention to change the look of the product by doing a chrome polish. We'll leave chrome polish to the owners.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  25. #25
    Member ID
    CZCC-18081
    Join Date
    Oct 2008
    Location
    Age
    59
    Posts
    180
    Default
    Quote Originally Posted by Bruce Palmer View Post
    Hi Bruce, I think we all know that you don't aim for a chrome level polish (I was just kidding around). Your product is beautiful, and as you said, returns your clients to [as new or better than new]. Which is appropriate.
    Every time I see your work product, my first thought is "wow".
    Smoothing and polishing until you have no more fingerprints isn't nor should it be your goal. (and it will never be my goal again).
    As I mentioned earlier, if your willing, I'd like my set-up to end up in your expert hands to assemble (now that you have shipped me everything to do it, I'm hoping to ship it all back ).
  26. #26
    Registered User
    Member ID
    CZCC-18571
    Join Date
    Jan 2009
    Location
    Houston, Texas USA
    Posts
    85
    Talking Must be One Missing??
    Hey that looks really good - but they must have shorted you one man. Three is what you need I tell you .
    Like the 3 and manifold I have still setting in the box from when we looked at them. You rs will be on soon and a lot faster than mine - like all of your Z projects vs mine. Yep I am further behind !
    Congrats on those again - now get them on and lets go pull some ZX parts off !
  27. #27
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Quote Originally Posted by 260zCaliCar View Post
    Sometimes my responses may come off sounding too obvious but I find myself thinking in terms of "who may be reading this that may not be as up to speed on our services" as you the "learned" ones.
    Call me and we can work out the particulars. For enough money, etc etc etc
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  28. #28
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Quote Originally Posted by TexasRider260Z View Post
    Yeah, triples would have been sweet bud. But I am pretty sure I could not have pried them out of your hands with a 5 foot crow bar! haha. I like the ease of running the SU's, and I know I will never make more power than they can supply. Unlike you who plan to build a monster
  29. #29
    Registered User ta240's Avatar
    Member ID
    CZCC-6558
    Join Date
    May 2004
    Location
    N California
    Posts
    343
    Default
    the Z Therapy carbs were probably the best money I ever spent on my car
  30. #30
    Registered User
    Member ID
    CZCC-18571
    Join Date
    Jan 2009
    Location
    Houston, Texas USA
    Posts
    85
    Talking
    I am waiting for you to pull in the driveway over here and lets sit and talk a spell. It not raining that hard and all the moon bombs are over !
  31. #31
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Quote Originally Posted by ta240 View Post
    Agreed. I went from being afraid everytime I drove my car for fear of a breakdown to total confidence and enjoyment. Not to overstate things; but they are the single reason I started driving my car again.
  32. #32
    Registered User auzziez's Avatar
    Member ID
    CZCC-19216
    Join Date
    May 2009
    Location
    Florida
    Posts
    120
    Default
    I'm not familiar with the term 3-screw or 4-screw SU's. What does that mean, and how do I know what I have. I have 2 sets, one on my new '70 Z, and another from a '72 Z, on my parts car '73.
    Also, I'd be interested to know if you guys prefer to run separate air cleaners on the carbs, or if the original cleaner housing (big orange cover) is used more often?
  33. #33
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Quote Originally Posted by auzziez View Post
    The 3 or 4 screw deal is merely the number of screws holding the dome on. Your 70 carbs are more than likely 4 screw and the 72 carbs are 3 screw. At least that's what they would have been from the factory.
    The factory air cleaner is a fine, very functional piece of gear. It has good air horns built in, both carbs draw from a common air cource and cooler supply air can be had through the "snorkle" from forward of the engine heat.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  34. #34
    Registered User Weasel73240Z's Avatar
    Member ID
    CZCC-14988
    Join Date
    Sep 2007
    Location
    Taunton, Massachusetts
    Age
    51
    Posts
    483
    Default
    3- or 4-screw refers to the number of screws holding the domes in place.
    Whatever air cleaner you run, you should use the air horns that the original air cleaner came with. I'm gonna fabricate a new intake, using a K & N cone filter and aluminum tubing to an aluminum air cleaner I'm making this Winter. I'm cutting the air horns out of my OEM air cleaner to incorporate into the new design. The air horns "smooth out" the flow of air into the carbs. Better air flow = more power.
    Wow, my 420th post. Happy 420 everyone!
    Paul Martin
    1973 240Z HLS30-127623 (10/72)
    4.11 R-180, 79 ZX 5-speed, ZX Distributor, ZTherapy SU's
  35. #35
    Member ID
    CZCC-19216
    Join Date
    May 2009
    Location
    Florida
    Posts
    120
    Default
    Thanks for that info. The '70 does have the 4 screw carbs and the '72 carbs are 3 screw carbs.
    And, I didn't even realize it until I just went out and looked, the parts car doesn't have the air horn cover. Basically, the previous owner took the cover off, but left the backing plate on, and then the OEM air filter is there, covered by a piece of flat aluminium in the same shape as the air filter. Not sure why that is...oh well.
  36. #36
    Registered User
    Member ID
    CZCC-18571
    Join Date
    Jan 2009
    Location
    Houston, Texas USA
    Posts
    85
    Default
    The OP Z1K must be at work out in the garage on this install as I have not seen him, the car, or any post showing its up and in as yet.
  37. #37
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    nope, I have been busy tracking down a rubbing brake drum and a getting a new set of tires.
    Now on to the carbs!
  38. #38
    JDM esprist's Avatar
    Member ID
    CZCC-16910
    Join Date
    May 2008
    Location
    Southern, CA
    Posts
    537
    Default Z therapy Carbs
    You have done my 4 screw carbs as well as my friend's 3 screw carbs. They are excellent! As matter of fact, it is way better than factory ones. I have rebuilt so many of them, but none of them turn out as good as yours. Especially your throttle shaft with roller bearings. My car idles smooth like an injected car.
    I strongly recommend your SU set up to everyone!
    Thanks a bunch!
    Esprist
  39. #39
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE: Today I got a baseline reading on my currently installed factory carbs. There is no telling how many times these have been messed with, but I slapped my new edlebrock sync tool I got from Bruce on there at idle with the engine warm and the carbs are FAR from balanced. ONe shot the red cup up to almost the 4th line. The back carb only managed to barely move it to the first. Since I am going to take these off, and they do run what I thought was well. I am looking forward VERY much to seeing how well she will run with a balanced set of carbs on there.
    PS. I adjusted the fast idle screw up to 3000 rpm per the SU video and the readings were far more even. But the front carb was still reading higher. I think I may have a vacuum leak in the back carb somewhere. Still all bolts are currently sitting in penetrating fluid, so the removal will start soon. My new intake/exhaust studs have arrived, as have my new air cleaner decals, filter, and my orange paint is on order. I have my new MSA intake/exhaust gasket waiting installation.
    Fun times ahead.
    Just if your curious. I adjusted the mixture nut on the bottom of the carb on the rear carb to see if I could get it to come in to match the front, and it had no effect. I think I recall that is how you adjust them at idle. I will have to watch the SU video again. Its wonderful by the way!
  40. #40
    Registered User zmadnez's Avatar
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Zedyone_kenobi, I am just a few steps ahead of you in the overhaul of the intake and exhaust with ZT carbs. The final upgrade will be replacing the intake with a polished intake, with ZT Euro Tube and replace the stock manifold with Jim Cook 3 to 2 headers. I am still debating if I should cap off the water/coolant line running through the intake manifold. Here in So Cal, we don't get the bone chilling weather that warrants the intake to be pre-warmed by the coolant going through the manifold.
    Today it was a dismantling day. The PB-Blaster week of soaking on those rusted bolts really did the job in loosening up the bolts = "no broken bolts". Easily and gently unscrewed the bolts from the heads and they all came off without a hitch. Installed the new intake/exhaust bolt & nut kit from MSA with plenty of the high-temp anti-seize stuff. Also removed, along with all those twisted smog air hoses, is the boat anchor of an air pump and bracket. Taking the smog pump and bracket took more effort then removing the intake and exhaust due to the tight spaces and the zillions of air tubes cluttering the back of the pump. I ran out of time to undo the rusted 2.5 inch pipes and muffler, it'll be next weekend's job along with installing the headers, intake manifold (assuming it will be delivered before the weekend). More adventure to come.
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  41. #41
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Good Luck on it! I was fortunate as somebody has already beaten me to removing the smog pump. I already have a header, so it sounds like they saved me a ton of work! I think what I may do is try do a photo documentary on this. It will give step by step directions to future Z a holics. Plus as a bonus, it will allow me to track my progress so I can get back to where I was if I forget where something went.
  42. #42
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    One of my concern in replacing the stock iron exhaust manifold with a uninsulated header is the increase of heat that may effect the carburation. Did you encounter any issue with excessive heat on your setup, assuming your header is not insulated?
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  43. #43
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Quote Originally Posted by zmadnez View Post
    I'm sure you already know this, but a heat shield could be fabricated really easily. A ceramic coated header with a heat shield would be the best combinaton; probably cooler than the factory setup.
  44. #44
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    My header was Jet Hot coated, not sure how long ago, and I run the factory heat shield. I am going to send the heat shield off to be powercoated with a high temp coating. I was even thinking of doing a reflective barrier on the back of the heat shield, Think McLaren F1 supercar. Of course I would not use 24 karat gold, but I could find something that has good insulating properties.
  45. #45
    Still plays with cars kenz240z's Avatar
    Member ID
    CZCC-6323
    Join Date
    Apr 2004
    Location
    Berthoud, CO
    Age
    52
    Posts
    738
    Default
    Hi Steve, I've had an MSA 6-2 header in my '73 for about 3 years now. It is not coated with anything and not wrapped with anything. I've never had an issue with too much heat under the hood. I've got round top SU's and the stock heat shield.
    Kenny P.
    '73 240Z
    '82 ZX L28
    '82 ZX 5-speed
    Round top SU's
    Tokico HP struts
    Tokico Springs
    Urethane bushings
    my gallery
  46. #46
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE: Due to the amazing great weather we had yesterday I spent the morning removing my intake to prepare for the installation. Everything went very straight forward for the most part. I spilled more coolant that I would have liked, but that was only a 10 minute diversion. THe hardest part of this by far was removal of the studs. Two gave me grief, the others came out rather nicely with using the old two nut method. I also soaked most of them with liquid wrench the day before, which may or may not have helped. I think having a header instead of a stock exhaust manifold gave me more clearance to work as well. ON to the pics...
    First pic is my box that I used to keep track of my studs and where they came from. I usually use a piece of cardboard as it is nice to make notes on as you go.
    THe next pic recalls something that was said earlier on this post. Gasket differences. The lower gasket is the one off the car. Obviously not a stock one. Notice the metal contact surfaces for the header to rest against. This is like the ultra high quality gaskets I use to use when I rebuild V8's. Above is the meager-by-comparison MSA gasket. I think I want to find another gasket like the one below.
    Here is the engine so far. All the studs removed, no casualties yet. I have been using scotch bright to clean up the surface of the header and head. It feels very smooth, and I think will seal quite well.
    Here is the old intake and carbs. You can also see the new intake/exhaust stud kit ready to go back in...
    THats all for now. ONe question though. I have read some posts on other car forums that its horrible to use antisieze on studs/bolts/spark plugs for aluminum heads. This goes against everything I have ever done. Does anybody have any more insight to this. MY dad is a retired A&P mechanic, and says they use antisieze on aluminum heads all the time.
    MOre updates to follow. I have to start sanding my heat shield for refinishing.
  47. #47
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Looks familiar!
    Wherever you read that info.......if it was the general consensus of the participants...........stay FAR FAR away from that forum.
  48. #48
    Registered User
    Member ID
    CZCC-20370
    Join Date
    Nov 2009
    Location
    Maryland
    Posts
    10
    Default
    I'm excited too! Just ordered the $630 dollar treatment from Bruce at Ztherapy yesterday, plus smooth and polish the intake and balance tube. I actually spent the extra money to have the european style balance tube. I've been working on my 240 for over a year now and am very close to being able to drive it. Bruce said about ten days for him to get the stuff ready and another 3 to 5 days for shipping, I can hardly wait. I'll post pics of the Euro balance tube when I get it
  49. #49
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    I have always used anti sieze. If anything, I've heard it's more important to use on aluminum for dissimilar metals (ie spark plugs in the head, steel studs in the head, etc). Aluminum on aluminum can gall/tear as well (like stainless).
    I pulled the lugs off my Civic to rotate the tires, and the studs had a dab of anti sieze on the threads. Good stuff
    -Andy
    1973 HLS30-166105
  50. #50
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Thanks for the info Kenny! I may just keep the header uncoated and unwrapped.
    Zedyone_kenobi, I noticed that your header has the plug screwed into where the air galley tube connects to. Did you have to use a sealer to prevent exhaust leaks or the plug coming undone?
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  51. #51
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    I wish I could tell you. The header was like that when I bought the car. I am thinking of sending it off to get redone. It is looking a bit worse for wear.
  52. #52
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Heres what my set-up looks like before it has been run. Those pretty carbs would look great next to a ceramic(shiny header). Be advised, I was told by a friend and verified thru research that you don't want to dial in new carbs with a freshly coated ceramic header. A bad fuel mixture will dull the finish of the ceramic and never come back. I wish I could get some Z therapy carbs, but my carbs are almost new-plus I got some mikunis for after break in.
    Good luck with your carbs!
Name:	z pics 044.jpg
ID:	32662   Click image for larger version.
Name:	z pics 045.jpg
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  53. #53
    Member ID
    CZCC-7517
    Join Date
    Dec 2004
    Location
    Central NJ
    Posts
    779
    Default
    now that is VERY NICE!
    Well Done
    Bart
  54. #54
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    These are the essentially unchanged directions since I had the Sanderson's on my Camaro. It's true, the finish will dull and the coating cracked on my headers. It has more to do with a Mallory distributor with a bad advance curve. High egt's from too much advance really damaged the coating on my headers.
    http://www.sandersonheaders.com/tech...stallation.php
    They have a quick section on new engines and fresh rebuilds. It also says to be careful after performance mods so a drastic enough change can affect exhaust temps
    I did an afternoon restore on my Clifford headers using high temp VHT black header paint. I prepped with naval jelly and a good cleaning (the paint is self priming). I have actually been pleasantly surprised by how durable the finish is. I've had a couple clumsy moments with my wrenches and the paint didn't chip
    -Andy
    1973 HLS30-166105
  55. #55
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    Okay, I got a small case of the while I was at its, and took off the thermostat hosing and the upper radiator hose. I ordered all new seals and hoses, since, you know, I was there. Now here was an adventure. The bolt was so corroded into the thermostat housing the head snapped right off. OH JOY!
    Three hours later and some delicate tapping with a rubber mallet I got the housing to loosen it's death grip on the sheared bolt. Now with only 1/4" of bolt sticking out of the head, I had to say my prayers to the good Lord above, said a few to Budda and Allah, just in case they were car nuts too, never hurts to be thorough, and clamped a vice grip to the last remaining threads to see if the bolt would unscrew.
    You know many things go through your mind when you attempt something like this. You have this feeling like you know there is a smarter way to do this, but at this point your caveman instincts from the Pre Cambrian period surface and you just want to pick up the car and throw it.
    Long story not so long, the bolt nicely unscrewed. Thank the Lord. OR Allah, Or Budda, hell I even thanked my wife.
    Kept cleaning things up, put some new paint on the thermostat housing and the heat shield, and started to do some final thread cleaning on the heads.
    One question folks. I asked Ztherapy to block of the water passages from the intake. So the water line that does form the thermostat housing to the intake, I assume I can just plug. Also, I should be able to remove the line running around the back of the engine as well. Is this correct. From the looks of it, the coolant does not need this flow path to function correctly.
    Any thoughts.
    I have to go see if Black Dragon or MSA sells bolts for the Thermostat housing now.
    I love working on my car.
  56. #56
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Actually, that appears to be a common problem. I had the exact same thing happen when I changed the thermostat on my car. What happens is that the shaft of the bolt corrodes and swells in the t-stat housing, so much so that the bolt won't turn and the head breaks off. Once you persuade the housing to give up its death grip on the corroded bolt, my experience has also been that the broken bolts unthread easily. In my case, I had a brand new t-stat housing waiting on the shelf, so I wasn't worried about destroying the one that was stuck.
    Short version - new t-stat housings are still available new from Nissan, and are actually rather affordable. I'd recommend having one on hand before attempting to remove a long-attached one.
    Oh yeah, ALWAYS thank your wife. It's a good habit to get into.
    Correct. Plug it at the t-stat housing, remove the pipe going around the rear of the engine, and cap off the supply to that pipe at the T-fitting on the side of the block.
  57. #57
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Quote Originally Posted by Arne View Post
    This is exactly how I did mine, as well.
    Here are a few pics that might help you.
    Heater hose coolant paths.
    Plugged t-stat housing. I forgot what exact plug this was, but I'm pretty sure it was a normal pipe thread (NPT) threaded plug.
    You'll need a 3/4" to 5/8" heater hose adapter (splice) to neck down from the larger hose coming from the lower radiator hose outlet assembly to the smaller hose needed at the heater core inlet. All parts stores should have these in stock.
    I chose to throw the heater hose T away, along with the metal line assembly and thermostat that snaked around the back of the head.
  58. #58
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    I used a 1/2" pipe plug in the thermostat housing IIRC. It's an allen head plug (socket head plug?) so it sits flush in the housing. I capped the heater T on the passenger side and completely removed the tubing routed behind the head. It's much cleaner without all the extra cooling lines.
    That's good information about the thermostat housing, I'll keep that in mind if/when I need to change the t-stat
    -Andy
    1973 HLS30-166105
  59. #59
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    THat confirms what I thought. Good info. I was going to order a new T-stat housing Arne, but thought I could save this one with a wire wheel and lots of scrubbing. So far so good. I am prepping it for paint right now. I still need to clean the holes. I am guessing I should liberally coat the next bolt with some copper grease or antisieze before installation. Something to prevent corrosion! YUCK.
  60. #60
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Today my orange paint from Classic Datsun showed up, as well as my new tensioner pulley for the AC. All I have left to do is clean out the threads, and I should be able to start putting things back together!
    Just need some thermostat housing bolts that go into the head. Must be metric bolt store around clear lake somewhere!
  61. #61
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    The Ace hardware here in town has a good selection of metric fasteners now. It allowed me to mount my ducted spook with metric bolts. If they are nearby it might be worth a look. I'm not sure on the length since I've never removed the factor thermostat housing bolts
    -Andy
    1973 HLS30-166105
  62. #62
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Just curious to see how many of you installed the ZTherapy carbs, strait out of the box, and got it running without tweeking the settings? I know that every application is different and requires some adjustments after installation but just wondering if the car fired up without any adjustments.
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  63. #63
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Mine did. Of course, you can double check the settings on the carbs within a minute by reading the instructions that come with them, and it will fire right up.
  64. #64
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    While I didn't need the ztherapy treatment, a good pair of carbs will fire right away (once the bowls have fuel). I would verify base settings but base settings should get you going. Synching will be needed on any new set of carbs.
    After fighting a pair of leaky carbs, a nicely sealed set is so nice. Air leaks around the throttle shafts will have you pulling out your hair guaranteed.
    -Andy
    1973 HLS30-166105
  65. #65
    Member ID
    CZCC-14988
    Join Date
    Sep 2007
    Location
    Age
    51
    Posts
    483
    Default
    Bolted my new ZTherapy's up, and it started right up (once I got a timing issue straightened out). One quick adjustment with the Uni-sys for high rpm balance, and they've been set ever since.
    Paul Martin
  66. #66
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    YOu guys are making me VERY happy! I am about to start bolting parts back up. I am holding off for two reasons. I am thinking that I may want to get some parts cad plated. I have a small pile of connectors and bolts and nuts. I cleaned them up with a wire wheel and Dremel, and they look clean and new, but would look better with a shiny CAD plate.
    I also nearly finished up my air cleaner resto yesterday. I have a few runs I need to work out with some 2000 grit and polish off. I think I am going to clear coat the thing when I am done to protect the new stickers I got for her.
    All I am waiting on now is gaskets for my Thermostat housing and I am off to the races!
    Should be fun. I think I will go ahead and flush the rad while I am here and replace all the hoses. I have to plug up the intake water path anyway.
  67. #67
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Okay, today was a great day. I got the header back on as well as the new carbs. They look very purrrrdy. refinished my thermostat housing and cover and got those in. Found some spiffy cad covered grade 8 bolts to install there.
    On note of warning. Put the washer and nut loosely on the lower studs for the intake first. Trying to fish those lower nuts on with the header and intake on was a bit of a pain. Apparently I have bear claw hands, and they would not reach very easily. But after many trys and finally MacGeyvering with a wrench and some tape, I got them on. Tomorrow I have to torque all the bolts and then I can start installing my new fuel lines and reroute my coolant lines to take into consideration the lack of intake water passages. MOre to come.
  68. #68
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Sounds good! Hopefully, you won't need it, but good luck!
  69. #69
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    All parts are on the car. I did not get around to finally torquing the bolts. There is no way I will be able to get a torque wrench on the bolts below the intake, so I will have to use the force.
    This is shaping up well. I still have some cleaning to do on the block and run new fuel lines. Still have not figured out how I want to rerun the coolant lines. MOre on that after Turkey day I guess.
  70. #70
    Member ID
    CZCC-14988
    Join Date
    Sep 2007
    Location
    Age
    51
    Posts
    483
    Default
    Since you're in Houston, I wouldn't bother with re-attaching the coolant lines. The lines are really to improve warm-up, not cooling, and I assume warming up in Houston is no problem. It just looks so much cleaner without them.
    My 2....
    Paul Martin
  71. #71
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Thats the plan...just need to find the cleanest way to do that.
    Latest issue is the upper and lower radiator hoses. My factory radiator was upgraded from a two core to a three core. While this is great and all, the outlet and inlet to the radiator seems to be larger than the stock 240Z radiator. I ordered an upper and lower radiator hose from Black DRagon and the part that attaches to the engine is perfect, but the part that had to go onto the radiator was a ultra tight fit. I think its far too tight. I need to find a larger diameter tube hose, with the same bend.
    The search is on!
  72. #72
    Administrator bpilati's Avatar
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    60
    Posts
    1,483
    Default
    I've heard that ZT has some kind of performance enhancement that they can do on your SU's for extra $$. Does anyone know about this, or has had it done? Interested in understanding the difference between that and a normal overhaul.
    Bryan Pilati
    1971 Datsun 240Z (8/71; 920 paint)
    IZCC #583; TZCC #16; CZC #110
    I'm never serious unless I should be.
  73. #73
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    They do put in different needles that run more rich. I am not sure that it is part of the basic Ztherapy SS treatment, but I requested them.
    I get the impression that the performance in the SU's is mostly due to the correct needle selection and the weight of the oil in the piston. You can control how fast it rises and how much fuel comes out. Until you reach the max CFM the SU's can flow with the pistons fully up, I think you can tune to just about any reasonable performance level.
  74. #74
    Furthur GreenZZZ's Avatar
    Member ID
    CZCC-14083
    Join Date
    Mar 2007
    Location
    Austin, TX
    Age
    55
    Posts
    608
    Default
    Quote Originally Posted by 70 Cam Guy View Post
    I went out and measured the threads and on my '72 it is definitely a 1/4" British Std Tapered Pipe Thread so you would want a 1/4" BSP plug, yes? Outer diameter of a 1/4" BSP is just over 1/2". Main thing is not to use a 1/4" NPT plug which has a different thread per inch count.
  75. #75
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Quote Originally Posted by GreenZZZ View Post
    On my '73 I am pretty certain my thermostat housing is 1/2" pipe (or similar, and definitely way to big to be 1/4 NPT). Reason being I removed a pipe plug from a junk LT1 water pump and it threaded into my housing by hand until taper prevented further tightening. I went "sweet!", wrapped the plug with teflon tape, restarted the plug by hand, and tightened.
    In my experience, a different TPI would not allow for tightening by hand or anything else. It's been installed and sealed since I did the header in early September. Maybe something subtle changed in 73? I really don't know, I'm feeling like I got away with a ghetto fix
    Thinking a little more, did the 72's have EGR? The water lines on the 73 go to both the EGR and intake manifold. Maybe they changed to 1/2 NPT to allow for more volume/flow
    -Andy
    1973 HLS30-166105
  76. #76
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    UPDATE:
    The couple hard-to-get-to nuts I had to use a 1/4 drive universal on an extension. Obviously not ideal with a torque wrench but it was the only way to truly control how tight the nuts were. I actually used an inch-pound torque wrench that was 1/4 drive. I understand not everyone has access to an inch-pound torque wrench but it was much easier than a larger torque wrench
    I can understand you had to put the carbs on to see how they look but it will be much easier to torque everything with those removed.
    btw, looking great
    -Andy
    1973 HLS30-166105
  77. #77
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    I agree. Mine is definitely NPT, and I'm pretty sure it is 1/2".
  78. #78
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    I bought several plugs yesterday. I know one fit very nicely, threaded in with no issues at all. I will see which one it was. I think it may have been NPT.
    As far as the carbs go. They were installed by Ztherapy on the manifold when it arrived. I just bolted it up. I may have to remove the carbs to get a good torque on the nuts. I think a 12mm crows foot would help dramatically as well.
  79. #79
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Quick note. It seems I made a bit of a mistake when putting my thermostat back on. The spark plug wire holder that bolts to the rear most bolt on the thermostat cover is made of plastic, and when I put it back on, I sort of snapped the plastic in half. Does anybody know who may have an extra?
  80. #80
    Member ID
    CZCC-14083
    Join Date
    Mar 2007
    Location
    Austin, TX
    Age
    55
    Posts
    608
    Default
    Looks like we have different housings!
    Looking further at the film, it would make sense to increase the ID of the plumbing to deal with the fact that downstream your Z is supplying the EGR and the Carb while mine is only doing the carb. Having a NPT thread is a real plus as you can install a standard 1/2" NPT thermostat switch for an electric fan.
    Lee - 2/72 240Z
    Thinking ahead is NO EXCUSE for thinking!
  81. #81
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Part 33, Nissan number 22472-E3000, still available from Nissan for around a buck and a half. Same price roughly from MSA. #12-4181.
Name:	Screen shot 2009-11-17 at 1.20.05 PM.jpg
    Attached Images Attached Images
  82. #82
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    You know for whatever reason, I was looking at the cooling part of the catalog since that is where its attached to the engine.
    Sometimes, I really have to think I am starting the road to senility early.
  83. #83
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Ordered my new wire holder today, and since its just plain silly to just order something for $1.53, I had to add a new european curved dizzy. I am hoping my current pertronix will bolt into the new dizzy.
    Yes, I am weak, and like new shiny OEM parts.
    But HEY, its Christmas soon, Merry Christmas to ME!!!
  84. #84
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    What's this distributor that you speak of?
  85. #85
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Quote Originally Posted by g9m3c View Post
    The non-emissions 240Z unit. The points dizzy factory installed on 240Zs where emissions controls were not needed. Could be used on a 280Z, but you'd need a 240Z dizzy support pedestal plus Pertronix or suchlike.
    http://www.thezstore.com/page/TZS/PROD/PEIC01/12-4040
    I believe the non-emissions dizzy uses the same points as the normal unit, so the Pertronix should fit fine.
  86. #86
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    We will find out Arne. I have always thought my advance mechanism may be a bit dirty. I will tear it down and clean it after I get the new one in. Should be plug and play for the most part. This will complete my tune up so to speak. After I get the carbs in and balanced, will swap out distributors. I only wanted to change one thing at a time. Carbs alone are a big change, and I expect great things from the Ztherapy units.
  87. #87
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    54
    Posts
    1,190
    Default
    Just so you guys know, it is possible to buy just the throttle bodies from Ztherapy. This means that you have to swap all the other parts off your existing carbs, but you'll have brand new throttle shafts, which are the parts that tend to wear out.
    I did this on my roadster, and it only ran around $270.00 (with exchange) instead of $630.00. The carbs on my new z appear pretty tight, (though not exactly clean), but I will absolutely use Z therapy againif I need carb work done.
  88. #88
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    Not much to report, wife has had me painting the dining room and den this weekend. I did manage to get the radiator empty and got my coolant hoses removed from the spark plug side of the engine. I need to come up with a way to reroute the coolant hose straight to the heater core, versus around the engine to the intake. I need to connect two lines with different diameters. Should not be too hard.
    In the mean time, I spent some time polishing my valve cover and refinishing my fuel line so it does not look so 'dirty' next to my purdy carbs. Engine is coming together nicely for now, just slowly.
  89. #89
    Member ID
    CZCC-14988
    Join Date
    Sep 2007
    Location
    Age
    51
    Posts
    483
    Default
    Here's mine, if this helps.
    I got a reducer at AutoZone (3/4" to 5/8", I think) for connecting the two different diameter hoses.
    Paul Martin
  90. #90
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Installed the carbs with the euro tube this weekend per the ZTherapy instruction and vid. and the idle is about 2k rpm. Adjusted the idle screw on the carbs to close the butterfly valve to lower the rpm and it didn't lower the rpm. I am thinking it could be a vacuum leak somewhere in the intake. If it is a vacuum leak, what's the best way to isolate the leak?
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  91. #91
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Age
    31
    Posts
    221
    Default
    Grab a can of brake cleaner, carb cleaner, or similar product from a parts store. Crank the car and let it idle while you slowly spray the product aroudn the intake, vacuum hoses, balance tube, or anything else that could possibly leak. When the idle raises, you've found your leak.
    I only suggest doing this if your intake and everything is bare metal still. No clue what brake cleaner would do to hot paint or other coatings.
  92. #92
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Also make sure your throttle return springs are in the correct spot. I swear I look but I have done it twice where I put the spring for the front carb on the idle-up arm.... not a good spot for it.
    Also make sure the linkage tie rod is not keeping your throttle open (balance tube to center linkage). Maybe pop off one of the ends and make sure.
    Aside from a good visual, the vacuum leaks are another good place to look. I have had good luck with carb clean. Everything is connected properly? Brake booster hose, balance tube tight, etc
    -Andy
    1973 HLS30-166105
  93. #93
    Registered User Lazeum's Avatar
    Member ID
    CZCC-15411
    Join Date
    Nov 2007
    Location
    Paris, France (prev. Troy, Mi)
    Posts
    302
    Default
    I would advice to try also to spot any leak with a fuel/heater hose: one end at your ear and the other to spot the leak. It is very easy to spot any unusual air variation.
    Nice thread also, can't wait to hear how good the Z will run
  94. #94
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    Disconnect the choke cables - push the chokes completely off by hand - to make sure the cables aren't holding the chokes on.
    FWIW,
    Carl B.
  95. #95
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    work is on hold for a few days. Still working on the dining room and office paint jobs, but managed to squeeze some Z time in. I found out I have had non functioning choke cables. I can barely get them to move. Not sure how they worked in my older setup. So I will need to get those off and try to lubricate them.
    Second, upon trying to start the car (which did roar to life rather quickly, but briefly) I noticed my fuel lines from the bowl to the car were SPEWING fuel on the ground. It was not from the where the jet nozzle is on the body, as that completely dry. Upon closer inspection, when I moved the fuel hose, fuel shot out of a small slit.
    I will contact ZT today and see if I can get some replacements. He mentioned in his video that at times those get damaged during shipping. It is easy to see why.
    As for how I fixed my coolant. I wanted to reuse the stock fitting that bolted to the side of the block. So I found a heater core cap that was made to block off coolant. It was remarkable easy and I was able to keep the stock routing of my heater hose. On the plus side, and another advantage to the 'while I am here' syndrome. I was able to finally add my heater grommet to the firewall, as well as my new choke cable grommet.
    Lets here it for unplanned and extra work.
    So, cliff notes version.... I got my carbs hooked up and all lines hooked up and got to hear some fire for a brief second before I saw some fuel leaking.
    New fuel lines and new choke cables (or repairing my old ones) and I will be back on the road.
  96. #96
    Registered User 7T1240's Avatar
    Member ID
    CZCC-9354
    Join Date
    Sep 2005
    Location
    Spokane, Washington
    Posts
    275
    Default
    UPDATE:
    Hi Stephen.
    I've been following this thread with great interest, hoping to largely duplicate your efforts in the near future. Will you provide more details about the heater core cap? Where you purchased it, part no. (if any), etc.
    Thanks, Gary S.
  97. #97
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    yup, got it at Advanced auto parts. Its just look like a hose with a domed closed end on it.
    I will try to see if I kept the package. If not, It would be my pleasure to shoot a close up pic of it for you sir.
  98. #98
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Thanks for all the excellent advice on the high rpm issue. I'll try them this weekend and report my findings.
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  99. #99
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    Quote Originally Posted by Carl Beck View Post
    FWIW,
    Carl B.
    This has my vote for the most likely problem. I personally fought with the choke cable setting over and over until I got it right. If the choke is partially engaged you can't actually set the mixture, and it will idle fast.
    A vacuum leak makes fuel injected cars idle fast, but I am not sure what would happen with SUs. My bet is that it would just run lean, or not at all.
    '71 240Z, Because any fool can drive fast in a straight line.
  100. #100
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    Found an OEM choke cable assembly on Ebay, and managed to win it for a reasonable sum, and the kind folks at ZT said they would be happy to send me new fuel lines. I cannot stress enough how fantastic it is to deal with people who care about their customers and strive to give them a good product and service.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Ztherapy??
    By H2O-Z in forum Engine and Drivetrain (S30)
    Last Post: 05-08-2012, 06:53 AM
  2. 73 Air Cleaner with ZTherapy Carbs?
    By Weasel73240Z in forum Carburetors (S30)
    Last Post: 12-05-2008, 10:47 AM
  3. Ztherapy S.U. conversion
    By rclayton12 in forum Carburetors (S30)
    Last Post: 04-24-2006, 06:38 PM
  4. Ztherapy SU's, wow what a difference
    By zguitar71 in forum Engine and Drivetrain (S30)
    Last Post: 05-30-2005, 12:42 AM
  5. Kudo's to ZTherapy
    By biker in forum Open Discussions
    Last Post: 10-20-2004, 07:10 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
