Results 1 to 11 of 11
Thread: mechanical fuel pump woes
  1. #1
    Registered User
    Member ID
    CZCC-9057
    Join Date
    Aug 2005
    Age
    33
    Posts
    3
    Default mechanical fuel pump woes
    Hey guys, this is my first post and although I have looked at the previous posts, I havent found the info im looking for. anyway, I have a 72 240z that I just recently purchased. It has been sitting for well over 15 years. I have had it for about 2 weeks now and I have just decided to try and get her started. After some fiddling, I managed to get it to turn over. It wouldnt start, I was getting spark so I begane investigating. I found that the fuel pump was faulty. So, I took it off the car, took the pump apart and cleaned everything out so it worked as it was supposed to. When it was all put together, It worked fine when I pumped it in my hands. However when I put it onto the car it didnt work. This worries me a bit because I know the pump runs off the cam, and since it wont pump when on the car, this leads me to believe the cam lobe has become flattened and can no longer push the lever far enough to pump sufficiently. Im curious if this sounds right, or if the problem is common. thanks guys!
  2. #2
    philo "Z" opher Zedrally's Avatar
    Member ID
    CZCC-2363
    Join Date
    Jun 2002
    Location
    Australia
    Posts
    1,818
    Default
    Never heard of a flattened lobe.
    Have you checked the filter?
    That and rust in the tank is a common problem in cars that have been sitting for so many years.
    Considering the period of time the car has been sitting I would suggest dropping the tank [it's not difficult, do a search for more info], cleaning it out etc, changing filters, and blowing out the fuel lines.
    MOM
    Mike of the Mire
    73 240Z Rally
    77 260Z Touring
    Bogged but not beaten
  3. #3
    Registered User MikeW's Avatar
    Member ID
    CZCC-3294
    Join Date
    Dec 2002
    Location
    Atlanta, GA, USA
    Posts
    2,739
    Default
    Quote Originally Posted by seventytwo240z
    As I recall you can take off the valve cover and easily see the offset cam lobe. However, before you do that, are you sure the fuel is actually getting to the pump? Since the car sat for so long you've presumably drained the bad fuel, blown out the lines with compressed air, and added fresh fuel.
    -Mike
    Add your Z to my online spreadsheet registry
  4. #4
    Registered User
    Member ID
    CZCC-9057
    Join Date
    Aug 2005
    Age
    33
    Posts
    3
    Default
    actually what I did was put fuel in a small container (an arixona tea bottle) and put the suction hose into the fuel. I couldnt get any fuel to suck into the pump when on the car. However when I tried pumping it by hand, off the car, fuel pumped easily. This is the only reason I suspect a cam lobe to be at fault. It just doesnt seem like the lever on the pump is being pressed far enough in by the cam to allow proper pumping. Maybe ill have to take the valve cover off to inspect further.
  5. #5
    Automotive Addict zman525's Avatar
    Member ID
    CZCC-8401
    Join Date
    May 2005
    Location
    Massachusetts
    Posts
    502
    Default
    wait wait wait... this happened to me on my 72 240 aswell.. Check the arm to the mechanical fuel pump that is suppose to be pushing on the lobe, make sure it has downward force on it... This is EXACTLY what mine did and i just loosened it all up and she pumped like she just came off the showroom floor
  6. #6
    Registered User
    Member ID
    CZCC-9057
    Join Date
    Aug 2005
    Age
    33
    Posts
    3
    Default
    Im not quite sure what you mean? do you mean when the pump is on the car, to make sure the arm has force on the cam lobe? if so, how exactly do I check this. I know the pump arm will move about 3/4 inch before it starts pumping, when I am checking it by hand. It only feels like the arm has force on it once I move it the initial 3/4 inch.
  7. #7
    Registered User Curtis240Z's Avatar
    Member ID
    CZCC-4128
    Join Date
    May 2003
    Location
    Hawaii
    Posts
    539
    Default
    There is a offset socket under the cam gear bolt that drives the fuel pump. Assuming it is there, you must make sure you have the fuel pump arm riding on it, NOT below it or the fuel pump will not operate.
  8. #8
    Member ID
    CZCC-8401
    Join Date
    May 2005
    Location
    Massachusetts
    Posts
    502
    Default
    kinda what i ment, but just take it out and move it up and down when u push up and let go does it fly back down? if not then it needs to be cleaned and lubed, and yes when you put it back in make sure its ontop of the lobe
  9. #9
    Supporting Member ChrisA's Avatar
    Member ID
    CZCC-5906
    Join Date
    Feb 2004
    Location
    Lincoln, NE
    Age
    52
    Posts
    1,471
    Default
    If you dont want to take the v/c off, shine a light in the fuel pump hole and look at the eccentric on the front of the cam. If you can rotate the engine while looking, you can examine the eccentric on a complete rotation. You could rotate the motor till the "bump" on the eccentric is towards the pump hole, then when you install the pump you can kind of feel the arm of the pump contact the eccentric. You have to push kind of firmly against the pump to depress the lever and slide it onto the studs in the head.
    Hope that makes sense and helps you somewhat.
    Chris
    1973 240Z HLS30-156693
  10. #10
    Former frequent poster sblake01's Avatar
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    San Bernardino, Ca. U.S.A.
    Age
    69
    Posts
    10,574
    Default
    They're talking about the fuel pump drive cam shown as #9 in this scan.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    2004 Ford Ranger EDGE Supercab
    (@Moonpup: This one really is an EDGE!)
    2005 Pontaic GTO
    2010 Mercedes Benz C300 AMG Sportline (Wife's car)
    2014 Kia Rio LX (Wife's daily driver)
    Certified HVAC/MVAC Technician
  11. #11
    Member ID
    CZCC-5906
    Join Date
    Feb 2004
    Location
    Lincoln, NE
    Age
    52
    Posts
    1,471
    Default
    Thanks Stephen, didnt have any pictures here at work.
    Chris
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
