Results 1 to 17 of 17
Thread: JDM 4 Barrel Carb & Manifold
  1. #1
    Laidback Purist moonpup's Avatar
    Member ID
    CZCC-10534
    Join Date
    Jan 2006
    Location
    Tx
    Posts
    748
    Default JDM 4 Barrel Carb & Manifold
    Check out this set-up currently on Ebay. Did any JDM S30's ever come equipped with this?
    http://cgi.ebay.com/ebaymotors/Datsu...64000945QQrdZ1
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	12251   Click image for larger version.
ID:	12252   Click image for larger version.
  2. #2
    ++++++++ HS30-H's Avatar
    Member ID
    CZCC-2116
    Join Date
    May 2002
    Location
    London, England, UK.
    Posts
    3,023
    Default
    Not fitted to any S30 as standard equipment from the Factory
  3. #3
    Member ID
    CZCC-10534
    Join Date
    Jan 2006
    Location
    Tx
    Posts
    748
    Default
    Thanks Alan, I read you LOUD and clear.
    Now I'm wondering about the E32 mark on the manifold. It is my understanding, at least here in the U.S., that parts with the "E" code (xxxxx-E4100, E31 etc.) were made for the 240Z.
    So my new question is was this manifold made for the S30 as some kind of "accessory/performance" part or were "E" parts made for other vehicles?
  4. #4
    Registered User
    Member ID
    CZCC-10050
    Join Date
    Nov 2005
    Location
    Eastern NC
    Age
    38
    Posts
    114
    Default
    I'm pretty sure "E" marked parts were use on other vehicles as well. This may have been off one of the roadsters or something. Not an original Z part, but the guy believes it to be a sedan part. What other vehicles in the early 70's did Nissan put out with the L6? All I know of are the Z's. The 510's I thought had a 4? Could eb wrong. This would be interesting to get details on.
    81ZX Stock, 215k+ miles and still rolling (daily driver)
    79 Fairlady 280Z, In need of major body work.
    77 280Z, Monster build, tripple throttlebody intake, TEC3, stroker...etc...
  5. #5
    Member ID
    CZCC-2116
    Join Date
    May 2002
    Location
    Posts
    3,023
    Default
    E32 = Showa 45 ( that's 1970 ) 'H130' series Nissan Cedric part ID.
    Didn't someone on this forum once post a question ( with pics ) asking about one of these carb / manifold setups that they found installed on a Z? Maybe it was a couple of years back.
    But it wasn't FACTORY .......
  6. #6
    philo "Z" opher Zedrally's Avatar
    Member ID
    CZCC-2363
    Join Date
    Jun 2002
    Location
    Australia
    Posts
    1,818
    Default
    I think it may have been one of my posts.
    I came across a zed once at Pick-a-Part with this combination and concluded that it was from a 260C.
    Not meaning to be picky, however the manifold was factory produced and used on the L26 in the Cedric, it just wasn't used in the HS-30/RS30!
    (I believe this is what you meant, just goes to show that people read meanings into statements in different ways)!
    Mike of the Mire
    73 240Z Rally
    77 260Z Touring
    Bogged but not beaten
  7. #7
    OK! ...I made it up. g72s20's Avatar
    Member ID
    CZCC-6441
    Join Date
    Apr 2004
    Location
    Sydney Australia
    Age
    62
    Posts
    564
    Question How similar are Prince and Nissan 6 manifolds?
    I'm not in a postion to check my references at the moment, but some of the guys here maybe able to check this;
    In 1965~ Prince Motor Company produced a 2.5 litre OHC 6 called the G11. (Very similar to the 2litre G7)This went into the S44 Gloria (B250 under Nissan). This used a 4BBL Hitachi as original equipment. Could this manifold be from one of these motors? I realise it would be an odd thing to make it's way to America, but these odd things do happen.
    Here's another off topic question for ya; Why is " four Barrel " universally represented as "4BBL"? Only 1 B in Barrel! My guess is the four holes in BB resemble a four barrel footprint...maybe?
    Regards,
    Jim.
    1972 Skyline GT-X (GT-R copy)KGC10
    Prince & Skyline spoken here
  8. #8
    Express Japanese Taxi ozconnection's Avatar
    Member ID
    CZCC-10105
    Join Date
    Nov 2005
    Location
    Sydney, Australia
    Age
    53
    Posts
    304
    Blog Entries
    1
    Default A little update fellas....
    I've owned and played with Cedrics for a long time and, no, that E32 doesn't belong to them.
    The E32 4 barrel manifold belongs to the JDM only Nissan PA30 Gloria of the late sixties. It was used on their 2 litre (L20A) engines.
    Tiny, tiny primary barrels measure 26mm's. Secondaries are 30mm's. Runners are 30mm's to match perfectly the E30 and Y70 heads they're fitted to. (The pictures from the above post look to me like the manifold mount for the carb are ported out and not original size).
    I just bought one from Ebay. Totally original and that's the way I'm going to keep it. Lucky too is the fact that a Clifford 6=8 intake manifold adapter fits perfectly so I can run my Holley on it. The E32 is a little oxidized but nothing a sandblast can't fix
    '78 280C sedan P30 Y70 L4N71B 4.11 H190 N/A A 'NEW" engine combination 131 rwhp.
    '71 240C coupe N42 NEW E88 FS5W71B 4.33 H190 Megasquirt V3.57 212 rwhp
    'Nissantiques - join the club'
  9. #9
    Member ID
    CZCC-2116
    Join Date
    May 2002
    Location
    Posts
    3,023
    Default
    Quote Originally Posted by ozconnection View Post
    According to Nissan's own data, the 'E32' code does relate to engine parts for a variant of the Cedric. I'm not saying that it doesn't relate to some of the Glorias too, as they are so closely related - but when I went looking to try to find an answer to the original question ( three years ago now ) the first thing I saw was 130-series Ceddy related.....
    How about one of the versions of the 'Cedric Special Six'?
  10. #10
    Member ID
    CZCC-10105
    Join Date
    Nov 2005
    Location
    Sydney, Australia
    Age
    53
    Posts
    304
    Blog Entries
    1
    Default
    Quote Originally Posted by HS30-H View Post
    Yes, very interesting. I know that the Cedric Special Six had an early style L20 engine and ran twin Su type carbs! Unfortunately, no mention of the E32 manifold in the Factory Service Bulletins (1966 Cedric 130 series Vol. 59)
    You're right about the "E" designations, take a look at the intake manifold for the later 230 series Cedrics that ran the E30 candilabra style intake.
    Gloria's are often much more highly spec'ed than Cedrics, especially the 230 and 330 series cars. I wonder if this applies to the Cedric P130/Gloria PA30 series cars as well?
    Had the manifold bead blasted today. A work of art now....as soon as I can, I'll download a few more pictures.
    Cheers
  11. #11
    Member ID
    CZCC-6441
    Join Date
    Apr 2004
    Location
    Sydney Australia
    Age
    62
    Posts
    564
    Default
    snip
    snip
    Hey Mark, can you back this up with some pics or other reference? I'm curious/interested in the Glorias of this era and the 4 barrel reference intrigues me!
    I've given my Prince Gloria manuals and parts books to someone who can actually use them so I've lost my own reference to the S44 G11 pics.
    Regards,
    Jim.
  12. #12
    Member ID
    CZCC-10105
    Join Date
    Nov 2005
    Location
    Sydney, Australia
    Age
    53
    Posts
    304
    Blog Entries
    1
    Default
ID:	31244Jim, some pictures of the Gloria. Nice car, I think they should have sold this O/S, especially in the US market.
    Here are a few pics of the E32 manifold.
    Enjoy!
Name:	E32 manifold 001 small.JPG
ID:	31245   Click image for larger version.
Name:	E32 manifold 002 small.JPG
ID:	31246   Click image for larger version.
Name:	E32 manifold 005 small.JPG
ID:	31247   Click image for larger version.
Name:	E32 manifold 006 small.JPG
ID:	31248   Click image for larger version.
Name:	E32 manifold 011 small.JPG
Name:	E32 manifold 013 small.JPG
  13. #13
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    Please don't take this the wrong way, but that Gloria looks like an Oldsmobile from the same era.
    (BTW, I rather like Oldsmobiles. So I guess it is a back-handed compliment.)
    NO, I am not saying it is a copy. Don't anyone get their dander up and start spouting relative production dates. It just looks a lot like some of the American "Heavy Metal" from the same time period.
    I still like the car.
    '71 240Z, Because any fool can drive fast in a straight line.
  14. #14
    Supporting Member =Enigma='s Avatar
    Member ID
    CZCC-9360
    Join Date
    Sep 2005
    Location
    Santa Cruz, CA
    Age
    52
    Posts
    2,401
    Default
    I love the look of that black Gloria. I've never seen one before. Sweet! Kinda reminded me of the 67 Chevy Nova.
    =Enigma=
    CZCC#9360
    4/73 - HLS30-156236
    My name is Adam and I'm a Zeeoholic!
  15. #15
    Member ID
    CZCC-10105
    Join Date
    Nov 2005
    Location
    Sydney, Australia
    Age
    53
    Posts
    304
    Blog Entries
    1
    Default
    I think the manifold should have something like this on it!!
Name:	E32 manifold 018 small file.JPG
ID:	31260   Click image for larger version.
Name:	E32 manifold 020.jpg
  16. #16
    Registered User
    Member ID
    CZCC-23885
    Join Date
    Mar 2011
    Location
    Morrinsville, New Zealand
    Posts
    1
    Default 67 Gloria
    Hey there ladds!!
    Here is a pic of the engine in my 67 PA30 Gloria as it was when I bought it recently.
    A G7 By Prince
  17. #17
    Member ID
    CZCC-2116
    Join Date
    May 2002
    Location
    Posts
    3,023
    Default
    Quote Originally Posted by jurassic.automotive View Post
    Hey there ladds!!
    A G7 By Prince
    Looks like you need to top-up the weedkiller reservoir.....
    Did they re-badge the Prince G7s with 'Nissan' logos on the few G7s used post-merger? Does yours have a 'Prince' logo on the engine and a 'Nissan' logo on the VIN tag?
    Don't know if it is would be any help, but I have three versions of the A30-series factory parts lists which cover your car. Would be happy to send them to you if you need them?
    Cheers,
    Alan T.
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
