Results 1 to 3 of 3
Thread: Peel and Seal question
  1. #1
    Registered User senkyoshi's Avatar
    Member ID
    CZCC-7543
    Join Date
    Dec 2004
    Location
    Pasco, WA
    Age
    42
    Posts
    33
    Default Peel and Seal question
    I posted this question on Zcar.com but I also wanted some input from another source. Although, some of you will also read tid there too.
    I am planning on putting down some peel and seal for vibration/sound control in my 240z. I know I could go with the more expensive name brand stuff but my dad just put some Peel and Seal on his roof and he has a lot left that he will give me for my car (key words "Save money!"). Besides, i have heard that Peel and Seal can be just as effective as the big name stuff.
    After some research through using the "search" feature and looking through other sites I learned that there are two kinds of Peel and Seal. With and without a shiny foil layer. My Dad has the kind without the foil layer. Do I have to use the kind with the foil layer for my application in my car or would the one without the foil work just as well? I know that many of the sound deadener products like dynomat and fatmat have the foil layer. What is the purpose of the foil layer? What would happen if I used the kind without it?
    Thanks for your help!
  2. #2
    240Z Original Owner ZIII's Avatar
    Member ID
    CZCC-7417
    Join Date
    Dec 2004
    Location
    El Paso, Texas
    Posts
    240
    George
    73-240Z, Original Owner
    Triple Mikuni Carbs
    5-Speed
    3.90 Diffy
    2:58 inch Exhaust
    Tokico Shocks/Springs
    105 Amp Alt
    MSD 6A ignition/coil/wires
    4 Core Radiator
    McIntosh Audio
  3. #3
    Registered User 240ZX's Avatar
    Member ID
    CZCC-1420
    Join Date
    Dec 2001
    Location
    Santa Paula, California
    Age
    68
    Posts
    1,884
    Default
    Quote Originally Posted by senkyoshi View Post
    The purpose of the foil layer is to reflect heat. Using the kind without should be OK as long as it is not subjected to alot of heat....such as one might encounter when using it in the engine compartment. But if it damps out sound and its free, use it.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
