Results 1 to 16 of 16
Thread: Some triple Weber pics
  1. #1
    Registered User george71z's Avatar
    Member ID
    CZCC-1730
    Join Date
    Feb 2002
    Location
    Melbourne, Florida
    Age
    67
    Posts
    445
    Cool Some triple Weber pics
    Seems to be a lot of triple carb questions lately. Here are some pics of my Weber set-up and hand-made linkage. I am by no means a machinist, but I had access to some hard aircraft aluminum (7075), a bandsaw and a grinding disc to get the shape I wanted. The linkage rod is 5/16 stainless rod with the stock Z U-bracket welded on the end, so I could use the stock setup from the firewall. The uprights and links to the throttle plates are Heim joints from a local speed shop.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	18716   Click image for larger version.
ID:	18717   Click image for larger version.
ID:	18718   Click image for larger version.
ID:	18719   Click image for larger version.
    72 240-- stock motor and drivetrain, 50,500 orig. miles
  2. #2
    Registered User red_dog007's Avatar
    Member ID
    CZCC-12322
    Join Date
    Aug 2006
    Location
    Chattanooga, TN
    Posts
    538
    Default
    Is your 240z motor mostly stock other then the webbers? How did performance change?
    I want to get a set of webbers on my 240z also, and sometime get it stroked.
    You wanna sell those!
    *Held for my future Datsun*
    1997 Buick LeSabre 122,000 miles (My DD)
    2003 Mitsubishi Outlander 90,000 miles (Wife's DD)
  3. #3
    Registered User Robin's Avatar
    Member ID
    CZCC-5458
    Join Date
    Dec 2003
    Location
    WA ST.
    Posts
    70
    Default
    thanks for putting those pics up, i do appreciate! one question, on the bottom of the thermo houseing, do you have a plug in the lower water port or is there a "T" fitting for the coolant line? I have included one of your pics with a circle on the part i am referring to. thanks again
Name:	thermoplug (Small).JPG
    73' 240Z HLS30-140770
    79' 280ZX HS130-120788
  4. #4
    Member ID
    CZCC-1730
    Join Date
    Feb 2002
    Location
    Melbourne, Florida
    Age
    67
    Posts
    445
    Default
    It's a plug. All the lower thermostat hsgs. I could find from early cars were trashed, so I used a later year.
  5. #5
    Member ID
    CZCC-5458
    Join Date
    Dec 2003
    Location
    WA ST.
    Posts
    70
    Default
    thanks!!
  6. #6
    240Z Elec. Upgrade guy Zs-ondabrain's Avatar
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Marysville, WA. U.S.A.
    Age
    48
    Posts
    4,004
    Default
    I got another question for ya. Why did you put springs on the linkage bar? Anti vibration or something else?
    I had to modify my linkage as well but it'll be hard for you to tell unless I point it out, which I won't do. I guess I got lucky with my carb connectors, I just use one push rod to move the front and the rest of them follow suit.
    Here are some pics but I don't have any good close ups yet. I'll post those later on. I've only had them for about 3 weeks and still need to tune them up better. Mine are 151's and the Weber book I bought does'nt cover 151's or 152's. SO I need the other tune up book just to find out what the white capped air bleed screws do. Unless someone here wants to link me to a page that covers tuning up a triple set of 40DCOE 151's.
    Nice set up though, I know I love mine.
    P.S. The pics below are from last week, I just installed an electric fuel pump, regulator and mini meter and also remodified the linkage cause I found the smaller linkage needed.
    Dave.
Name:	My new triple 40DCOE Webers 1 resized.JPG
ID:	19150   Click image for larger version.
Name:	My new triple 40DCOE Webers 2 resized.JPG
ID:	19151   Click image for larger version.
Name:	My new triple 40DCOE Webers 3 resized.JPG
    Rate my Z at Car Domain.com
    My 70' 240Z, Daily Driver
    My Parking Light and Headlight Upgrade Harness's at MotorSport Auto
    HLH - PLH - SCP - ZXP's at MSA *They accept PayPal!!*
    Headlight Upgrade Harness info here at ClassicZCar Club
    HLH info at CZCC Do a search for info on the other upgrades I offer.
  7. #7
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Age
    48
    Posts
    4,004
    Default
    I just took these pics about 20 minutes ago, Showing the updated linkage and fuel supply. New Spectre regulator and meter. and some Spectre SS and anodized aluminum parts.
    Also shown is 1 of 2, 4-screw carbs that I am completely rebuilding to spec. When I am done, the carbs, Linkage and intake with balance tube will be completely rebuilt and look almost new. Like you see on Z Theropy. They will be a complete bolt on ready set and I'll sell them for $500 flat plus S/H. Probably about a week before I'm done.
    Dave.
Name:	full pic new regulator and meter etc.JPG
ID:	19153   Click image for larger version.
Name:	new linkage and Spectre SS braid.JPG
ID:	19154   Click image for larger version.
Name:	close up on carb linkage and choke.JPG
ID:	19155   Click image for larger version.
Name:	close up on no. 2.JPG
ID:	19156   Click image for larger version.
Name:	rebuilt SU right carb.JPG
Name:	rebuilt SU right carb pic 2.JPG
  8. #8
    Registered User s14280zx's Avatar
    Member ID
    CZCC-10899
    Join Date
    Feb 2006
    Location
    Windber, PA
    Age
    45
    Posts
    102
    Default
    Quote Originally Posted by Zs-ondabrain View Post
    Dave.
    Nice setup. Did you have to buy differentthrottle adapters to link the carbs together like that, and if so where did you get the parts? thanks
  9. #9
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Age
    48
    Posts
    4,004
    Default
    Thanks, I worked like hell to bring them back from the dead, they sat on a display motor for 7 years and collected quite a bit of dust and crap. unfortunately, I can't help ya on the linkage. The triples came that way. They were off of another Z from 10 years ago, so it was already set-up that way.
    They're actually a pain in the ass to adjust this way. cause each one offsets the other with each turn.
    Dave.
  10. #10
    Registered User Amazombi's Avatar
    Member ID
    CZCC-4461
    Join Date
    Jul 2003
    Location
    Austria
    Age
    52
    Posts
    26
    Default
    Thanks for all those Pics guy`s.
    Anyone is a big help.
    Hey, visite my Site!
    www.amazombi.at
  11. #11
    Registered User
    Member ID
    CZCC-16252
    Join Date
    Mar 2008
    Location
    New Jersey
    Posts
    203
    Default
    Perhaps these photos will provide a few ideas for a heat shield and balance tube. Note that the original fuel rail brackets have been used for fuel supply, fuel return, vacuum and fuel vapor purge.
    Regards,
    Fixitman
Name:	engine lines0100_resize.JPG
ID:	22824   Click image for larger version.
Name:	fuel lines071231_007_resize.JPG
ID:	22825   Click image for larger version.
  12. #12
    Registered User graham53's Avatar
    Member ID
    CZCC-13689
    Join Date
    Jan 2007
    Location
    sc
    Age
    66
    Posts
    72
    Default Triple with air box
    Triple with air box
ID:	22848   Click image for larger version.
  13. #13
    Registered User
    Member ID
    CZCC-16252
    Join Date
    Mar 2008
    Location
    New Jersey
    Posts
    203
    Default
    Quote Originally Posted by graham53 View Post
    Triple with air box
    Very nice, creative design. Was it custom made? Where was it sourced?
    I would be interested to see a photo of the air filter arrangement.
    Regards,
    Fixitman
  14. #14
    Member ID
    CZCC-13689
    Join Date
    Jan 2007
    Location
    sc
    Age
    66
    Posts
    72
    Default
    It was custom made. the intake is a 4" very tight K&N cone
  15. #15
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Red face
    Triple with air box
    I tried very close to what you have-different filtration setup, but the acrylic kept deforming(South Georgia challenged A/C and plastic under the hood!).
    Will
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  16. #16
    Bobby Lee Bobby_Lee's Avatar
    Member ID
    CZCC-9082
    Join Date
    Aug 2005
    Location
    Rockland County NY
    Age
    69
    Posts
    30
    Default
Thread Information
Users Browsing this Thread
Similar Threads
  1. Triple Weber Downdrafts?
    By QMan in forum Engine and Drivetrain (S30)
    Last Post: 07-27-2006, 10:35 PM
  2. triple weber...but where the pcv??
    By kool240z in forum Engine and Drivetrain (S30)
    Last Post: 06-30-2003, 05:28 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
