Results 1 to 3 of 3
Thread: 240z electric fuel pump
  1. #1
    Registered User
    Member ID
    CZCC-13907
    Join Date
    Feb 2007
    Location
    Humble, Texas
    Posts
    1
    Default 240z electric fuel pump
    I believe I am having problem with the elect. fuel pump on my '73 z. As i recall, I thought I used to be able to hear the fuel pump operating when the ignition was on but the car not started. I am currently not hearing anything. Is my assumption correct. The car does not seem to run very long under load(normal driving), but it does idle ok. Thanks
  2. #2
    Registered User hd240z's Avatar
    Member ID
    CZCC-13159
    Join Date
    Nov 2006
    Location
    Lincoln, Nebraska
    Posts
    153
    Default
    It sounds like your pump is not running when it should be. It could be a blown fuse which is usually located under the dash in a separate fuse holder, or possibly the relay, but only the later 73s had relays, or a wiring problem or the pump itself may be bad. Might be easiest to start at the pump and check for 12v and chase the problem from there.
    Good Luck
    71 240Z HLS30 021986 (2/71 build) with 63,XXX miles
  3. #3
    Registered User
    Member ID
    CZCC-23987
    Join Date
    Mar 2011
    Location
    SOCAL
    Age
    29
    Posts
    7
    Default
    Sorry guys* too many threads open at once. Added a reply to what I thought was my current thread
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1973 240z fuel lines
    By J.T. in forum Carburetors (S30)
    Last Post: 07-05-2007, 04:15 PM
  2. Mechanical Fuel Pump 73 240Z
    By MAX in forum Engine and Drivetrain (S30)
    Last Post: 01-04-2006, 09:34 PM
  3. 240Z Fuel Pump alternative
    By =Enigma= in forum Engine and Drivetrain (S30)
    Last Post: 10-15-2005, 04:32 PM
  4. Turbo Fuel Tank
    By Aussie260z in forum Fuel Injection (S30)
    Last Post: 05-18-2005, 06:19 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
