Results 1 to 10 of 10
Thread: Weird advance curve
  1. #1
    Registered User
    Member ID
    CZCC-16100
    Join Date
    Feb 2008
    Location
    Sydney Australia
    Age
    48
    Posts
    78
    Default Weird advance curve
    Does this look right to you guys?
    http://www.youtube.com/watch?v=YVDeDyEaxU0
    I've got pretty poor driveability at low rpm, and I think maybe this might have something to do with it. Base timing is 15degs, but you can see that off idle it seems to retard (!) about 3 degrees before going all-in at about 2800rpm.
    I think it's a C210 Skyline distributor by the way, looks very much like an E12-80 but has a J-105 Mitsubishi module instead. Vac advance disconnected.
  2. #2
    Former frequent poster sblake01's Avatar
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    San Bernardino, Ca. U.S.A.
    Age
    69
    Posts
    10,574
    Default
    Judging by the picture, I'm not even certain of that beinig a Nissan distributor. At least, not like any I've ever seen. The screws that affix the module are on opposite sides from where they are on the Nissan distributor. And the body of the distributor looks different from any E12-80/93 distributor I've ever seen. Does the distrubutor have a part number on the body (opposite side from the pictire behind/below the vacuum pot)?
    2004 Ford Ranger EDGE Supercab
    (@Moonpup: This one really is an EDGE!)
    2005 Pontaic GTO
    2010 Mercedes Benz C300 AMG Sportline (Wife's car)
    2014 Kia Rio LX (Wife's daily driver)
    Certified HVAC/MVAC Technician
  3. #3
    Registered User
    Member ID
    CZCC-16100
    Join Date
    Feb 2008
    Location
    Sydney Australia
    Age
    48
    Posts
    78
    Default
    It's a Nissan distributor alright, here's a few more angles
    Pedestal neck looks like it's the 240Z type rather than the E12-80 type tho.
    I think it's from a JDM C210 (78-80) Skyline, with the injected L20 six....
  4. #4
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    Age
    69
    Posts
    10,574
    Default
    Looks totally different from any E12-80/93 I've ever seen but we didn't get C210s here. The E12-80 distributor didn't show up here until the 79 model year.
    2005 Pontaic GTO
  5. #5
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    I wonder if this is acting like the modules we have on out later 280 ZX Dists. Does the Skyline have a computer input to the module? When we try a module other than a 12 80 on our Carbed engines the input form the module causes the ignition to retard the timing, with out a signal form the computer. A friend of mine has devised a method to stop this from happening plus he uses a different vacuum advance that has two ports . One goes to the ported source just back of the front carb and the other to manifold vacuum. The claim is faster throttle response and better power and mileage. He has gotten 35 mpg on a bone stock 240Z with 150K. I haven't done this my self, but he is a VARY knowledgeable and respected guy that has been building Zs for over 30yrs. Gary
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  6. #6
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    Kim? in Idaho
  7. #7
    Registered User
    Member ID
    CZCC-16100
    Join Date
    Feb 2008
    Location
    Sydney Australia
    Age
    48
    Posts
    78
    Default
    Quote Originally Posted by beandip View Post
    Well it looks real similar to the E12-80 module, just 2 spade terminals with B and C on them. No other electronic input...and mine seems to retard the timing just off idle all my itself without any computer input
  8. #8
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Quote Originally Posted by Carl Beck View Post
    Kim? in Idaho
    Yup. He's worked it all out quite well. I haven't done it yet, but I might at some point.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  9. #9
    Registered User
    Member ID
    CZCC-16100
    Join Date
    Feb 2008
    Location
    Sydney Australia
    Age
    48
    Posts
    78
    Default
    Tonight was dizzy rebuild nite and I thought you guys might be interested in more details on this weird distributor.
    First I took off the dizzy and it was pretty grubby inside.
    Then I took off the vac advance pot thing
    Then the breaker plate
    Odd looking advance mechanism....but someone's already removed one of the springs in Japan to get it to advance quicker
    Tap out the spring pin with a punch and gently pull the whole shaft and advance mechanism out..
    Pretty grubby inside
    The old grease has long ago dried up and it was all very stiff
  10. #10
    Registered User
    Member ID
    CZCC-16100
    Join Date
    Feb 2008
    Location
    Sydney Australia
    Age
    48
    Posts
    78
    Default
    The advance shaft didn't spin on the main shaft very easily
    Very crudded up
    Clean everything with a scotchbrite
    Grease me up woman, I'm going in after this the advance mechanism was much smoother to turn by hand, in hindsight I think it was quite notchy before
    Reassemble...
    Bung back in the car...
    I think it advances a bit smoother...still has that little dead spot just off idle, but it seems to come on a little earlier. Timing is 17 at idle which seems to relate to 32 max.
    Before:
    After:
    http://www.youtube.com/watch?v=mfDM_-40xWQ
    I'm pretty sure it isn't my imagination, but it does seem to advance a bit earlier and smoother...not a massive difference but I guess we'll see when I drive it next.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Tripple Webers / Vacuum Advance ???
    By ZsRUSTIN in forum Carburetors (S30)
    Last Post: 12-04-2007, 11:35 AM
  2. Vaccuum advance placement
    By commplexone in forum Open Discussions
    Last Post: 12-04-2006, 10:11 PM
  3. help me understand my vaccum advance
    By datfreak in forum Electrical (S30)
    Last Post: 08-07-2006, 04:12 PM
  4. Unilite Distributor with mechanical advance vs vacumm advance
    By Panamared in forum Electrical (S30)
    Last Post: 06-13-2006, 02:50 PM
  5. advance curve of the '79-'83 ZX dist?
    By beandip in forum Engine and Drivetrain (S30)
    Last Post: 01-09-2004, 09:06 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
