Page 2 of 2 FirstFirst 12
Results 101 to 116 of 116
Thread: Ztherapy excitement
  1. #101
    Registered User 70 Cam Guy's Avatar
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    When I was still getting my car running on the round tops, I propped up my center console and pulled the choke cable completely out of the sheath. Once out, I cleaned it thoroughly and applied some light grease I have for door strikers and hinges. I fed it in the sheath and back out again. I wiped the cable with a shop towel and repeated the the process until the amount of black particles left on the towel was negligible. Once clean, I applied a small amount of grease to the cable and put everything back together. It made a world of difference.
    -Andy
    1973 HLS30-166105
    RB20DET swap, HKS GT2530 turbo, HKS Actuator, Hallman MBC, ebay intake manifold, ebay dump pipe, straight pipe, 14 psi boost
  2. #102
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    I may try to restore my stock cable for a spare using just that technique. For now I just use this NOS cable. It will be fun to try to fix the old one though!
    7T1240Z, here is your picture of the block off hose... sorry, but I must have thrown the package away... it was at advance auto parts, and it was in the radiator cap section
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  3. #103
    Registered User zmadnez's Avatar
    Member ID
    CZCC-20271
    Join Date
    Oct 2009
    Location
    OC Down Under
    Posts
    18
    Default
    Quote Originally Posted by Zedyone_kenobi View Post
    That's the exact cap that I have on mine. I bought the cap in a pack with other caps of various sizes from a local auto part shop (Kragen Auto). I believe you can get them through any auto parts stores.
    - Steve.
    '70 240Z - #4994
    '03 350Z - TRACK
  4. #104
    Registered User 7T1240's Avatar
    Member ID
    CZCC-9354
    Join Date
    Sep 2005
    Location
    Spokane, Washington
    Posts
    275
    Default
    Stephen, thanks for this info.
    Gary S.
  5. #105
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    65
    Posts
    1,746
    Default
    I just won a nice set of 72 carbs on eBay as spares. Plan to send my current carbs to Z Therapy to get them reworked in the next few months. My forward carb is just developing a bit of throttle shaft play.
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  6. #106
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    Ztherapy was amazingly fast in getting my new fuel lines back to me. Great service. IF you recall, I had a leak on the bottom of the fuel bowls on both carbs. Or so I thought. I installed the first line no problem and sure enough the line was slit letting fuel just pour out. When I went to install the second line, I noticed the fuel nipple coming out of the bottom of the bowl was bent 30 degrees to one side. The fuel line was fine, but the boss was cracked right where the brass nipple goes into the bowl. I have NO idea what I am going to do now.
    This was obviously handled VERY poorly by the shipping company. Looks like it may have been dropped directly on that nipple. I imagine that these are pressed in. I am thinking I may have to pull the carb off and send it back to ZT. Bad setback.
  7. #107
    Registered User Weasel73240Z's Avatar
    Member ID
    CZCC-14988
    Join Date
    Sep 2007
    Location
    Taunton, Massachusetts
    Age
    50
    Posts
    483
    Default
    That sucks. You can probably just remove the fuel bowl and send that back to ZT rather than taking the carb off.
    Paul Martin
    1973 240Z HLS30-127623 (10/72)
    4.11 R-180, 79 ZX 5-speed, ZX Distributor, ZTherapy SU's
  8. #108
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Did you catch up with Steve via the phone? He is very responsive to customer issues as infrequently as they arise. 503-365-8583 will get him at the shop.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  9. #109
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    Not yet, I did not want to bug him during the weekend. I will call later today. He was a pleasure to talk to with the fuel lines.
  10. #110
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    UPDATE:
    I know I have more updates than bad microsoft software, but in case people are interested.
    I contacted Steve at ZT and he was more than happy to take care of my problem. I will be sending the carb back to him to have him install a new bowl and then it will make its way back.
    Merry Christmas to ZT and great customer service.
  11. #111
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Great service indeed
    Patience is definitely important for the older cars as I have learned over the years. You are going to love having fresh, and balanced, carbs.
    -Andy
    1973 HLS30-166105
  12. #112
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    While I am waiting for my new choke cable to show up, and my rear carb to come back from ZT, I decided to take a shot at fixing my old choke cable. Holding the wire with vice grips set on gorilla tight, I tried to move the cable. No dice. I am going to try to spray some liquid wrench in there to wiggle things out.
    ON a happy note, I swapped out my old coil with a shiny new chrome Pertronix flamethrower!
  13. #113
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default Wow
    UPDATE:
    I cannot express how wonderful my new carbs work. I received the carb with the bent float bowl outlet back yesterday in wonderful shape. I was able to bolt it back together and get it tuned in less than 45 minutes. It was that easy. I find the fuel mixture to be about spot on at 2.5 turns out.
    What can I say about how these things run. My idle is rock solid at 750 rpm, and will actually idle down to 500 rpm quite easily. The throttle response and smoothness of the throttle is amazing. I had the sticky 240Z throttle that so many of us have with my old carbs, that is gone with my ZT carbs. Its such a joy to be able to glide away from lights as if it were a fuel injected car.
    Performance. In a word, awesome. My stumble I use to have at around 5500 rpm was not my timing or my dizzy. It was in fact my old carbs. I was able to rev to 6700 in second with absolutely NO issues at all. Smooth as melted butter in a quart of Amsoil in a rolls royce driven by angels.
    Starting is so much easier with a functional choke cable and the way the car performs very well. No matter what your SU issues are, ZT is your solution. They have been a joy to do business with, and words like integrity and service which are so missed these days seem to be a hallmark of Bruce and Steve.
    I always thought my Z was tuned pretty well, now it is as close to a new car feeling as it has ever been. I am stoked!
    Here is my baby finally back after enjoying some spirited driving today...
    BEFORE:
    AFTER:
    I still need to get a hose from my valve cover to the air cleaner housing and run a vent tube from the front carb float bowl to the air cleaner housing.
    Summary.
    Installed polished manifold and ZT SU's
    Refurbed my old air cleaner
    Installed flamethrower pertronix coil
    Installed new thermostat
    Refurbed fuel line
    Refurbed Thermostat Housing
    Refurbed heat shield
    New braided OEM braided line from balance tube to crankcase
  14. #114
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    75
    Posts
    1,334
    Default
    Stunning!
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  15. #115
    Registered User
    Member ID
    CZCC-18209
    Join Date
    Nov 2008
    Location
    Tuscaloosa/Winfield, AL
    Age
    30
    Posts
    221
    Default
    Glad to see you're as happy as I am with the ZT carbs. It looks like you got the upgrade finished in just enough time to consider it a Christmas present, as well.
  16. #116
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    39
    Posts
    567
    Default
    Looks great! Tuned carbs and a working choke are nice things to have. It probably feels like a totally different animal. All the little improvements do add up in the end
    -Andy
    1973 HLS30-166105
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Ztherapy??
    By H2O-Z in forum Engine and Drivetrain (S30)
    Last Post: 05-08-2012, 05:53 AM
  2. 73 Air Cleaner with ZTherapy Carbs?
    By Weasel73240Z in forum Carburetors (S30)
    Last Post: 12-05-2008, 09:47 AM
  3. Ztherapy S.U. conversion
    By rclayton12 in forum Carburetors (S30)
    Last Post: 04-24-2006, 05:38 PM
  4. Ztherapy SU's, wow what a difference
    By zguitar71 in forum Engine and Drivetrain (S30)
    Last Post: 05-29-2005, 11:42 PM
  5. Kudo's to ZTherapy
    By biker in forum Open Discussions
    Last Post: 10-20-2004, 06:10 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
