Results 1 to 12 of 12
Thread: Intake/Exhaust manifold
  1. #1
    Registered User JohnnyP's Avatar
    Member ID
    CZCC-20179
    Join Date
    Oct 2009
    Location
    Greenfield, NH
    Age
    30
    Posts
    115
    Default Intake/Exhaust manifold
    So I'm new to this world of restoration.. This is my first car.. I'm in the process of removing the intake manifold on my '76 280z and I'm a little stuck. I've removed the intake manifold bolts holding it to the head, I don't know where to go from here. I have removed everything that looks like it would be in the way but the thing won't budge..
    I guess my question is how do I pull the intake manifold?
    My Haynes manual is in the mail.. Any and all help would be greatly appreciated.
  2. #2
    Go Fast, Don't Crash 280~Master's Avatar
    Member ID
    CZCC-9867
    Join Date
    Oct 2005
    Location
    Savannah, GA
    Age
    47
    Posts
    859
    Default
    Johnny there are a few bolts and nuts that sit out of site. if you look in my gallery there is a picture of a head with the nut and bolt markings on it.
    My Gallery
    John Thomas Bertrand
    Model: HLS30 STD CPE 2DR
    Color: 305 LIGHT BLUE
    Serial: HLS30-298085
    Engine: L28-081399
    Port of Entry: 34 JACKSONVILLE
    Method of Transport: TRUCK
    Dealer to whom delivered:
    Brown Datsun INC
    213 E Liberty ST
    Lyons, GA 30436
  3. #3
    Registered User JohnnyO's Avatar
    Member ID
    CZCC-17819
    Join Date
    Sep 2008
    Location
    Hudson, WI
    Posts
    935
    Default
    I have a 240Z so it may be different but I removed all bolts from intake and exhaust. After that I took a block of 2x4 and put it against the exhaust manifold and gave it a good shot with a 3 pound sledge. It was just enough to loosen the gasket enough to "peel" it off the rest of the way.
    Hope that helps.
    John
  4. #4
    240Z Elec. Upgrade guy Zs-ondabrain's Avatar
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Marysville, WA. U.S.A.
    Age
    49
    Posts
    4,004
    Default
    The bolts on top are not the only ones. There are nuts all across the bottom of the intake that are "Shared" nuts. They hold the bottm of the intake and the top of the exhaust. You need to loosen all of them before the weight of the intake will pull the intake away from the head. DON'T USE A HAMMER!!!
    In the picture below (not a great one for the discussion) you'll see three top bolts, 3 middle nuts on studs and 3 bottom nuts on studs. The middle ones are the "Shared" nuts that need to be loosend, all the way across.
    Dave
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Rate my Z at Car Domain.com
    My 70' 240Z, Daily Driver
    My Parking Light and Headlight Upgrade Harness's at MotorSport Auto
    HLH - PLH - SCP - ZXP's at MSA *They accept PayPal!!*
    Headlight Upgrade Harness info here at ClassicZCar Club
    HLH info at CZCC Do a search for info on the other upgrades I offer.
  5. #5
    Member ID
    CZCC-20179
    Join Date
    Oct 2009
    Location
    Greenfield, NH
    Age
    30
    Posts
    115
    Default
    In order to reach those middle nuts do I have to remove the heat shield underneath the intake? And where are those bolts at? I have felt around underneath and have located a few but may have missed - or not be knowledgable - to the others
    Thanks for the the help this far, everyone has been a great help!
    -Johnny
  6. #6
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Age
    49
    Posts
    4,004
    Default
    Some are in blind spots, you just have to feel around.You need to reach under the exhaust manifold to get to them. The heat sheild is typically mounted to the intake.
    I can pesonally do it with my eyes closed but like I said, you gotta just feel around. Hell, just loosen every nut you find under there. Just remember to tighten then all back up when you're done. haha.
    Dave
  7. #7
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Age
    49
    Posts
    4,004
    Default
    Use this picture (taken from the gallery) to familiarize yourself with the bolt patterns and locations. Thanks Dkd021, great picture.
  8. #8
    Member ID
    CZCC-20179
    Join Date
    Oct 2009
    Location
    Greenfield, NH
    Age
    30
    Posts
    115
    Default
    So I've managed to locate all the hidden bolts and nuts but when I try and fit a socket to them it slips. So I downsize to the next lowest socket and it just slips everytime, until I get to too small of a socket and it doesn't fit. My question is what's wrong here and what's the best way to loosen this nuts? Should I be concerned?
    Thanks again everyone, your help has been greatly appreciated!
    -Johnny
  9. #9
    Registered User
    Member ID
    CZCC-5905
    Join Date
    Feb 2004
    Location
    Whistler BC
    Age
    61
    Posts
    14
    Default
    You must use metric sockets. 10, 12, 14 are the most common.
  10. #10
    Member ID
    CZCC-20179
    Join Date
    Oct 2009
    Location
    Greenfield, NH
    Age
    30
    Posts
    115
    Default
    So I have two bolts remaining under the intake and I have them fit to a 12mm socket. I was having trouble gripping them with the socket so i managed to get a hold on them with a wrench (same size). But whenever I think I'm getting a good hold on the nut, I realize that the wrench is just turning around the nut.. Is it possible that those two nuts are rounded off and unable to be gripped? I threw some heat at them, tried some liquid wrench as well.. Any suggestions?
    Everyone has been a lot of help, those pictures helped immensely! Thanks everyone.
    -Johnny
  11. #11
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    Sounds like the nuts are rounded as you said. Liquid wrench is a poor substitute for Kroil or PB Blaster.
    Do you have a Drummel or have access to one? You may find that you will have to split the nuts . Before you do this though, look into your socket and count if it is a 12 or 6 point socket. If it is a 12, this may be part of your problem if the nut is rounded off some. A 6 point will capture the flats on the nut better and is less likely to slip.
    Gary
    d
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  12. #12
    Member ID
    CZCC-20179
    Join Date
    Oct 2009
    Location
    Greenfield, NH
    Age
    30
    Posts
    115
    Default
    I'm using a 6 point socket. I did try a 12 point at one time but that wasn't catching at all. The 6 point catches, and when i turn it its pretty tough, could it just be so tight that instead of loosening the nut, the socket (or wrench) just slips?
    I do not have a drummel but might be able to get my hands on one.
    Thanks again
    -Johnny
Thread Information
Users Browsing this Thread
Similar Threads
  1. Changing intake/exhaust gasket on '83 motor
    By jezze in forum Help Me !!
    Last Post: 09-22-2006, 06:13 PM
  2. Need help locating intake/exhaust manifold gasket
    By Kaz in forum Engine and Drivetrain (S30)
    Last Post: 07-10-2006, 08:27 AM
  3. Torque specs for intake/exhaust manifold bolts...?
    By lww in forum Engine and Drivetrain (S30)
    Last Post: 08-21-2005, 10:01 PM
  4. which intake manifold has bigger runners?
    By z_boi in forum Fuel Injection (S30)
    Last Post: 07-21-2004, 12:01 PM
  5. Intake/Exhaust Manifold Torque Specs
    By dhoneycutt in forum Engine and Drivetrain (S30)
    Last Post: 05-26-2004, 08:57 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
