Results 1 to 3 of 3
Thread: 240K Coupe Brake booster / master cylinder
  1. #1
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default 240K Coupe Brake booster / master cylinder
    Hi,
    Can some one tell me what size brake booster / master cylinder came out on a original '73 Coupe,
    I was looking at mine today, and the booster is small, 5 inches by the looks, with a 3/4 master cylinder.
    Nigel
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	32681   Click image for larger version.
ID:	32682   Click image for larger version.
  2. #2
    Datsaholic Mr Camouflage's Avatar
    Member ID
    CZCC-1278
    Join Date
    Oct 2001
    Location
    Perth, Western Australia
    Age
    47
    Posts
    3,460
    Default
    Yep looks stock. They look tiny when compared with the later sedan ones.
    www.nostalgictrio.com Skyline - Silvia - Fairlady Z
    www.ozdat.com The Australian Datsun site.
    www.cafepress.com/vintagedatsun
  3. #3
    skyc110 skyc110's Avatar
    Member ID
    CZCC-12962
    Join Date
    Oct 2006
    Location
    Saudi Arbia
    Posts
    127
    Default
    this is the original one.... I have it on my 73 sedan as well, part # 47210 - R3000
    many of us change it to the bigger master of the c210, but now adays all old enthusiast go back to it. searching even for
    faulty ones , cause it makes the car look stock.
    to make sure I ll give some mesurements
    diameter 122 mm
    width 86 mm
    short distance between fixing bolts 88 mm
    long distance between fixing bolts 96 mm
    distance between the front bolts 68 mm
    the C110 240k is a not normal car
Thread Information
Users Browsing this Thread
Similar Threads
  1. Brake booster, master cyl upgrade
    By 240kconvertible in forum Wheels, Tires, Brakes (240K)
    Last Post: 12-01-2009, 08:49 PM
  2. Brake Fluid 101
    By Ed in forum Tech Pubs and HowTo
    Last Post: 09-10-2005, 03:44 AM
  3. brake master cylinder size
    By hf240z in forum Help Me !!
    Last Post: 09-08-2004, 06:54 PM
  4. Replies: 3
    Last Post: 04-18-2004, 02:30 PM
  5. DOT-4 vs DOT-3 brake fluid
    By TomoHawk in forum Wheels, Tires and Brakes (S30)
    Last Post: 12-07-2003, 05:40 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
