Results 1 to 10 of 10
Thread: camshaft replacement
  1. #1
    Registered User
    Member ID
    CZCC-19654
    Join Date
    Jul 2009
    Location
    new mexico
    Posts
    14
    Default camshaft replacement
    Hi, I want to replace my cam on my 73 240z and want to know if it is possible to do it with the head still on the car. Just to preface my question I have done a head change before so I know about the wedge in the timing chain and torque specs and all. I guess my main question is can you remove the camshaft with the towers which will involve removing the 5 long head bolts and in the process not have to "re-torque the head bolts" in the typical 'center out' pattern. If anyone can help it would be great!
    Thanks, Mike
  2. #2
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    Yes, the cam can be replaced with the head on the car. You do NOT remove the towers. What you need to do is remove the trans mount and lower the rear of the engine. This points the cam up enough to slide it out the front and clear the radiator support. You will need to remove the hood and radiator as well as loosen the fuel rail and move it up or down to clear the cam path. It isn't easy, but beats removing the head, manifolds, etc.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  3. #3
    Registered User
    Member ID
    CZCC-19654
    Join Date
    Jul 2009
    Location
    new mexico
    Posts
    14
    Default
    Jeff thanks for the quick response, I understand the proceedure you are decribing but how do you deal with the spring tension/pressure on the cam lobes to slide the cam out?
    Thanks, Mike
  4. #4
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    You need to get a service manual, it will describe the process. Removing the cam towers is a last resort and not recommended unless you need to shim them.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  5. #5
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    If you are only replacing the cam and leaving the springs alone, you can simply use a large flat blade screwdriver to remove the rockers. After you remove the springs at the adjuster end of the rockers, pry the valve spring caps down with the tip of the screwdriver while the shaft of the screwdriver is against the cast part of the cam - NOT the lobe. It's very easy with stock springs. Once removed, lay each rocker out on a clean towel or board in order so they can be reinstalled the same way they were. You will have to turn the cam such that the lobes are up while you remove the rockers.
    Once all the rockers are removed, set the engine to #1 TDC and wedge the chain before removing the gear and cam retainer plate.
    The manual can be downloaded from xenons30.com. It doesn't matter what year manual you download as the base engine disassembly is more or less the same.
    Jeff
    IZCC #1285
  6. #6
    Registered User
    Member ID
    CZCC-19654
    Join Date
    Jul 2009
    Location
    new mexico
    Posts
    14
    Default
    Thanks guys for the info. it makes sense now that you describe the process. One other question I have: Can camshafts be interchanged from the different L-series engines ie, 280 cam into the 240 head and vice versa, and what if you are using the old rockers on a new cam, will the new cam break in correctly?
    Thanks, Mike
  7. #7
    Biafra for President e_racer1999's Avatar
    Member ID
    CZCC-6883
    Join Date
    Jun 2004
    Location
    San Diego
    Age
    38
    Posts
    2,171
    Default
    Short answer: yes, all 6-cyl mechanical rocker camshafts are interchangeable. Slight difference in lift/duration/profile across years, I believe. I recommend to ALWAYS keep rockers and camshafts together, or have your existing rocker arms resurfaced.
    If you've never taken a cam/head off of a tension-type OHC engine, find a who has. Trust me when I say some experienced hands to help you out will save you hours of frustration. If the timing chain slips you will be hating life for hours.
    Jason King
    6/72 240Z / HLS30 89646 (Yellow)
    1996 Infiniti I30 *I finally have all Nissans again!*
    1971 510 4door (wife's car)
    IZCC Member #14186
    Quote Originally Posted by xray View Post
    As unfortunate as it may be, if you want to vintage race, go Euro....If you want to race for real, stick with the Z!
  8. #8
    Supporting Member Diseazd's Avatar
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    Don't put an L24 cam in an L28 w/o a spray bar.....L24 cams don't have oil holes in the lobes.
    http://www.flickr.com/photos/1404980...7600346077563/
    ______________________________________________
    http://www.flickr.com/photos/1404980...7603350695459/
    70, 71, 2 72's, and a 73 240z....
    90 300zx and a 1996 Acura NSX.....but who's counting?
  9. #9
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    Yep, like Guy said, if your Z does not have a spray bar, you must use an internally oiled camshaft. They can be identified by the oil holes in the lobes. If you do have a spray bar, you can use either style cam, but if you have a weak oiling system, your pump might not be able to support internal and external cam oiling. With a tight bottom end and a turbo oil pump, using a spray bar with an internally oiled cam is fine. An alternative is to use an internally oiled cam and buy the MSA block off plates for the towers. They are cheap and eliminate the spray bar.
    Given the choice, I like the spray bar, but it needs to be in good shape.
    Jeff
    IZCC #1285
  10. #10
    Registered User
    Member ID
    CZCC-19654
    Join Date
    Jul 2009
    Location
    new mexico
    Posts
    14
    Default
    Thanks guys for the info, I am just trying to get my 73' 240 running so as to have a driver car while I am restoring my 280. It's coming along but I have a long way to go. Happy new year to all.
    Mike
Thread Information
Users Browsing this Thread
Similar Threads
  1. Fuel Pump Replacement options?
    By clemsparks in forum Fuel Injection (S30)
    Last Post: 11-08-2007, 06:12 AM
  2. L24 E31/E88 camshaft on L28? good idea??
    By BuDavid in forum Engine and Drivetrain (S30)
    Last Post: 03-08-2007, 09:29 PM
  3. Got info on Camshaft. EN1 know about this cam?
    By ZSaint in forum Engine and Drivetrain (S30)
    Last Post: 02-12-2005, 09:26 PM
  4. MSA Replacement Fuse Box
    By mdbrandy in forum Electrical (S30)
    Last Post: 09-11-2003, 10:22 AM
  5. Welding Replacement Panels
    By spindel in forum Body and Paint (S30)
    Last Post: 09-08-2003, 11:22 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
