Results 1 to 10 of 10
Thread: Distributor configuration
  1. #1
    Tophu530 Tophu530's Avatar
    Member ID
    CZCC-19669
    Join Date
    Jul 2009
    Location
    Oregon
    Age
    27
    Posts
    52
    Default Distributor configuration
    I've got 72 240z that i bought about 7 months ago. I put in an l28 from a 280z with about 50,000 original miles and so everything is hooked up and I've been dieing to get this thing running seeing as it's my first car, but the thing wont start. even spraying gasoline into the carbs and sucking fuel up from the take isn't working. I still haven't tuned the engine yet so that could be a problem, but the one thing i'm not 100% sure on is the distributor. The manuals i have show which wires go where on the cap but there is no real reference point so i'm not sure if the wires are in the right ones. so if anyone could show a picture with labels for each wire going into the cap that would help.
  2. #2
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    Well , first off you have a fuel injected engine in a car that is set up for Carbs. Were you going to add SUs ? If so then the engine basic is the same. Use the ignition from the earlier engine. For now.
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  3. #3
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Number 1 on the distributor cap is generally the closest to the radiator.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  4. #4
    Member ID
    CZCC-19669
    Join Date
    Jul 2009
    Location
    Oregon
    Age
    27
    Posts
    52
    Default
    yeah I took off the fuel injection from the engine and bolted on the SUs from the original l24. so yeah i guess the distributer isn't the biggest thing i need help on cause i'm pretty sure i've got that all right but if anyone could help at al with starting the car cause I have everything hooked up. I tested the starter the alternator, and but new oil, radiator fluid, and everything should run but still the engine wont fire.
  5. #5
    Registered User
    Member ID
    CZCC-19613
    Join Date
    Jul 2009
    Location
    Everett, WA
    Age
    29
    Posts
    148
    Default
    Quote Originally Posted by Tophu530 View Post
    If the distributor is not working right the car isn't going to run. Have you check to make sure your getting spark?
    HLS30299157 1976 280Z
  6. #6
    NUTs according to wife ChrisZ's Avatar
    Member ID
    CZCC-14427
    Join Date
    May 2007
    Location
    Denmark - in front of my coffee, behind the laptop
    Age
    54
    Posts
    904
    Default
    Have you confirmed you have spark ?, if so i bet you have messed up your timing, it happens all the time.
    Chris
    -73 240Z HLS30-171039
    -66 Roadster SPL311-05204
  7. #7
    240Z Elec. Upgrade guy Zs-ondabrain's Avatar
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Marysville, WA. U.S.A.
    Age
    48
    Posts
    4,004
    Default
    Where in Oregon are you? You are in a highly 240Z owner, populated area. Let them know where you are and maybe one of them could help you out. 4 eyes are better than 2.
    1) the #1 spark plug.
    2) turn the engine with your thumb over the piston as it rises up and you should feel air escaping, That's your compression stroke.
    3) Use a wrench to slowly get the piston to the very top (I use a screwdriver in the hole to watch the piston, to make sure it's at it's highest point)
    4) pull the cap and look at the rotor on the distributor. Mentally mark where it's pointing.
    5) place the cap back on and make sure the #1 spark plug wire is centered over that position.
    6) The firing order is 1. 5. 3. 6. 2. 4. in a counter-clockwise rotation.
    7) Also check the timing notch on the crank pully, it should be about centered with 0*
    Then go from there, put the plug back in, plug wire on, coil wire on and secure.
    Or grab an extra spark plug and and check for spark off the #1 plug wire when you try to fire it up.
    let us know,
    Dave
    Rate my Z at Car Domain.com
    My 70' 240Z, Daily Driver
    My Parking Light and Headlight Upgrade Harness's at MotorSport Auto
    HLH - PLH - SCP - ZXP's at MSA *They accept PayPal!!*
    Headlight Upgrade Harness info here at ClassicZCar Club
    HLH info at CZCC Do a search for info on the other upgrades I offer.
  8. #8
    Registered User
    Member ID
    CZCC-20627
    Join Date
    Dec 2009
    Location
    California
    Age
    34
    Posts
    67
    Default
    favorite little memory device about spark plug order
    15 is too young
    36 is too old
    24 is just right
    makes you laugh and set correct spark wire order!
  9. #9
    DeesZ (John) DeesZ's Avatar
    Member ID
    CZCC-9676
    Join Date
    Oct 2005
    Location
    Pennsylvania - Millersburg
    Age
    68
    Posts
    745
    Default
    Picture as requested - hope this helps.
    Click image for larger version.
    See my Gallery .....
    http://www.classiczcars.com/photopos...00&ppuser=9676
    John
    CZCC #9676 - IZCC #14985
    1972 - HLS30-84646 - My driver - matching #'s - Nice ride
    1973 - HLS30-132236 - RIP - Reduced to boxes of spare parts in the garage
  10. #10
    Registered User
    Member ID
    CZCC-27293
    Join Date
    May 2012
    Location
    calif
    Posts
    1
    Default thanks for photo
    helps me just by looking
    Quote Originally Posted by DeesZ View Post
Thread Information
Users Browsing this Thread
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
