Results 1 to 2 of 2
Thread: Engine Cutting Out Sporadically
  1. #1
    Registered User
    Member ID
    CZCC-17479
    Join Date
    Jul 2008
    Location
    Sacramento, CA
    Age
    59
    Posts
    14
    Default Engine Cutting Out Sporadically
    Here is a mystery. The car is an early 71 that is essentially stock, but I run a header and a Mallory dual point mechanical-only distributor.
    It starts great every morning and runs well for about hour. Then I get a stalling effect. It is as if one turns the key off and then quickly back on. It happens once or twice at first but then gets more frequent as I go along. I had this problem before and replaced the positive and negative connectors at the coil and it went away. Now it is persistent.
    By the way, it only affects the engine voltage does not drop, the lights do not dim, etc. when it occurs.
    Any help is greatly appreciated.
  2. #2
    ZCCIV Webmaster motorman7's Avatar
    Member ID
    CZCC-19125
    Join Date
    Apr 2009
    Location
    San Diego CA
    Age
    57
    Posts
    988
    Default
    I had something like that happen to mine. The problem was the wire going to the dizzy would short on the exhaust manifold. I have since re-routed the wire to keep it way from the exhaust manifold. Just a thought. Also, check the terminal fits on the contacts for the entire ignition system (wires going to resistor and coil). Make sure they are clean and snug.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Working out bugs in engine -- Next obvious things to consider?
    By FastWoman in forum Engine and Drivetrain (S30)
    Last Post: 07-22-2009, 08:56 PM
  2. Would a blown head gasket cause my car not to start?
    By zalex in forum Engine and Drivetrain (S30)
    Last Post: 07-19-2009, 12:03 PM
  3. Engine Rebuild Parts Combination/Mix'N'Match Question(s)
    By texasz in forum Engine and Drivetrain (S30)
    Last Post: 06-15-2009, 08:41 AM
  4. Another discussion on L-series evolution
    By Carl Beck in forum Zcar History
    Last Post: 05-26-2009, 10:40 PM
  5. Wierd Engine combination in 280ZX
    By stevegee in forum Engine and Drivetrain (S30)
    Last Post: 12-06-2003, 05:55 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
