Results 1 to 7 of 7
Thread: Did all series 1 240's have a electric fuel pump?
  1. #1
    Registered User mally002's Avatar
    Member ID
    CZCC-13312
    Join Date
    Nov 2006
    Location
    Knoxville, TN
    Age
    53
    Posts
    710
    Default Did all series 1 240's have a electric fuel pump?
    I got a call today from the shop asking if all series 1 cars had electric fuel pumps, while finishing the fuel lines today they stated my car did not have one.
    I have no idea, so was wondering if you guys knew.
    Thanks,
    Randy
    1970 240Z HLS30 00797 White / Blue
  2. #2
    Registered User
    Member ID
    CZCC-6119
    Join Date
    Mar 2004
    Location
    Denton Tx
    Posts
    87
    Default
    73 was the first year. Came with the flattops to aid in preventing vapor lock maybe?Plus there might have been some emission ramifications too. It came on when ignition was turn to start only, as I recall. Mine stayed on all the time as the PO had set it up that way. I think the harness is there though if you want to retrofit.
    DK
  3. #3
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    IIRC, some of the very early '73s might have come w/o the electric pump also. I seem to recall that it was a late addition once the vapor-lock problem reared its ugly head.
    So #797 definitely would not have had an electric when new.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  4. #4
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    I would have to look through some of the old FSMs to be sure, but I seem to recall posts saying that the 240Z was wired for an electric fuel pump. The 240Z in America did not come with an electric fuel pump, but you might find 73s with them as that was one of the measures taken to reduce vapor lock.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  5. #5
    Supporting Member =Enigma='s Avatar
    Member ID
    CZCC-9360
    Join Date
    Sep 2005
    Location
    Santa Cruz, CA
    Age
    53
    Posts
    2,401
    Default
    The electric fuel pumps found on the 73 and 74 cars are but one of a series of potential modifications designed to address issues with vapor lock, and/or percolation due to heat soak in the mechanical fuel pump and fuel lines. The first caused a lean condition and the latter caused a rich condition and as well as overfill the float bowl resulting in raw fuel being spilled out into the air cleaner. All bad things. These things were really only an issue with the bulkier and dreaded flat top Hitachi carbs. These have mostly been replaced with the more popular round tops as a quick fix, or to avoid the final mod which consisted of installing a special hood scoop that required cutting holes in the hood. Not a very attractive mode IMHO. Finally, I seem to recall hearing that the wiring for the electric fuel pump may have been present on cars earlier than 73 but I don't know when that started or why it started prior to the 73.
    =Enigma=
    CZCC#9360
    4/73 - HLS30-156236
    My name is Adam and I'm a Zeeoholic!
  6. #6
    Registered User bobc's Avatar
    Member ID
    CZCC-9737
    Join Date
    Oct 2005
    Location
    Orange, California
    Posts
    344
    Default
    Datsun came out with what they called the V3 kit to "fix" the vapor lock problem on the 73 cars, leading me to believe that the 73's did not come with it or at least didn't until later in the model year. The kit had an 8 blade fan, pump, relays, wiring, and insulation for the fuel lines under the hood. I installed one on the 72 I had many years ago.
    Your car didn't come with an electric pump, but was probably wired for it. When you installed the V3 kit, the instruction pointed out where to find the wiring as it was already there. In fact the frame was already tapped for the screws that held the electric fuel pump. You just had to mount the pump, run the lines, plug in the relays and you were good to go.
    Best,
    Bob
  7. #7
    Member ID
    CZCC-13312
    Join Date
    Nov 2006
    Location
    Knoxville, TN
    Age
    53
    Posts
    710
    Default
    Thank you all for the information, that solves the mystery.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1972 Electric Fuel Pump
    By gotswap in forum Fuel Injection (S30)
    Last Post: 06-01-2009, 07:24 PM
  2. Electric Fuel pump installation
    By Mat M in forum Help Me !!
    Last Post: 11-29-2006, 01:44 PM
  3. releasing fuel press. with electric pump?
    By learnerZpermit in forum Help Me !!
    Last Post: 08-27-2005, 06:36 PM
  4. Which QUIET electric fuel pump to use?
    By ezzzzzzz in forum Carburetors (S30)
    Last Post: 04-12-2005, 04:21 PM
  5. auto shutoff for electric fuel pump
    By ta240 in forum Electrical (S30)
    Last Post: 02-16-2005, 08:58 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
