Results 1 to 5 of 5
Thread: Car won't start!
  1. #1
    Registered User
    Member ID
    CZCC-23192
    Join Date
    Dec 2010
    Location
    Santa Ana, CA
    Age
    32
    Posts
    3
    Exclamation Car won't start!
    A few nights ago I was driving my 1974 260Z home and my lights started to dim, windshield wipers started to slow, and my engine began to choke. At first I thought it was just my battery. So I had my battery jumped and it wouldn't hold a charge.
    I automatically assumed it was my alternator after checking all my fuses. I replaced the alternator and charged my battery. I was able to drive it for about 45mins. I went home, woke up the next morning, checked the belts and such, and drove it around the block to make sure all was going smoothly. It seemed okay.
    Once I turned the car off and went back to start it up again it wouldn't start. Any help or advice anyone has to offer would be greatly appreciated. If there is any information I left out please let me know!
    Thanks in advance!
    -Joseph
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Make sure that your voltage regulator is working. Your 260 should have an external regulator unless someone has switched it to an internally regulated alternator.
    You can probably have it checked at an auto parts store (take the new alternator in with it to confirm it's not damaged) or measure voltage at the battery while the engine is running.
  3. #3
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    I'm guessing the alternator or voltage regulator was bad, so it/they let your battery drain to nothing, which damaged it.
    If your system voltage is around 14.5V with the engine running, then the regulator and alternator are doing their job.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  4. #4
    Registered User JohnnyO's Avatar
    Member ID
    CZCC-17819
    Join Date
    Sep 2008
    Location
    Hudson, WI
    Posts
    935
    Default
    I had a similar issue this past summer. It turned out to be a broken connector under the dash on the passenger side. If you have been working under the dash it may serve you well to check all those rubber boots for solid connections, especially the white with red stripe wires that run from the fuse block.
    John
  5. #5
    Registered User
    Member ID
    CZCC-23192
    Join Date
    Dec 2010
    Location
    Santa Ana, CA
    Age
    32
    Posts
    3
    Smile Thanks everyone!
    I replaced my voltage regulator and ran a charging system test and battery test, everything came out alright and seems to be functioning...for now. I'll test it a bit more when I get home tonight and make sure it's still runnin' strong.
    Thanks again everyone! I really do appreciate your help!
    -Joseph
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. The latest in my car WONT START saga
    By MEZZZ in forum Electrical (S30)
    Last Post: 07-11-2008, 07:32 PM
  2. Car wont start!!!
    By Aussie260z in forum Open 240K Discussion
    Last Post: 09-19-2006, 10:59 PM
  3. Received the car I purchased off Ebay today.
    By Spridal in forum Open S30 Z Discussions
    Last Post: 07-28-2006, 07:03 AM
  4. advice on getting car to start again...
    By mikeltang in forum Open S30 Z Discussions
    Last Post: 04-16-2006, 10:47 PM
  5. please help my car wont start
    By JaYaYsSoHN in forum Electrical (S30)
    Last Post: 12-12-2004, 11:12 AM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
