Results 1 to 6 of 6
Thread: Quarter window replacement...
  1. #1
    Still Z 1
    Member ID
    CZCC-23596
    Join Date
    Feb 2011
    Location
    Reno, Nevada
    Posts
    30
    Default Quarter window replacement...
    I'll be honest, Guys, the thought of undertaking this job scares the hell out of me. It looks pretty straightforward, but if anyone can mess it up... I'm that guy. Advice please. I have the new glass/trim assembly. I guess it's the thought of screwing up the interior panel that has me freaked out. If anyone else out there has done this and can talk me down, that would be great. Thanks in advance. Cheers, Scott
  2. #2
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    Scott, I was going to replace the seals on my quarter windows. I removed the passenger quarter window. The process was VERY easy -- no risk to any of the parts. Upon removing it and seeing how the whole assembly went together, I was satisfied the area was perfectly tight, so I simply put it back together.
    On a scale of 1-10 in difficulty, it was about a 2 or 3. Spark plug wires and the air filter might be a 1.
    BTW, the interior panels are very easy to remove. You'll need to pull out your dome light, then remove the panel that fits into, and then remove the quarter window trim. To release a plastic rivet, simply push the little black rod through the rivet with a small nail or paperclip. It will fall harmlessly into the body cavity. Then you can pull the rivet out. If you're lucky, you can find the little rod again, so that you can reuse it. Otherwise you can order new rivets.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  3. #3
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    Scott, just wet the gasket well with windex or soap and everything will slide right in. Mine was a tight fit. The only caution that I have is that the frame is fragile so be careful. The ends are spot welded together and can separate easily. I found that out. Don't ask. I used my old ones one set was slightly rusted and they separated .
    Gary
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  4. #4
    This car is 40 years old?
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Colorado Springs, CO.
    Posts
    91
    Default
    Good info! I will be going through this soon enough! I have the new weatherstripping, just need to get everything cleaned up and put together.
    If anybody needs them, I have 2-3 extra sets of these windows. Just shoot me a PM if interested.
    Tim
    Tim Reinhardt - Colorado Springs, CO.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
    Rebuilding from the bottom up. Very cool project!
    96' Impala SS - Full custom build from top to bottom. This is my weekend toy!
  5. #5
    Registered User grantf's Avatar
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    What the others have sad. Take you're time though, I had to use really soapy water and had to push pretty hard rearwards while threading the little bolts on. Most of those tiny bolts were rusted and snapped on mine, I replace all 4 per side with ss bolts and washers.
  6. #6
    Still Z 1
    Member ID
    CZCC-23596
    Join Date
    Feb 2011
    Location
    Reno, Nevada
    Posts
    30
    Default
    I think I can, I think I can... I know I can. Thank you Lady and gentlemen. FastWoman nailed it for me. I couldn't figure out how to remove those bloody rivets without snapping them. As soon as it warms up a little (it's about 19 degrees in the shop at the moment) I'm gonna dive into this project. Thanks for your input Guys. Cheers, Scott
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. quarter window weatherstripping help
    By madkaw in forum Body and Paint (S30)
    Last Post: 04-11-2010, 05:44 PM
  2. Door Window Problems and Checks
    By EScanlon in forum Tech Pubs and HowTo
    Last Post: 09-02-2007, 02:55 PM
  3. Quarter Window Moulding
    By ZsRUSTIN in forum Body and Paint (S30)
    Last Post: 02-14-2007, 12:24 PM
  4. Door Window Adjustments
    Last Post: 10-22-2004, 08:27 AM
  5. Quarter window seals
    By GunnerRob in forum Body and Paint (S30)
    Last Post: 01-21-2004, 12:58 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
