Results 1 to 14 of 14
Thread: No fuel coming into filter
  1. #1
    Registered User StinkyCheese's Avatar
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Question No fuel coming into filter
    I have a '73 240z, stock. I finally got it to spark (see http://www.classiczcars.com/forums/s...ad.php?t=41386), and now I'm trying to get fuel to it. After a month of trying to get it to spark, I may have run all of the fuel through it. I put 5 gallons in the tank and cranked the engine for a good 2 minutes with no success. The fuel filter is dry.
    I looked in my Haynes and Chilton manuals. Each suggest that the '73 didn't have an electrical pump - only the mechanical pump up front. I crawled under and couldn't find an electrical pump, either. At least not an external one. I took a couple of pictures of what I did see, and I'm a little confused.
    There are two wires coming out of a module on the tank. I assume these are the fuel-level indicator wires. There are 2 more wires in the bundle that look like they've never been hooked up. (see pictures).
    Either way, I'm not getting gas to my motor. There hasn't ever been ANY debris in the fuel filter - I don't think its a clogged line. Assuming my fuel lines are dry and I only have the mechanical pump, do I have to prime it somehow?
    Thanks for the help - I'm really a noob when it comes to this, but I'm really enjoying the education. (My wife is trying to talk me into selling it, she doesn't really believe that I enjoy working on it. Would be an easier sell if it was ACTUALLY RUNNING).
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	40948   Click image for larger version.
ID:	40949   Click image for larger version.
  2. #2
    Registered User Powderkeg's Avatar
    Member ID
    CZCC-8478
    Join Date
    Jun 2005
    Posts
    222
    Default
    I had a similar problem with my 280Z with 72 SU Carburetors.
    My fuel line was clogged. And my Mechanical fuel pump was leaking.
    You said you don't think it's a clogged line... are you sure?
    Spray starting fluid into the bowls of the carburetors. I just pulled the hose from the top of the carb bowl and sprayed starting fluid through the inlet in both of the carbs. (See photo)
    The car started and ran for about a minute.
    I then blew out the hard lines from the tank to the fuel pump and carburetors.
    The car started on it's own and ran fine until I noticed the fuel pump leaking. Ordered a new one from AutopartsWarehouse.com for $19.95.
    The car runs fine (Except for two bad plugs wires..on order).
    Sounds like you may have to check your fuel tank for debris.
    A recoating of the tank may be in order.
    Also do you have a factory service manual? They are easily downloaded from this site.
    Good luck.
    Dave Ruiz
Name:	Carb Bowl Top.JPG
  3. #3
    Registered User
    Member ID
    CZCC-15144
    Join Date
    Sep 2007
    Location
    Murrells Inlet, South Carolina
    Age
    63
    Posts
    122
    Default no fuel
    That would be your sending unit for your fuel gauge.
  4. #4
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Question
    Quote Originally Posted by Powderkeg View Post
    You blew out the hard lines? Do you know how much gas you had in the tank when you did this? I read somewhere on this site that you have to have your tank 3/4 full for it to "prime" the line. I only have about 5 gallons right now.
    When you blew out the lines, how long did it take for the fuel to reach the front of the car? I wonder if there's a way to suck the fuel forward manually. I'd like to KNOW that the fuel isn't caught on a clog before I start tearing things apart..
  5. #5
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Default
    Cool, that's what I thought. Any idea what the spare wires are for?
  6. #6
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Spare wires are for an electric pump. Even cars that did not come with such a pump had the wires. Ignore 'em.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  7. #7
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Default
    Cool, thanks
  8. #8
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    What was the status of the gas in the tank pior to your starting this project? How long sitting?
    Take the gas line loose on the inbound side of the fuel pump and see if the pump will pump known good fuel to the carbs. Pull the plugs and just have someone spin the engine over. If things have been sitting a long time this will get oil pressure up in the bearings at the same time without hurting things any more. Then if the pump is pumping you should be able to start the car once you put the plugs back in 'natch.
    Then you can start back toward the tank. Probably wouldn't hurt to douche some of that Great Basin alkili dirt off of things while you are under there.....
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  9. #9
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Default
    Quote Originally Posted by StinkyCheese View Post
    So I took the advice and blew some compressed air down both the hard lines. Lo and behold, I took the air off and gas started flowing into my filter. But it still won't start. When I try to start it, you can see the fuel moving inside the filter. The filter is about 1/2 full. When I start cranking you can see the level go down to about 1/4 and you can see "pulses" of fuel going out of the top of the filter toward the pump. (I took a video and tried to attach it, but it wouldn't take. )
    Does anyone know if that is the proper behavior for the fuel. Should it be pulsing?
    The FSM says to test the pressure coming off the pump while the engine is running "at various speeds". Mine only runs at one speed - starter speed! It says "if the fuel in the carb float chamber has run out and engine has stopped, remove the clip and pour fuel into the carb." Can someone describe where I find this clip?
  10. #10
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Default
    The car has been sitting since October. It was nearly empty when it died, and I think I used all the fuel trying to get it started while diagnosing the spark problem. I put 5 fresh gallons in it last night.
    How will removing the plugs help? I'm confused...
    I'm headed to the parts store to get some long fuel lines so I can direct the fuel from the pump into a gas can. The FSM says I should be able to move 1/2 gallon in about a minute. I'm going to try that.
  11. #11
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Spinning over an engine with dry bearings with the plugs removed will take the strain off of dry bearings until you get oil circulating thru out the engine internals by spinning the engine over which in turn spins the oil pump. I just wasn't sure when some of this stuff was happening.
    Okay, now where exactly is this filter you mention? If it's after the fuel pump then it sounds like the pump is working and you can forget all that other stuff I mentioned. If the pump is working you should be able to fill the float bowls with fuel and from there it is all down hill. Gravity etc. etc. etc.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  12. #12
    Member ID
    CZCC-22497
    Join Date
    Sep 2010
    Location
    Sandy, UT
    Age
    48
    Posts
    67
    Default
    The filter is before the pump, so the pump is sucking fuel from it. I took off the hose that went from the pump to the hard lines that feed the carbs. I hooked up a 4' piece of hose and directed it into a gas can. The FSM says I should be able to move 1/2 gallon in a minute, but I think it meant at idle speeds... How do you do that??
    Anyway, with my daughter running the starter, the pump took a long time before it got fuel to the end of the hose. But when it did, it looked good (I guess). Like Bruce said, I should be able to fill the float bowls with the pump, so instead of trying to open it up, I hooked the hose back up to the carbs and cranked it. In about 15 seconds it started sputtering and a minute later I was revving! Such a sweet sound. That sound really brings a tear to my eye. Plus all the smoke in the garage helped.
    So anyway, after 5 months of off-an-on tinkering I took it for a short 2 mile drive. So happy.
    Since it appears I DID have a blockage, I think I'm on the path of dropping the fuel tank and getting it boiled out.
    THANKS everyone for your suggestions and help! These forums (and you guys) are amazing... Just wish I knew anything so I could give back! Who knows, maybe this thread will help someone lurking around...
  13. #13
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    Congratulations, John! It's a great feeling to make some old machine spring to life.
    Don't let your wife goad you into selling your Z! It will eventually become a fine car again.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  14. #14
    Brian
    Member ID
    CZCC-20911
    Join Date
    Feb 2010
    Location
    Richmond VA
    Age
    42
    Posts
    243
    Default
    For anyone who comes across this, here was my problem. No fuel coming to filter. I could blow compressed air through the line to the tank and here a few bubbles but not enough and I couldnt blow through it with my mouth. It was probably 97% clogged. Stuck a piece of baling wire into fitting on outside of tank and could get it about 2" from the bottom. I was just about ready to pull tank back down but as a last ditch effort...I pulled sending unit and moved pickup tube over just a little bit. Then I drained the gas and looked through the drain plug and was able to see the tube with all the crap in it. Ran a fish tape and carb cleaner through it and its now good to go. FWIW
    Brian
Thread Information
Users Browsing this Thread
Similar Threads
  1. Few questions: trans, fuel filter
    By 280ZSS in forum Help Me !!
    Last Post: 04-08-2009, 07:12 PM
  2. changed fuel filter, no start
    By h4nsm0l3m4n in forum Help Me !!
    Last Post: 05-12-2008, 07:20 AM
  3. 1975 280 z Fuel Pump has no power
    By shadesh in forum Help Me !!
    Last Post: 04-09-2008, 08:29 AM
  4. Fuel filter
    By Blue Meanie in forum Help Me !!
    Last Post: 04-22-2006, 06:44 AM
  5. 1975 280Z fuel pump issues (long)
    By mtcookson in forum Help Me !!
    Last Post: 06-27-2004, 05:30 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
