Results 1 to 8 of 8
Thread: Can you Rebuild the wiper arm linkage?
  1. #1
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default Can you Rebuild the wiper arm linkage?
    the bearings on the ends of the linkage from the wiper motor to the arms are very loose so there is a lot of slop when the arms are at either end of travel, and they stop in a different place when you turn the wipers off. plus they are making some clatter at the ends of the travel, and it's getting distracting.
    Is there a way to rebuild those bearings? they look a like a kind of Heim joint, but maybe there's something better to tighten it up? Maybe a replacement linkage from another model car?
    thxZ
    Drive Responsibly.
    enjoy classic Rock music.
  2. #2
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    I measured a number of vehicles in some junkyards to see if they had wiper pivots with the same spacing, thinking the motor and linkage could be adapted to work in the Z, but there wasn't anything the was close so far.
    Drive Responsibly.
  3. #3
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    55
    Posts
    1,052
    Default
    Yo THawk, It would be easier to find someone with a parts car and just replace. The bearings are actually bronze bushings, certainly a replacement could be found and inserted in the arm. You might try a Google search for Wiper Arm Bushings.
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
  4. #4
    Registered User 5thhorsemann's Avatar
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    54
    Posts
    1,398
    Default
    McMaster Carr has the bushings. I think the bushings I got from them were brass though.
  5. #5
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Autozone and other places list them, but I have not had a change to look at them personally yet.
    Drive Responsibly.
  6. #6
    Registered User
    Member ID
    CZCC-19249
    Join Date
    May 2009
    Location
    Knoxville, Tennessee
    Posts
    7
    Default
    Does anyone have a suggestion as to the best way to remove the tiny snap rings on the wiper arm shafts? I'm ready to rebuild mine, but all of my snap ring pliers are too big to use on these clips.
  7. #7
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Those clips are not very springy, unlike true C-clips. More like a stiff band that is just bent into place. Once you get them off, use pliers to bend them back into place in their slots. I actually replaced mine with a some common generic size of eternal c-clip.
    Now as to getting them off, put the arm in a vise, and use two smallish flat blade screw drivers to push the opposing tips of the clip apart. Or one flat blade of "just" the right width that you can use it as a wedge between the two tips.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  8. #8
    JDM esprist's Avatar
    Member ID
    CZCC-16910
    Join Date
    May 2008
    Location
    Southern, CA
    Posts
    537
    Default
    Well, if you careful, you should be removed with 2 small flat head screw drivers to open them up, and clamp them back on with a pair of pliers.
    See the pictures below. The rubber bushings can be replaced with rubber orings with high speed grease.
    It takes about 2 hours to get it cleaned and repaired.
    http://jdm-car-parts.com/restoration/Details.html
    Esprist
    Visit my blog & rare parts from Japan at
    www.jdm-car-parts.com
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Windshield wiper linkage torsion spring
    By TVollnogle in forum Open S30 Z Discussions
    Last Post: 05-26-2009, 09:50 AM
  2. Wiper Motor rebuild
    By TomoHawk in forum Electrical (S30)
    Last Post: 12-09-2007, 07:49 PM
  3. new parts for wiper motor attach to linkage...
    By dogma420 in forum Help Me !!
    Last Post: 11-04-2006, 12:29 PM
  4. Wiper arm rebuild
    By matria in forum Open S30 Z Discussions
    Last Post: 05-22-2006, 12:45 AM
  5. Quick rebuild of wiper arm pivots...
    By kmack in forum Tech Pubs and HowTo
    Last Post: 02-23-2004, 11:52 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
