Results 1 to 1 of 1
Thread: Balancing SU Suction Pistons and matching fall rates
  1. #1
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Balancing SU Suction Pistons and matching fall rates
    Below is a video showing how to match pistons so that they rise and fall at the same rate due to differences in mechanical tolerances where the piston is sealed by the suction chamber: (the process is simply to remove the piston and dome, tape the two holes on the bottom of the piston shut, then measure/compare the drop time of the pistons). This process only compares mechanical sealing.
    If your pistons don't fall at the same rate, don't worry, there are some solutions:
    I just experimented further and the oil well plungers AND the type of oil in the well AND the temperature affect these fall rates. In theory you should be able to match piston rates by using different oils/fluids of different viscosities in each well to better match pistons that are mechanically different and have unmatched fall times.
    You can also sand the outer surface of a plunger to decrease the drop time. (Sanding the sealing edge of a piston or sanding the inside of a suction chamber is not recommended).
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
Thread Information
Users Browsing this Thread
Similar Threads
  1. '71 240-Z no suction from one carb
    By Ttiger in forum Help Me !!
    Last Post: 09-20-2009, 06:34 AM
  2. suction piston carb problem
    By ajmcforester in forum SU Carb Discussions
    Last Post: 01-08-2008, 09:58 AM
  3. Balancing and blueprinting...what are they doing?
    By gogriz91 in forum Engine and Drivetrain (S30)
    Last Post: 12-10-2005, 09:11 AM
  4. Taking screws off suction chamber?
    By sahunt66 in forum Carburetors (S30)
    Last Post: 01-21-2004, 04:54 PM
  5. Engine Balancing?
    By Ed in forum Engine and Drivetrain (S30)
    Last Post: 01-27-2003, 08:41 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
