Results 1 to 17 of 17
Thread: back fire through the exhaust on deceleration
  1. #1
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default back fire through the exhaust on deceleration
    My duel SU round top 3 screw runs crappy and is backfiring through the exhaust when you pull your foot off the pedal(deceleration) what does this mean, does it mean it is running rich? Any help would be appreciated. It is also running rough and seems to want to stall. I just adjusted the carbs and float.I set the floats at 9/16 they do not suck full at that point but begin when the float starts to drop, I used the FSM for the carb sync.
    any ideas
    ZDUDE1967
  2. #2
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Where are your nozzles set in relation to the full up position? I suggest taking them down a half turn and see if the situation improves. If so that would be an indication you are lean which is what I suspect anytime backfiring under deceleration or spitting back through the carbs occur.
    You might also check for vacuum leaks....
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  3. #3
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    Thanks Bruce, I think my nozzles are somewhere in the 1.25. to 1.5 turns from the top range. I will try your suggestion and re-post with the results
    zdude1967
  4. #4
    Registered User Gary in NJ's Avatar
    Member ID
    CZCC-21253
    Join Date
    Mar 2010
    Location
    Amongst the twisty roads
    Posts
    1,057
    Default
    A good place to start is 2.5 turns. From there you can fine-tune as required. Do you own a unisync?
    Gary
    Guardian of HLS30-91415
    Previous Owner of a 10/70 240Z ('83-'85)
  5. #5
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    I own a synchometer, I think it is an SK brand from Germany. I may have gotten it from motorsports. Would having 2.5 inch exhaust with headers and a glass pack make it pop on deceleration or is popping strickly carb / lean fuel / vacuum leak related? I turned it back to 2.5 and went from there I actually redid the whole carb sync thing. It still pops. To be honest it was hard to hear when the idle smoothed out and increased when turning the mixyure nuts because my valves are so noisy. Which is concerning as the engine has 500 miles on a fresh rebuild. When I got it back from the rebuild the valves were to tight???,so the car ran on 5 cylinders. Perhaps needless to say but my faith in the engine rebuilder may be fading, that is unless the valve adjustment is common on a fresh rebuild-which I assume it is not, or is it? In any case I will be trying to find a vacuum leak and/or readjust the carbs then maybe bring it back for the valve adjustment as I only have a month left on warranty.....ah fun!!!! any additional suggestions or comments/ insight into the valve noise or popping would be greatly appreciated
    zdude1967
  6. #6
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    75
    Posts
    1,334
    Default
    Adjust your valves. Then go to the carb adjustment.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  7. #7
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    I am bring the car back to the engine rebuilder for the valve adjustment. I just got off the phone with them and they claim a valve adjustment is not included if you install the engine they rebuilt yourself. I know this is off from the carb issue but how would installing the engine yourself hsave abvything to do with the valves being done corectly on an engine rebuild
  8. #8
    Registered User 5thhorsemann's Avatar
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    53
    Posts
    1,398
    Default
    Quote Originally Posted by zdude1967 View Post
    Soooo......................They want to charge you to adjust the valves once in the car, as apposed to on the engine stand in their shop? I think you need to find a mechanic that isnt going to beat the crap out of you on price and charge you for doing things they MISSED the first time around.
  9. #9
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    I agree 5th horsemann...They ended up not charging me but I am not impressed with the whole experience
  10. #10
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    I find it hard to follow you guys thinking it's the engine rebuilders responsibility to adjust your valves after install. They do the machine work, and assemble it, YOU roll it out the door, put it in AND get it running. Adjusting the valves HOT is part of that "get it running" deal. YOUR PART.....
    Your builder did it just to get rid of you.
    That would be like buying a set of carbs from any rebuilder and expecting the carb builder to fly to your location and set 'em up for you.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  11. #11
    Registered User
    Member ID
    CZCC-16296
    Join Date
    Mar 2008
    Location
    Cornelius, Oregon
    Age
    47
    Posts
    238
    Default
    I agree with Bruce.
    I had a local and well-respected builder put together an engine for my Volvo 1800 years ago. He did not adjust the valves either. Since they are supposed to be adjusted hot, unless they start the engine at the shop, how could they even consider adjusting the valves for you? They would need your carbs and gas and an engine stand where they could hook a starter and battery power up.
    Learn to adjust the valves yourself....it isn't hard and takes less than an hour. Then you can do them yourself when they are due the next time too...
    Greg
    1972 Datsun 240Z
    1969 Volvo 1800S
    1985 Audi 4000 Quattro
    1989 Volkswagen Vanagon
  12. #12
    Registered User AWAUDIO's Avatar
    Member ID
    CZCC-21181
    Join Date
    Mar 2010
    Location
    Marin County
    Posts
    14
    Default
    FWIW, have you checked your dwell and timing advance? My 1972 240Z was doing something similar when I got it...
    dwell and timing were way off. Put in new points, set the dwell, set the timing (was off by 5 degrees) and backfire went away. Didn't touch the carbs till later (after buying Bruce's video BTW). Also, when my engine was rebuilt, valves
    were set "loose" to avoid burning, then they were adjusted to spec after 1500 miles or so. They were just clicking a
    little and after adjustment were nice and quiet. Still are. Hope this helps.
    Andy
    1972 240Z
  13. #13
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    Thanks for the advice. This is my first rebuild that I have installed myself, so I am not sure of what should be included. If the valve adjustment should not be included then that's cool even better since it indicates I am wrong and not the engine rebuilder. My pride has no problem being wrong, I rather be wrong then question the rebuilders integrity or skill. So with that said the engine rebuilder said the car is running rich as the exhaust smells like gas. Can popping occur with a too rich mixture or does it just happen when you are to lean. I adjusted the floats with the ZT video but the video is showing ball valves I have the old school needle valves and adjusted the float height to 9/16. The fuel flow is off at this height and begins to flow fuel once the float drop from the 9/16 position. Does this sound right?
    Thanks
    zdude1967
  14. #14
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Shoot me a phone number off list and I'll call and walk you through float level setting without the Grose Jets. I keep telling steve and Pam we need to re-do that part of thew video but it just doesn't seem to get done.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  15. #15
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    53
    Posts
    1,398
    Default
    Quote Originally Posted by Bruce Palmer View Post
    If the bench adjustment was so far off that the valves weren't closing and allowing unspent fuel to explode into the exhaust system, yea, theres a problem. The cold adjustment of the valves should be loose (noisy) but the motor should run well enough to get through the break in period at which point you take it to him and he does the hot adjustment. It has no relation to a carb setup, the carbs are flow bench adjusted to a meanial standard, whereas the valves are adjusted to a known set of mechanical measurements. Worst case, the builder should have told Zdude to do the brake in regiment and then come in for a hot adjustment, after all, it's not a track car with a pit crew, it's a classic car with an old fangled in line 6 and a shade tree mechanic/ owner. (No offence Zdude)
  16. #16
    Registered User
    Member ID
    CZCC-16936
    Join Date
    May 2008
    Location
    arizona
    Posts
    81
    Default
    No offense taken 5th horsemann.
  17. #17
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    For any of you out there who may be feeling uneasy about adjusting valves, our Tune Up DVD does a fair country job of showing how it's done plus other goodies that may help in your Z enjoyment.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
Thread Information
Users Browsing this Thread
Similar Threads
  1. Slight back fire and stumble!
    By 280m in forum Fuel Injection (S30)
    Last Post: 12-16-2011, 06:52 PM
  2. Vibration on deceleration
    By SteveJ in forum Engine and Drivetrain (S30)
    Last Post: 02-17-2008, 05:15 PM
  3. Back-Fire from Hell
    By 280ZManiac in forum Help Me !!
    Last Post: 07-18-2007, 03:32 PM
  4. back fire!
    By FairladyZS30 in forum Help Me !!
    Last Post: 04-18-2007, 03:45 AM
  5. Back on the Road, but exhaust leak...
    By mdbrandy in forum Engine and Drivetrain (S30)
    Last Post: 04-02-2006, 12:17 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
