Results 1 to 17 of 17
Thread: interior bulb replacements
  1. #1
    Registered User
    Member ID
    CZCC-25802
    Join Date
    Dec 2011
    Location
    washington state
    Posts
    1
    Default interior bulb replacements
    does anyone have a recommendation for the replacement of the interior dash, rear window defogger indicator bulb, manual choke indicator bulb etc as to the bulb type? i've checked my local autoparts store and they had nothing. Does the bulb sockets have to be replaced? can i order bulbs from somewhere? replace with led's somehow? my interior is going dark and i would appreciate any advice. My cars and early 1974 260z. thanks!
  2. #2
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    56
    Posts
    631
    Default
    There are lots of mail order companies on the web that have bulbs of all (most?) types.
    Try here: http://www.1000bulbs.com/category/mi...dicator-bulbs/
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    LEDs. You can remove the bulbs inside the instruments and use whatever color LED light you like.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Higuys,
    I'm updating my list of replacements, and the only bulbs I can't find are the ones in the defroster/hazard/seatbelt indicators. Is there a bulb number for those? From the look of the old bulb, it seems like an LED would fit just right.
    Click image for larger version.
Name:	280Z Bulb Chart.jpg
    Drive Responsibly.
    enjoy classic Rock music.
  5. #5
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    I agree with Steve, replace them all with LED's. I did all my dash lights, the overhead and map light, looks much better than stock.
    www.superbriteleds.com
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  6. #6
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    WAR, LEDs are out of order on a car from 1978 and they are just too much trouble.
    Drive Responsibly.
  7. #7
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by TomoHawk View Post
    Only if you're worried about staying 100% stock. Frankly I prefer being able to see my instruments clearly at night and not melting down the fusebox/wiring.
    73 240Z
    74 260Z
    Georgia Z Club
  8. #8
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Ok, then war it is! I put an LED in my dome light a couple months ago and I love it!!
    Story goes like this... About a year ago I bought a cheap "cool white" festoon bulb off Amazon and I hated it. I found it very harsh compared to the original incandescent. Even though it was supposed to be brighter than the incandescent it replaced, I found it harder to see with that typical harsh "cool white LED light".
    What I really wanted was a warm white bulb, but the problem is that the warm whites are always dimmer than their cool white counterparts and I was worried that it wouldn't be bright enough.
    So... I went one size larger and got one of these from superbright in warm white:
    I had to grind a little off the brass clip fingers in order to stuff it into the dome lamp housing, but now that it's in there, I absolutely love it!
    The whiter white from the LED style perfectly offsets the yellowing old lens plastic giving me a perfect incandescent "looking" light style. And going one size too large gives me an increase in light output that it's a good upgrade from the original incandescent without melting the lens with a larger wattage bulb.
    I'm not going for the dash bulbs, but for the done lamp? War it is!!
    I bet you would open my door and when the lamp would come on, you would think "Hmm... Seems brighter than mine", but you would NOT think "Oh... He's got one of those stupid LED lamps in there".
  9. #9
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Captain, you're spot on. I did my dash lights minus the speedo and tach(haven't been able to get them out with the dash cap on) which I will do soon, painted the inside of the cans bright white and used the leds which fit into the little clear green housing and voila' dash lihjts that are brighter with a slight green tinge, I love'em.
    75 280Z almost done
  10. #10
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Cap'n O-
    Can you give a specific part number or vendor for the lamp you used? Is that bulb something you can get from the local AP store?
    I agree that the LEDs can appear "too bright" as those SMD things have a narrow "beam." I was going to wire up a rearview mirror with dual reading lamps to turn on with the dome lamp, but I don't want to tear up the headliner, so maybe this is a reasonable compromise.
    Drive Responsibly.
  11. #11
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    I settled on Part Number: 3710-WWHP6.
    It's a 37 mm long festoon with 6 LEDs in warm white. https://www.superbrightleds.com/more...d-festoon/661/. It was a little longer than what fit comfortably between the mounting clips and I had to grind a little off the connector clip fingers in the lamp housing to get it to fit between the fingers, but it's a once and done job, I've very happy with the outcome. Brighter and not harsh.
    Hot the "specifications" tab and you can choose what color you want. Lots of people like the "cool white" color, but I'm not one of them. I find the bluish "cool white" light harsh. I bought "warm white" and I love it.
    Here's some pics showing what I had to do to the mounting clips to get the bulb to fit. I used a carbide burr on a dremel. Don't get tiny brass slivers stuck in your fingers (or eyes):
    And even though you can't tell much because there's nothing else to compare it to, here's the obligatory "ON" pic:
    If you don't want to deal with modifying the clips to get the wider festoon to fit, you can sacrifice some brightness for ease of installation and get a 4 LED shorter version instead:
    https://www.superbrightleds.com/more...toon/238/1129/
    Part number 3022-WWHP4 is the shorter 4 LED version in warm white.
    Lastly, I don't think you're going to find a "warm white" shade at a generic AP store. Seems most people like the bluish LED color of the "cool white" bulbs and that's all I've ever seen on the shelf. So if you want cool white, you might be able to find it local, but if you want to control the shade, you'll probably have to mail order it.
  12. #12
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Thanks.
    I don't think MSA will be happy with your discovery! They have that fancy LED board for the dome lamp. I like the warm colour better too- I grew up with all incandescent bulbs, so I'm used to the "warm" color in the car, even if it is a bit dull. I think if I had the rearview mirror with reading lamps installed, then I would use the cool white lights for illuminating "maps" (though I have a tablet with GPS navigation & maps.) but I do a road rally occasionally. I still have my clip-on map lamp with red LEDs tho.
    I've only seen the 4-LED festoon bulbs locally.
    LED headlamps are still scary to me. I'm used to the yellow of my halogens, so the blue light of new cars bothers me. Plus I don't like the idea of driving on a dark road or in the rain at night and have the LED headlamps suddenly go dark. I will keep using the halogens for a while.
    Drive Responsibly.
  13. #13
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Yeah, I grew up on the incandescent as well and completely understand. That whiter than white LED thing just doesn't work for me either. I don't know if it's all mental, or age... But I just don't feel that I can see as well with the cool white shade.
    The LED bulb I installed is a little whiter than the stock incandescent, but I find the whiter bulb offsets the yellowing old plastic lens of the dome light. End result is that I think it looks like it's "supposed" to look. Original shade, only brighter.
    Haha! I don't think my hair brained weird stuff I spend my time on is going to scare MSA or any of the other suppliers.
  14. #14
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Maybe MSA will figure out that this is a good product to carry, and get some.
    Drive Responsibly.
  15. #15
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Cap'n O-
    Do you know the exact distance between the festoon clips? You can get the LED bulb/panel in several widths like 31mm, 37mm and 42mm.
    There are some similar bulbs available (with 6 LEDs) and it is less expensive, but the LED panel is going in the other direction. Do you think it would be about the same? I figure the light would be concentrated towards the center of the cabin. They might be the hyper-white kind tho.
    BTW- I think the cheap festoon type LED bulb with the inline LEDs would be great for a high-mount brake lamp. I just don't know where to get the clips, and you need the red one.
    Drive Responsibly.
  16. #16
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    TomoHawk, The original festoon bulb is what they considered a 31 mm festoon, but that's measured tip to tip, so it's hard to draw any correlations without actual drawings of LED replacements.
    I measured the two lamp housings I have here and came up with the following:
    Distance between the inside edges of the brass contact clips = 0.67 inches.
    Distance between the plastic inside walls of the whole housing = 1.47 inches.
    That means in order to fit comfortably into an unmodified location, the wide PCB portion of the bulb must be less than 0.67 inches wide, and the overall length of the whole bulb (tip to tip) must be less than 1.47 inches.
    That bulb you linked to on Amazon looks very promising mechanically. It looks like it would fit better than what I used and I don't think you'd need to modify the contacts. If you could get that in warm white, it looks like a winner. I bet the ones on Amazon are cool white though (what you're calling hyper).
    The bulbs I used with the PCB turned the other way. You can see from the dwg why I had to remove some material from the clips to get the PCB to fit. I also had to file a tiny bit off the tips of the cones to get it to fit inside the plastic housing, but it was a small amount and very easy to do:
    Maybe you could dig up a mechanical drawing for the bulb you found?
  17. #17
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    I"Ll look into it.
    Duh- I have a spare festoon bulb in the drawer...
    Drive Responsibly.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Instrument Light Bulb
    By Darrell 240Z in forum Help Me !!
    Last Post: 01-15-2008, 12:11 AM
  2. Dash Bulb LEDs
    By BRE-240Z in forum Interior (S30)
    Last Post: 11-15-2006, 11:45 AM
  3. koito bulb
    By kats in forum Electrical (S30)
    Last Post: 04-07-2004, 07:52 AM
  4. Max Bulb Wattage?
    By Xargon321 in forum Electrical (S30)
    Last Post: 12-07-2003, 08:36 AM
  5. need vinyl interior replacements
    By My260Rocks in forum Body and Paint (S30)
    Last Post: 12-21-2001, 04:49 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
