Results 1 to 2 of 2
Thread: 74 260 ignition/startor HELP PLS!
  1. #1
    Registered User
    Member ID
    CZCC-26016
    Join Date
    Jan 2012
    Location
    Mesa, AZ
    Age
    36
    Posts
    1
    Default 74 260 ignition/startor HELP PLS!
    I have a 74 260 z. She has had some troble with starting. I rebuilt her but the wireing is so back wards I literaly can't get it straight. It died on me on my way back from a dent. app. luckily i had a timing light in the car so i could tell the coil stoped getting power. So I ran a wire straight from the battery to the coil for about 45 miles until I found the EGR valve wire was running 6/8 volts and hooked it to the ignition coil. Having long ago removing the EGR entirely. Then a month later the starter just stops working, New starter btw, and rechecked. Tried to wire the seat belt safty togther and all I got was the relay by the fusible link next to the battery moaning like a virgin at jounior prom. I'm at the piont where i'm going to have to wing it to rewire the whole car compleatly I guess. Don't know what to do. starts up just fine when I "Bump" the starter with a screw-driver, but only with a compleat and full charge on the battery. Please any advice would help. Thank you!
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    My first suggestion is to make sure you have properly bypassed the seatbelt interlock relay. Search on here. I know I've done some posts on that. It can be as simple as putting in jumpers to fool the seatbelt circuit into thinking the seatbelts are buckled. If you are more adventurous, I have attached a drawing from the FSM showing what wires need to be jumpered out to bypass the interlock relays. However, you'll need to match this up to the full wiring diagram to know what wires to jumper.
    Can you post a picture of the relay that was chattering? I have found that there are variations in component placement in the 260Z that I haven't been able to account for by the early/late designations.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Interlock Bypass.JPG
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Which to go for ignition?
    By red_dog007 in forum Electrical (S30)
    Last Post: 07-08-2007, 07:53 AM
  2. Need ignition help
    By 240zwinter in forum Help Me !!
    Last Post: 10-18-2005, 08:04 PM
  3. MSD Ignition
    By Zrush in forum Open Discussions
    Last Post: 06-06-2004, 06:38 PM
  4. Ignition
    By Mlaice in forum Help Me !!
    Last Post: 08-26-2000, 02:14 AM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
