Results 1 to 13 of 13
Thread: Oil Pan Gasket Replacement
  1. #1
    Registered User
    Member ID
    CZCC-25140
    Join Date
    Sep 2011
    Location
    El Dorado Hills, CA
    Age
    61
    Posts
    68
    Default Oil Pan Gasket Replacement
    Wow, that oil pan gasket job that I thought was going to be easy was a total bust!
    I ended up taking the pan back off because I could not get the gasket holes to line up with the holes in the block and pan. RTV sealer all over everything, including my helper. Are there any tricks I should be using? I had the whole pan/gasket combo glued together with sealer, but it slipped around during the install. Maybe I could get some really long bolts and thread them down through the block (where that is possible) as temporary guides. Now I have to order another gasket and get more sealer too. More room between the block and the crossmember would help line it up.
    One more item is reinstalling the rear main seal. Should I just give it a light coat of sealer and tap it in with a rubber mallet? I don't have the special installation tool that is 50 mm in diameter.
    Thanks for your ideas,
    Gary
  2. #2
    Registered User Bonzi Lon's Avatar
    Member ID
    CZCC-11300
    Join Date
    Apr 2006
    Location
    Kingman, Kansas
    Age
    64
    Posts
    1,155
    Default
    The new Black Dragon catalog shows 'Oil Pan Snap-Ups', pg 96 #53-506, set of 4 for $6.95. They look like a plastic 'kleco' type tool to hold the pan and gasket in place while attaching the bolts. I have no idea if they work like shown or not, first time I've seen them in their catalog. Might be something to look into for the price.
    Bonzi Lon
    1973 HLS30-168500
    1968 SPL311-18100
    1969 HLS30-000110 SOLD Shipped to Dubai UAE
    CZCC#11300
    Ones and Zeros
    "We drive only blue cars." Dishwalla
  3. #3
    Registered User
    Member ID
    CZCC-25140
    Join Date
    Sep 2011
    Location
    El Dorado Hills, CA
    Age
    61
    Posts
    68
    Default
    Those look pretty clever. I will give them a try and maybe go prowl the local hardware store for other options. Now to go clean up the mess!
    Thanks Again,
    Gary
  4. #4
    Registered User Pop's Z's Avatar
    Member ID
    CZCC-8342
    Join Date
    May 2005
    Location
    Fort Collins, Colorado
    Age
    74
    Posts
    430
    Default
    Hi Gary, Make sure that the pan is level around the holes. They can get out of shape and make the seal not work. You can use a hammer and a square piece of steel to do this. Speaking from experience, if you don't do this the pan will leak. I would not use RTV on the pan gasket. It could lead to problems if it gets in the pan/oil pickup. Use gasket adhesive instead and wait until it dries and the gasket is stuck to the pan and doesn't move. Are you trying to do this with the engine in or out of the car? If in, you need to get the car far enough up in the air to work efficiently. If out. flip the engine upside down if it's on a stand(beware of oil drips). FWIW this job is much easier with the engine out of the car and on an engine stand.Line up the 4 corner bolts first then do a few more opposite each other. Don't tighten them down until you have them all started. Tighten them down little by little and opposite each other just like with a cylinder head. Don't tighten them too much or they will snap off (ask me how I know this) making them a bear to get out. Follow the FSM for torque settings. My torque wrench didn't go that low so I had to guess. They really only need to be snugged up tight. Good luck.
    Cheers, Mike
    PS: do NOT use RTV on your rear seal, either.
    '73 240Z, 80,000 original miles, F54, N42 massaged and shaved (10.5-1 comp.), stage 2 cam, ZX ignition, Header, 2 1/2" exhaust w/ magnaflow muffler, 5 spd (Maxima), 4:11 R180 (200SX), 15" Rota RBs 205-60/15 Bridgestone Grid 109s, KYB struts, stock springs, rubber bushings, MSA sway bars and strut bars, HotRod Air hvac system, '90 300ZX seats, upgraded sound system, BRE-type spook and spoiler
  5. #5
    Supporting Member Diseazd's Avatar
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    Which gasket are you using? The Nissan factory cork gasket, or the competition gasket? If you use the comp gasket, it's really important to take Pop's Z's advice. The cork is a lot more forgiving. I don't use any RTV and I use cork......never had a problem.
    http://www.flickr.com/photos/1404980...7600346077563/
    ______________________________________________
    http://www.flickr.com/photos/1404980...7603350695459/
    70, 71, 2 72's, and a 73 240z....
    90 300zx and a 1996 Acura NSX.....but who's counting?
  6. #6
    Registered User
    Member ID
    CZCC-25140
    Join Date
    Sep 2011
    Location
    El Dorado Hills, CA
    Age
    61
    Posts
    68
    Default
    The engine is in the car, so the first order of business is to get some additional clearance to install the gasket. I just ordered a new Victor/Reinz cork/rubber gasket which was $13 compared to the cork at $6. Sounds like I need to get some gasket adhesive rather than the RTV so no little worms of silicon get into an oil passage. One last question: should I put adhesive on the block side of the gasket too? If I do not, it makes installation a lot easier.
    Thanks!
  7. #7
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    76
    Posts
    1,334
    Default
    With the engine in, you've got a job. If you haven't already, you'll need to drop the sway bar and maybe the oil pump (can't remember for sure). No adhesive on the block, just make sure the mating surface is squeaky clean with zero old-gasket-residue. Get the first corner bolt in, as Pop's Z said, followed by the bolt on the diagonal corner opposite and work your way around. I think it took me about three hours to do mine several years ago... or maybe it was 3 days!
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  8. #8
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    Where did you get the Victor/Reinz gasket? It sounds like a nice gasket. Do you have pics? I usually use gasket adhesive on the pan side. You can spray it on the gasket and lay the pan on the gasket, adjusting the holes with a tooth pick until it sets up........Then you can get a few bolts started with the help of a friend. I installed mine without removing anything, or even raising the engine.
  9. #9
    Registered User
    Member ID
    CZCC-25140
    Join Date
    Sep 2011
    Location
    El Dorado Hills, CA
    Age
    61
    Posts
    68
    Default
    I ordered the gasket from Autozone, so they should be readily available. Mine will not arrive until Tuesday. I will post a photo.
    As long as I don't have a sticky gasket facing the block during the install, I should be fine for clearance. I just cheat the pan around the oil pump suction with some help from my son.
    I finally have all the RTV cleaned off of the block and the pan. Thanks so much for the advice.
    Gary
  10. #10
    Registered User
    Member ID
    CZCC-30242
    Join Date
    Mar 2014
    Location
    USA
    Posts
    2
    Default datsun 260z oil pan gasket
    Quote Originally Posted by ggunder View Post
    Gary
    all I have the same issue I am referbing a 260z that my aunt gave me and I just noticed some oil underneath it. I think that I have to change the oil pan gasket and was wondering if there are issues that I should be aware of and can a average person do this? any and all advice would be very helpful.
    thanks
  11. #11
    Registered User er34gtt2000jp's Avatar
    Member ID
    CZCC-8081
    Join Date
    Mar 2005
    Location
    Sacramento CA
    Age
    45
    Posts
    466
    Default
    Hey, you could get yourself a bunch of little 4mm (think that's the size) studs and covert the oil pan to studs and nuts. Then just push the gasket up onto the studs and follow suit with the oil pan ;-)
  12. #12
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Don't forget that having the crank in a certain position allows for more clearance when wedging pan between the crossmember .
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  13. #13
    Registered User
    Member ID
    CZCC-30242
    Join Date
    Mar 2014
    Location
    USA
    Posts
    2
    Default
    Does anyone have any pictures of how the oil pan sits underneath the car? the reason that I am asking is because I had surgery on my foot and cant crawl under there at this moment and I was even wondering if this is something that the average person can do, any input would be very helpful.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Head gasket + timing chain replacement.
    By Rocket88 in forum Engine and Drivetrain (S30)
    Last Post: 05-05-2011, 05:15 PM
  2. Replies: 4
    Last Post: 04-03-2005, 07:39 PM
  3. Intake/Exhaust Gasket replacement?
    By Chewievette in forum Engine and Drivetrain (S30)
    Last Post: 12-04-2004, 09:08 PM
  4. Any tips on head gasket replacement?
    By Gee in forum Open Discussions
    Last Post: 06-26-2003, 02:11 PM
  5. 240z Rear Diff Gasket replacement
    By Zsled in forum Help Me !!
    Last Post: 03-28-2003, 05:43 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
