Results 1 to 16 of 16
Thread: Melted Fusebox
  1. #1
    Registered User BoldUlysses's Avatar
    Member ID
    CZCC-24084
    Join Date
    Apr 2011
    Location
    Winston-Salem, NC
    Age
    41
    Posts
    149
    Default Melted Fusebox
    It's been this way for some time (back when the car was last driving—in '04). Now I'm finally addressing it.
    The dash/parking lights wouldn't come on, and the culprit was the fuse you see. The metal part wasn't broken, but the left end was corroded and melted, which caused the break. I replaced it with a new one, and immediately smelled burning and the terminal area was too hot to touch.
    Do I have a short somewhere in the dash/parking light circuit? If so are there any typical places to look?
    I can fix mechanical stuff, but electrics are a bit of a black art to me. Hence the reason I'm restoring a Z and not something with Lucas electrics.
    Matt | Spannerhead.com | Original Z Owner #129 (2nd Gen) - '72 240Z (HLS30-93069) • '95 525i/5 • '05 MPV
  2. #2
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    75
    Posts
    1,334
    Default
    MSA has an upgrade for this that provides modern blade fuses instead of the old glass fuses. It's well worth the price. I doubt you have a wiring issue.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  3. #3
    Member ID
    CZCC-24084
    Join Date
    Apr 2011
    Location
    Winston-Salem, NC
    Age
    41
    Posts
    149
    Default
    I was going to ask about that but I didn't want to pepper you guys with too many questions. Awesome—I'll look into that for sure.
    Why would the fuse terminal get so hot if I didn't have a wiring issue? Heat = too much current = short somewhere. Right?
  4. #4
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    75
    Posts
    4,424
    Default
    Quote Originally Posted by BoldUlysses View Post
    Heat = too much resistance. Too much resistance in the loose and corroded fuse terminal on one end.
    Yes - a dead short will draw too much current and because the wires are too small to carry it - they get hot, and in a good circuit the fuse will blow. If there is no fuse between the battery and the short in the circuit - then the wires will melt.
    FWIW,
    Carl B.
  5. #5
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Matt, look for my Sold on LEDs thread. Replacing the incandescent bulbs with LEDs will drop current flow through the circuit greatly. Also consider getting the parking light relay harness from Dave Irwin, aka Zs-Ondabrain. Also, unless you have more fuse boxes lying around, you might need to get the replacement fuse box from MSA.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  6. #6
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    FAIW, while that fuse box might be slightly unsightly, there's nothing wrong with it functionally. Just clean the metal with distilled vinegar, dry, and lightly coat with a bit of silicone dielectric grease. Then you'll have excellent contacts with very little resistance and therefore very little heat.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  7. #7
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    56
    Posts
    631
    Default
    Quote Originally Posted by FastWoman View Post
    Unless the clips have lost their temper. When they overheat they can lose the spring temper and the pressure to hold the fuse will be too light and the resistance will be high enough to allow a recurrence. In this case replacement clips could be used if you want to keep the OE fuse box badly.
  8. #8
    Member ID
    CZCC-24084
    Join Date
    Apr 2011
    Location
    Winston-Salem, NC
    Age
    41
    Posts
    149
    Default
    Quote Originally Posted by Carl Beck View Post
    FWIW,
    Carl B.
    Carl— Thanks for clearing that up.
    Quote Originally Posted by SteveJ View Post
    Good tips, Steve. I'll look up your thread. LEDs aren't really considered by the BMW world because of the cars' self-monitoring systems—if resistance in a circuit drops too low (either by a light out or installing LEDs), a dash warning trips on. But our Zs don't have that "protection."
    Good to know. I might do that just to get the car running. Will definitely replace the fusebox in the long run.
    Quote Originally Posted by beermanpete View Post
    Lol. The OE fusebox is trashed, cover melted, etc... Good points about the temper, though.
  9. #9
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    To be pedantic (a trait that I'm good at ), LEDs have high resistance and low current. An incandescent bulb is a piece of wire that glows because of low resistance and relatively high current. As you noted, the Z does not monitor resistance in lighting circuits, so there are no worries about using LEDs. Though, I believe LED vendors are also selling devices to fool the onboard systems that do monitor resistance. It would essentially be a bypass for the circuit.
    73 240Z
    74 260Z
    Georgia Z Club
  10. #10
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Age
    56
    Posts
    631
    Default
    The only issue with the LEDs is the turn signals. Some flasher units are load (current) dependent and won't flash if the load is wrong. You can get flashers for different loads or get the heavy duty type which is not load dependent.
  11. #11
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Very true. I put the part number in a post in the Sold on LEDs thread. It was the Bussmann 232.
    73 240Z
    74 260Z
    Georgia Z Club
  12. #12
    Registered User
    Member ID
    CZCC-22955
    Join Date
    Nov 2010
    Location
    North Texas
    Age
    56
    Posts
    46
    Default I read a good article today on the Datsunzgarage site about blown fuses and bad
    bad contacts in the turn signal lights listed under the common z car problems. Maybe take a look at all your parking lights and see if you have some of the same problems.
  13. #13
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    Wow, what are the odds of that? My fuse box looks exactly like that!
    Apparently that is usually the first fuse to burn out. It must be a high load circuit.
    I just replaced the fuse on that circuit with an in-line fuse holder. However after a couple of years the remaining clips were so weak that they stopped holding the fuses tight and they started to heat up as well. I "fixed" it by pulling the battery out, taking out all the fuses, and then using a plastic wire tie around the base of each clip to clamp every fuse in place. (It will be a real pain to replace any of them now...)
    I know however that what I did is only a temporary measure. Eventually the MSA fuse box upgrade is probably in my future. You might want to bite the bullet and replace the fuse box now...
    '71 240Z, Because any fool can drive fast in a straight line.
  14. #14
    Registered User
    Member ID
    CZCC-4044
    Join Date
    Apr 2003
    Location
    Denver
    Posts
    1,008
    Default
    This along with the headlight harness and for the modern blade fuses get the msa fuse block. As Dave has explained in previous threads all the current to run the PL and HL run through the fuse block and the combination switch. If you take the clam shell off the steering column you will see the white and red wire deformed from all the resistance. The msa fuse block will curtail much of the resistance, but you still have the power to the HL and PL running through the combo switch.
    things will only bother you if you let them.
    82 280zxt 4 spd auto
    73 240z--lsd, cv axles
    short throw info
  15. #15
    Registered User
    Member ID
    CZCC-27328
    Join Date
    Jun 2012
    Location
    Severna Park, MD
    Posts
    16
    Default
    Hi,
    I realize this is an aged thread, but it's ironic I'm repairing a damaged fuse box in the same location. What is MSA?
    WhiteBug73
    Severna Park, MD
  16. #16
    Registered User
    Member ID
    CZCC-4044
    Join Date
    Apr 2003
    Location
    Denver
    Posts
    1,008
    Default
    Motorsport auto
    www.zcarparts.com
    short throw info
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. The Seatbelt cover Melted!
    By TomoHawk in forum Interior (S30)
    Last Post: 07-26-2011, 09:06 PM
  2. '73 fusebox problems, need help
    By gogriz91 in forum Electrical (S30)
    Last Post: 04-18-2009, 07:30 PM
  3. Melted Fuel Pump Fuse
    By kray-z-1 in forum Carburetors (S30)
    Last Post: 06-15-2006, 08:41 PM
  4. Lighting and Fusebox
    By sideshowbob in forum Electrical (S30)
    Last Post: 07-18-2005, 03:14 PM
  5. where can I get a fusebox
    By swallozgoo in forum Electrical (S30)
    Last Post: 04-04-2003, 08:00 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
