Results 1 to 12 of 12
Thread: Should my 240Z have a fan shroud?
  1. #1
    Registered User
    Member ID
    CZCC-25413
    Join Date
    Oct 2011
    Location
    Birmingham, Alabama
    Age
    58
    Posts
    111
    Default Should my 240Z have a fan shroud?
    I have a completely orignal 1972 240z that I am trying to get back on the road, (over all freshen up under way). It does not have a fan shroud. I have seen several of you guys that DO have fan shrouds. Did my car come with one and possibly lost it somewhere along the way? Do I need one?
    Thanks in advance,
    Danny
  2. #2
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    75
    Posts
    4,424
    Default
    No the 72's did not come with the fan shroud. I ordered mine over the Parts Counter when I installed the Dealer A/C kit in 72. They do aid a bit in relation to engine cooling during low speed operation.
    FWIW,
    Carl B.
  3. #3
    Registered User black gold man's Avatar
    Member ID
    CZCC-22534
    Join Date
    Sep 2010
    Location
    Detroit, Michigan, United States
    Age
    59
    Posts
    821
    Default
    The 240 came with a small shroud like this. The auto trans came with full shroud.
    The belly pan is necessary for fan cooling air flow.
  4. #4
    Registered User
    Member ID
    CZCC-25413
    Join Date
    Oct 2011
    Location
    Birmingham, Alabama
    Age
    58
    Posts
    111
    Default
    Quote Originally Posted by black gold man View Post
    Thanks guys,
    My 72 has the small "hood" shroud like the one shown. It does not have the belly pan though. Is the belly pan really needed for everyday driving?
    DT
  5. #5
    Member ID
    CZCC-22534
    Join Date
    Sep 2010
    Location
    Age
    59
    Posts
    821
    Default
    It helps with aerodynamics and cooling. One z i know of had a fire do to redbull can came up through
    the void of no belly pan and grounded the starter and it burnt bad.
  6. #6
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    54
    Posts
    1,190
    Default
    It would depend upon your weather conditions and how warm your car will tend to run. If it is consistently hot and humid there it would probably be a good idea to have a shroud and/or a 4 row radiator.
  7. #7
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    75
    Posts
    4,424
    Default
    Quote Originally Posted by dltalfa View Post
    Thanks guys,
    If your radiator has the little "finger guard" or "safety guard" it is most likely the original radiator. Most the after market replacements don't have them.
    As I recall Nissan called it a "splash guard", which might give some indication of it's original purpose. It didn't seem to provide any noticable effect on cooling on any of the 240Z's I have them on. No - you don't need it for everyday driving.
    FWIW,
    Carl B.
  8. #8
    Member ID
    CZCC-22534
    Join Date
    Sep 2010
    Location
    Age
    59
    Posts
    821
    Default
    I think Nissan meant for the hood and belly pan to act as a shroud dose on a car with more space in that area.
  9. #9
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    75
    Posts
    4,424
    Default
    Quote Originally Posted by tlorber View Post
    Agreed! If you want to keep the "stock" or "original" look of your radiator - just have it re-cored with the 3 or 4 row core, keeping your original top tank with the finger guard and bottom tank.
    All that said - the most effective items I've found to reduce engine operating temps. here in Florida are; 1) changing to synthetic oil and 2) adding Redline "Water Wetter" to the coolant.
    FWIW,
    Carl B.
  10. #10
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    I have never had a over heating problem in my 240 but I have always made sure the coolant was up to date and clean. Even my ZX engine stayed cool with the old 240 radiator in traffic at 104* temps. Now I have gone to a 280 radiator and again no problems. As to the splash pan. I am running one on my 240 and what I found years ago when I ran without it and then with it. Is it helps move the air under the car. With our the pan the car was getting light in the front at speeds above 75 mph. Now with it she is good up to a 100 to 110. Now this is with no cross or head wind. Since I rarely drive at these speeds I never mounted a front air dam. Club members that have, claim that even the BRE style eliminates this lifting period. I can see why these pans were removed and not replaced by mechanics in the past because they can be a pain to work around when lubing the front steering rack.
    Gary
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  11. #11
    Registered User Bonzi Lon's Avatar
    Member ID
    CZCC-11300
    Join Date
    Apr 2006
    Location
    Kingman, Kansas
    Age
    65
    Posts
    1,155
    Default
    The splash pan can also be a pain when removed and 5 of the 9 bolts break off!
    Bonzi Lon
    1973 HLS30-168500
    1968 SPL311-18100
    1969 HLS30-000110 SOLD Shipped to Dubai UAE
    CZCC#11300
    Ones and Zeros
    "We drive only blue cars." Dishwalla
  12. #12
    Registered User Hunter260Z's Avatar
    Member ID
    CZCC-24528
    Join Date
    Jun 2011
    Location
    Timberlake, NC
    Posts
    207
    Default
    Splash pad were standard on the 260z.Two of my bolts have broken off. I thought the fan shroud came on all A/C equipped cars.
    Ray
    1974 Datson 260Z
    RLS30-27748 Matching #'s
    L26 Stock w/72 Round Tops
    Interpart Front Spoiler
    Addco Front & Rear Sway Bars
    My Very First Car
    Purchased 5/23/1974
Thread Information
Users Browsing this Thread
Similar Threads
  1. 240z Tail Light Shroud Color
    By ksbeta in forum Body and Paint (S30)
    Last Post: 08-15-2014, 01:32 AM
  2. Need a 240z Fan Shroud
    By lm71z in forum Engine and Drivetrain (S30)
    Last Post: 06-07-2010, 12:56 PM
  3. Electric fan or new fan clutch/shroud for my 240z?
    By Jayru in forum Engine and Drivetrain (S30)
    Last Post: 07-02-2006, 11:01 PM
  4. Fan shroud for a '77
    By bobs77 in forum Engine and Drivetrain (S30)
    Last Post: 04-21-2006, 03:08 PM
  5. 240z fan shroud and splash pan
    By richard1 in forum Engine and Drivetrain (S30)
    Last Post: 02-26-2004, 09:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
