Results 1 to 4 of 4
Thread: What can new ball joints do for you???
  1. #1
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default What can new ball joints do for you???
    I just had new ball joints installed on my ZX. WOW, WHAT A DIFFERENCE.
    The old ones weren't DETECTABLY worn, you couldn't shake the wheel and say "oh, bad ball joints" even though the rubber boots were long gone. But at 200k I figured they were probably the originals....
    Driving it with the new ones --- it made a BIGGER IMPROVEMENT to the car's handling than all of the other bushings and other pieces I've replaced so far - tie rod ends, sway bar links, etc.
    The car is actually starting to drive half-way decent now! It has gone from homicidal (sway bar links & rear struts) to tempermental (tie rod ends, alignment, properly torque wheel bearings) to almost respectable (ball joints).
    I SUSPECT a fatter sway bar up front, and the prothane bushings on the rear arms are what's going to get me to home plate.
  2. #2
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Posts
    692
    Default
    To clarify, the steering wheel moves EASIER, but the steering is tighter, more responsive to smaller inputs. I used to blame the steering rack for what felt like mild binding, but apparently it was the ball joints.
  3. #3
    Registered User grantf's Avatar
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    I put new ball joints on about 2 months ago. I have not noticed much improvement at all. Since I have noticed more steering shake. I had an alignment done right after putting in new ball joints and outer tie rod ends. but there are other things I need to work over, namely bushings and a closer inspection of the rack. On the easer side I plane on a tire rotation to see how that affects things. I feel good about doing it though as the old units were in pretty bad shape.
    I guess I could say there has been some minor improvements in responsiveness but that may be overshadowed by the shakes.
  4. #4
    Registered User
    Member ID
    CZCC-22370
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5
    Default
    I've been suffering for a while with a lot of vibration in my 79 ZX. I knew the car had worn ball joints and bushings that were badly deteriorated. I just had all the bushings replaced, the rear differential mount, the ball joints and the tie rods (one of which looked like it was barely holding together).
    Huge difference in the ride and handling. There steering is tighter and even though there is no power steering it does turn easier.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Ball joints from MSA !
    By kjphilippona in forum Suspension and Steering (S30)
    Last Post: 01-20-2011, 12:06 PM
  2. Ball joints
    By Pomorza in forum Suspension and Steering (S30)
    Last Post: 11-12-2010, 09:45 PM
  3. Bad Ball Joints?
    By Jeff G 78 in forum Suspension and Steering (S30)
    Last Post: 05-22-2006, 03:20 PM
  4. Need new Ball Joints
    By lan240 in forum Suspension and Steering (S30)
    Last Post: 07-06-2004, 04:59 AM
  5. Ball Joints, etc: OEM or not?
    By AxtellZ in forum Suspension and Steering (S30)
    Last Post: 01-07-2004, 12:47 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
