Results 1 to 13 of 13
Thread: Can this be saved ?
  1. #1
    Registered User george71z's Avatar
    Member ID
    CZCC-1730
    Join Date
    Feb 2002
    Location
    Melbourne, Florida
    Age
    67
    Posts
    445
    Default Can this be saved ?
    This past Friday, I was cut-off by another driver and rear-ended a mini-van. No serious human injuries, but my beloved 71 240 was trashed. I hit the right rear of the van with my left front. Since it has been 21 yrs. since it's restoration,
    and I now have some medical problems that would limit my ability to do the work on the car that I used to; I am posting pics of the damage and some details that are not apparent in the photos; with the question; can this car be restored, or should I total it and try to sell off the remaining good parts?
    The left frame rail is mangled, the radiator support as well. The left front inner fender is trash, as well as the left door.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	55236   Click image for larger version.
ID:	55237   Click image for larger version.
ID:	55238   Click image for larger version.
ID:	55239   Click image for larger version.
ID:	55241   Click image for larger version.
ID:	55242   Click image for larger version.
ID:	55243   Click image for larger version.
ID:	55244   Click image for larger version.
    72 240-- stock motor and drivetrain, 50,500 orig. miles
  2. #2
    Registered User palosfv3's Avatar
    Member ID
    CZCC-16744
    Join Date
    Apr 2008
    Location
    chicago
    Age
    68
    Posts
    54
    Default
    It would not be practicle or cost effective to attempt to repair this damage . The left wheel is driven back into the cowl. This is an indication of the severity of the impact.
    If you remove the carpet on the drivers side you should see significant damage to firewall with a good possibility of the floor below the brake pedal being buckled.
    Larry
    www.picasaweb.google.com/wgmauto
    www.wgmauto.com
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Unfortunately, I would agree with Larry. You may want to hold onto it while you get another car to swap the parts over to. Call about the 71 advertised on Craigslist Atlanta quickly! http://atlanta.craigslist.org/wat/cto/3163713654.html
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    Registered User cbuczesk's Avatar
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    Remove the fender, hood and cowl for us. A frame shop might be able to pull a lot of that out. The radiator support, LF inner fender and LF frame rail might need to be replaced. I'd like to see more pictures before scrapping the car. It _can_ be fixed but like Larry said it might not be practical.
    Chuck
    East Coast Z Nationals held at the Carlisle Import & Kit Nationals - May 16-18, 2014 Carlisle, PA
    www.carlisleevents.com/events/import
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z ITS race car
    1972 240Z turbo
    1974 260Z turbo
    1975 280Z my first car
    1978 620 King Cab
  5. #5
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    Thankfully you were not hurt. Cars in general weren't very safe when the 240Zs were new, and cars don't get safer with age.
    Could it be saved? I don't really know without seeing the condition of the unit body. Personally I doubt that I would try, particularly if I had to pay someone else to do all the work. (Which I assume is what you meant when you mentioned that you have medical issues that would preclude doing the work yourself.) But that is just my opinon.
    '71 240Z, Because any fool can drive fast in a straight line.
  6. #6
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    You would have to want that car saved- and find a healthy doner. I have seen worse damage repaired-somewhere I have pictures...
    Will
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  7. #7
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    75
    Posts
    1,334
    Default
    We're all sad about this. I lost 721 in March. Yours appears to be rebuildable, though. Best of luck to you.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  8. #8
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    It all depends on how far rearward the damage went. My '78 was hit before I bought it and I had the whole left front corner cut off and replaced. It wasn't as bad as yours an it had already been pulled, but I decided to cut and replace. It is now straight and solid. These pics are scans from 20+ years ago, so they are a bit small an grainy.
    Here it is with the bent steel cut out
    Here is the donor inner fender, strut tower and rail
    And here it is after welding and painting
    Here is it after reassembly
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  9. #9
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Ouch! Glad you're OK, save it for a donor for another build, you've probably got a ton of good parts, engine, etc. that can be used and at least the inspection lid is still good.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  10. #10
    Member ID
    CZCC-1730
    Join Date
    Feb 2002
    Location
    Melbourne, Florida
    Age
    67
    Posts
    445
    Default
    Got news today that insurance is declaring it a total. I asked about buying it back, with a salvage title. Will find out tomorrow. I will probably look for another early Z that has been 'finished' and make it my own. Hopefully I can part out this one. As it is now, the left front and door are the damaged areas, (including the frame rail) Everything else is perfect. We'll see what happens.
  11. #11
    Registered User MotoManMike's Avatar
    Member ID
    CZCC-26581
    Join Date
    Feb 2012
    Location
    Maryland, Eastern Shore
    Age
    39
    Posts
    173
    Default
    I would say in your situation i'd find another car if you aren't too attached to driving it. Almost anything can be fixed but it costs. It would be nice to keep for parts though. Jeff thats a nice repair on your 78, came out good. Not many make it back on the road after a bump like that. Like you said you have to want it fixed... Glad everyone was ok.
  12. #12
    Member ID
    CZCC-1730
    Join Date
    Feb 2002
    Location
    Melbourne, Florida
    Age
    67
    Posts
    445
    Default
    Well, got the news today that they will let me buy it back (salvage title), but they want to reduce my payout by $4,000. Seems a little high. Has anyone else bought back a totalled car from their insurance co.? Can the buyback be negotiated somehow? What do ins. co.'s usually do in cases like this? Do they send the car to be stripped for parts (i.e. sell to Zcar source in Az.) or is it simply crushed? I will call my adjuster tomorrow and ask some questions, but if anyone has any experience with this situation, I would be most appreciative.
  13. #13
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Pretty sure that your car would end up sold to a wrecking yard, where the ins. co. would get about $200 for it. Everything is negotiable, especially with insurance companies. I think that they're starting way high to try and save the most money on the payout. You could buy another 71 that runs and drives for $4000.
    Don't forget also that the car will have a salvage or reconstructed title if you try to put it back on the road. That will lower its resale value dramatically. $4000 seems like way too much to me, I'd offer $500. The insurance company will do the math and if they come out ahead they'll take the money, and move on to the next claim. No way they're going to get $4000 from any salvage yard, they're trying to bleed you.
    That's just my opinion though, the last car I bought back from the insurance company was a 1967 Chevy pickup, in 1984, for $300, after I got the payout from the ins. co. of the guy that hit me. But it was a work truck and ran fine after I put a new radiator in it, so it was a no-brainer.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Blue saved my sanity for another day
    By siteunseen in forum What I Did Today
    Last Post: 03-26-2012, 07:25 AM
  2. Can it be saved?
    By mbarjbar in forum Engine and Drivetrain (S30)
    Last Post: 05-04-2009, 09:44 AM
  3. 280z saved from the crusher
    By boggie36 in forum Help Me !!
    Last Post: 07-17-2007, 05:33 PM
  4. Another 280z saved ...
    By 280z1975 in forum Introductions and Z Stories
    Last Post: 12-30-2005, 05:36 PM
  5. saved a z needs yoour suspension help
    By mtdripo in forum Suspension and Steering (S30)
    Last Post: 01-17-2004, 08:17 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
