Results 1 to 4 of 4
Thread: ZX Body Question --- Where does the rain drain in Spain?
  1. #1
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default ZX Body Question --- Where does the rain drain in Spain?
    The little "grille" underneath the windshield wipers, which admits fresh air to the HVAC system and contains the wiper "transmission."
    How or where does that drain rain away? To the sides, or are there drain tubes which might be clogged?
    I'm getting wet carpets, the leak APPEARS to be under the dash near the steering column, and it does NOT seem to be the windshield seal.
  2. #2
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    They drain to the sides-take of the grill and inspect what is in it-could be related the cabin air intake(very common on the S30)or your wiper system attachment points. If you don't find the obvious, check out your upper hood seal(frequently removed/unintentionally manipulates)-and door seals, and the entire Windshield moulding(many ZXs have openings from rust in this area)-water can get to the carpet several ways
    If you still don't find it, One dark night(or anytime in your dark garage) when everything is dry take the cowl grill out and put a bright drop light in the hollow it covers, disconnect the battery-or your interior light bulbs-then stick your head in the footwell and look for the light under the dash. It may not shine right in your face, but odds are something under there will be at least a little lit up and give you North Star to follow to your leak.
    Will
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  3. #3
    HS130-150591 4/79 zbane's Avatar
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    47
    Posts
    1,671
    Default
    Check all the rubber grommets that pass through the firewall (tricky to get to the ones behind the slave cylinders). Odds are you'll find one (or more) cracked-though a cursory visual inspection may not show faults. (I'm speaking from experience here)
    David
    _____________________________________
    HS130-150591, April, 1979-280zx
    2001 Infiniti I 30
  4. #4
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Posts
    692
    Default
    Thanks for the good ideas.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Body/interior question
    By mlaw7 in forum Open S30 Z Discussions
    Last Post: 12-27-2009, 12:21 AM
  2. Body Bolts Question
    By Aguyandaredhead in forum Body and Paint (S30)
    Last Post: 08-11-2008, 11:05 AM
  3. Fancy a trip to Spain via France?
    By Caen Fred in forum Europe
    Last Post: 02-23-2005, 02:50 AM
  4. Spain
    By ChrisA in forum Open Discussions
    Last Post: 03-16-2004, 07:45 AM
  5. Anyone in Spain?
    By derk in forum Open Discussions
    Last Post: 02-27-2003, 06:18 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
