Results 1 to 23 of 23
Thread: bought a 71 datsun 240z and i dont know anything about carbs
  1. #1
    Registered User
    Member ID
    CZCC-24971
    Join Date
    Aug 2011
    Location
    socal
    Posts
    11
    Default bought a 71 datsun 240z and i dont know anything about carbs
    Hello, i bought a 71 datsun 240z that has a l26 with i believe su carbs on it, and a 5 speed in it. I noticed today that there seem to be a couple of vacuum hoses that are either just open or plugged, i took some pictures to see if it helps someone figure this out. I hooked up the vacuum control on the distributor but really didn't notice any difference in the change of idle. The car is idling between 1000-1200rpm's after warm up, im not sure if thats normal or not. Also the car seems to be running really rich. also, is there a good manual that i can buy for this car that someone can recommend. Thanks for the help in advance.
    Thanks,
    Albert
  2. #2
    Formerly known as Koalia Reverend's Avatar
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default
    First of all, welcome to the club! Secondly, check out the SU-carbs section in this forum and use the search function, there is tons of info here for you to find. It seems you are missing the tube from front carb to distributor, it suppose to be attached on the manifold side of the carb. Other 2 tubes from the carbs supposed to be attached to original style airbox.
    Btw. you have exactly the same coil as i do
    -72 240Z "Goldie"
  3. #3
    Registered User olzed's Avatar
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Auckland. New Zealand.
    Age
    76
    Posts
    1,069
    Default
    Hi Albert.
    Koalia is correct. There should be a vacuum hose from the inlet manifold to the distributor.
    Where does the hose in the last picture come from? If it comes from the inlet manifold, then remove the bolt, and determine if there is suction there with the engine running.
    If it doesn't, then attach a hose from the unused fitting near the centre of the manifold to the dizzy.
    Idle should be 7-800 RPM or thereabouts.
    Haynes put out a good book---DATSUN 240z & 260Z OWNERS WORKSHOP MANUAL. Lots of good reading there.
    Your engine has carbs from a 240Z, which will run well. Someone has swapped in a 260 and put 240 carbs on there. Originally 260 was fuel injected.
    Hoses from the carbs are merely breathing tubes, and as Koalia said were plumbed into the air cleaner box.
    Tie them away from the exhaust, and shorten them a bit if you want.
    Brian.
  4. #4
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    The 260 was fuel injected? I thought it had flattops?
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  5. #5
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Nz .
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  6. #6
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Quote Originally Posted by Zedyone_kenobi View Post
    The US 260Z used flattops. It was not fuel injected from the factory.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  7. #7
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    There were two different 260's in North Am. Early one with flat top carbs like 73 240 (though not identical), skinny bumpers with hydraulic shocks, and then a later one with FI like 280 and bumpers like the 75 280. The interiors for both were the new 280 style dash and console. Real Heinz 57.... No wonder folks restoring 260's have a devil of time finding parts for them!
    Nice Z BTW. I like the red wire that comes through the firewall at the choke cable grommet and goes to the coil best. I'm pretty that's not stock... and worth understanding what it bypasses (like the ignition switch....).
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  8. #8
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    We sell a dvd that will help shorten your learning curve on the Hitachis (SUs made under license for the Japanese makes). You could for very little money go through them, clean 'em up and get them running in some known state to see what you really have.
    JUST SUs ZTV09 for twenty five of your hard earned dollars.
    Whatever you do don't plug the hoses that come off the top of the float bowl lid. Those need to be open to the atmosphere. Is there anything hooked to the vacuum advance canister on the distributor? Are you running a points distributor of and electronic distributor. If you are running an electronic distributor and there is no vacuum advance hooked up at the canister it may be because the EI Dist was over advancing with vacuum hooked up..
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  9. #9
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Quote Originally Posted by zKars View Post
    Late 260Z in the US still had flat tops. Not FI. That was actually the probable reason for the late 260Z - the fuel injected L28 wasn't ready yet, so the late 260Z was the rest of the 280Z package but still using the carbed L26.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  10. #10
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Download the FSM from the "Reference" section of xenons30.com, everything you need is in there. The Haynes book is woefully underwhelming.
    2/74 260Z
  11. #11
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I prefer the FSM over the Haynes manual.
    Europe, Aus, NZ and South Africa never saw the 280Z. They just went further with the 260z and FI until the 280ZX. The 280z came out to try to combat the extra weight due to the heavy bumpers and the tougher emision regulations in CA.
  12. #12
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Age
    76
    Posts
    1,069
    Default
    Oops, late night brain fade. I was thinking of the Fairlady 2000 JDM private imports we got down here. I have seen flat top carbs and fuel injection on them.
    Depending on the year I suppose.
    I actually got up at 1am to try to edit that, but was unable to connect. More brain fade perhaps.
  13. #13
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Arne, thanks for the clarification. All 260's were flat top carbed. No FI. thanks!
    Jim
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  14. #14
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    Hi Albert:
    First - as others have mentioned - a 240Z Factory Service Manual is the best thing to have.
    Second.
    See this picture - you can see where the vacuum hose hooks up for the distributor vacuum advance.
    http://becksystems.com/KellyW/162KellyW.jpg The vacuum advance on the distributor uses Ported Vacuum just behind the Carb - ahead of the intake manifold.
    Third - the hose off the top of the Carb Float Bowls is a vent - it would normally hook to the stock Air Cleaner - but as I recall the aftermarket round cleaners have a hole in the back of them for a connector. I wouldn't suggest venting the float bowls toward the exhaust manifold.
    Fourth - the last picture shows a line from the Gasoline Vapor Emission Flow Control Guide Valve - that used to run to the Stock Air Cleaner - that line lets fresh air into the system, to allow heavy gasloine vapors to get out of the cannister in the rear of the car - - - Unplug that and leave it open. No need for the hose if it isn't connected to an air cleaner
    Fifth - the vacuum ports on the Balance Tube - between the Carb's - should be properly sealed off if not used.
    Post some pictures of the rest of the Z - and tell us why you bought it to begin with.
    FWIW,
    Carl B.
  15. #15
    Registered User
    Member ID
    CZCC-24971
    Join Date
    Aug 2011
    Location
    socal
    Posts
    11
    Default
    Quote Originally Posted by Koalia View Post
    Thank you, and will do. I hooked up the distributor vacuum to the carb manifold but I didn’t notice any change in anything.
    Quote Originally Posted by olzed View Post
    Hi Albert.
    Brian.
    Hello, I unplugged it but there is no vacuum or air coming out. It seems to be coming from this blue tube that’s connected to the block. I’ll be getting a haynes book then, thanks. I got the idle down to 950rpm but any lower and the car shuts off.
    Thanks for the heads up, I’ll look into it. This car came with a push start button, but I want to uninstall that.
    Quote Originally Posted by LeonV View Post
    I’ll go ahead and do that, thanks.
    Quote Originally Posted by Bruce Palmer View Post
    I’ll go ahead and order one today, thanks. There wasn’t anything hooked up to the vacuum advance canister but I hooked it up to the carb manifold but didn’t notice any change. I’m not sure if this picture will help with your question but here it is.
  16. #16
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    74
    Posts
    4,424
    Default
    Second Picture from the last at Post #15 - the Top hose on that Flow Control Valve should go to the Air Cleaner or be left open - it draws in fresh air. The Bottom hose goes to the Crankcase Vent... the flow control valve directs gasoline vapors to the crank case - where they are sucked back into the intake manifold by the PCV valve.
    FWIW,
    Carl B.
  17. #17
    Registered User
    Member ID
    CZCC-24971
    Join Date
    Aug 2011
    Location
    socal
    Posts
    11
    Default
    Quote Originally Posted by Carl Beck View Post
    Hi Albert:
    Second.
    FWIW,
    Carl B.
    Thank you, that picture was very helpful. ill check later for the hole in the carb filters. As far as the line from the Gasoline Vapor Emission Flow Control Guide Valve, would it be ok if i found a way to hook that up to the carb filter, or should i just leave it alone and unplug it.
    Ill take a picture of it later and post it but i have to warn you, it needs a lot of work, but at least it runs. Im 26yrs old now and i first saw one of these cars when i was about 8yrs old, i remember it looked so cool, after that i never saw another one again. I sold my 03 Z06 a couple of days ago so i can use that money for a down payment on a C6 Z06 but i couldnt resist, so i picked up this little thing as a project so i can restore it to its former glory.
  18. #18
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    74
    Posts
    4,424
    Default
    Quote Originally Posted by 03redzo6 View Post
    Thank you, and will do. I hooked up the distributor vacuum to the carb manifold but I didnít notice any change in anything.
    You shouldn't. At idle there is no need for vacuum advance in the distributor. You should feel vacuum on that line if you open the throttle and run the engine at higher RPM's. Vacuum Advance should advance the timing under load and back off at cruise or steady RPM's.
    [QUOTE=03redzo6;412327]Hello, I unplugged it but there is no vacuum or air coming out. It seems to be coming from this blue tube thatís connected to the block. [QUOTE=03redzo6;412327]
    That Blue Tube is the Crankcase Vent - the small tube on it - should be hooked to the bottom line on the Flow Control Valve. It is there to suck gasloine vapors into the crankcase.
    FWIW,
    Carl B.
  19. #19
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    I second everything that Bruce said. Maybe I am dense, but I couldn't get my head around the SU until I saw the video.
    '71 240Z, Because any fool can drive fast in a straight line.
  20. #20
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    74
    Posts
    4,424
    Default
    Yes - it would actually be best if hooked to the carb air cleaner. If not - it at least has to be open to draw in fresh air.
    I'm sure that you will enjoy the Z - they are fun to drive and very easy to work on. Once they are in proper condition - they are very reliable as well. Not to mention that they are always beautiful to look at.
    FWIW,
    Carl B.
  21. #21
    Administrator bpilati's Avatar
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    60
    Posts
    1,483
    Default
    [QUOTE=Carl Beck;412338]You shouldn't. At idle there is no need for vacuum advance in the distributor. You should feel vacuum on that line if you open the throttle and run the engine at higher RPM's. Vacuum Advance should advance the timing under load and back off at cruise or steady RPM's.
    [QUOTE=03redzo6;412327]Hello, I unplugged it but there is no vacuum or air coming out. It seems to be coming from this blue tube that’s connected to the block.
    FWIW,
    Carl B.
    Carl, why would you want to suck gasoline vapors INTO the crankcase?
    Bryan Pilati
    1971 Datsun 240Z (8/71; 920 paint)
    IZCC #583; TZCC #16; CZC #110
    I'm never serious unless I should be.
  22. #22
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    74
    Posts
    4,424
    Default
    Personally I wouldn't want to. However as part of the Gasoline Vapor Emission Control System - gas vapors from the tank are collected in that cannister behind the Right Rear Quarter. That cannister is there to allow the vapors to condense back into liquid form when they get dense enough. The vapors that remain are sent up to the engine compartment - to that Flow Control Valve. They are sucked into the crank case when there is a negative pressure there - then redirected to the intake via the PCV system - to be sucked into the combustion chamber. So the crank case is just a place to suspend them until they can be put back into the combustion process.
    This was all originally part of the California emissions control regulations - but soon became part of the Federal Standards.
    Give a bureaucrat an inch and they will always take a mile and demand more. They can not ever let their job be DONE.
    FWIW,
    Carl B.
  23. #23
    Registered User
    Member ID
    CZCC-26741
    Join Date
    Mar 2012
    Location
    El Paso
    Age
    35
    Posts
    64
    Default
    FWIW,
    Carl B.
    So if you aren't worried about emissions, you could rip all that stuff out and just plug the vent tube @ the tank?
    Current:2011 370Z 6mt with simple mods
    Starting my 240Z project
Thread Information
Users Browsing this Thread
Similar Threads
  1. Just bought '72 240Z. Using a lot of gas?
    By austinramsay in forum Engine and Drivetrain (S30)
    Last Post: 01-07-2012, 10:13 AM
  2. Bought my 240z a makeover =)
    By BTF/PTM in forum Open S30 Z Discussions
    Last Post: 07-14-2010, 07:36 PM
  3. bought a 240Z need info
    By troubledz in forum Introductions and Z Stories
    Last Post: 10-23-2006, 06:42 PM
  4. Just Bought a 240Z Need Info
    By W.A.ZED in forum Open Discussions
    Last Post: 01-13-2003, 11:16 PM
  5. Just bought 240z
    By Hallaian42 in forum Open Discussions
    Last Post: 07-29-2002, 06:08 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
