Results 1 to 12 of 12
Thread: AFM to Throttle body hose
  1. #1
    Registered User
    Member ID
    CZCC-28433
    Join Date
    Oct 2012
    Location
    Tahuya, wa
    Age
    51
    Posts
    6
    Cool AFM to Throttle body hose
    New guy here so please be kind. Just got a 79 280zx for FREE. I noticed it has a crack all the way through the rubber boot between the mass air flow to the throttle body. No new part available, can't find one used. I don't have much money right now but would like to buy a used rather than repairing mine. Any idea's????? Thanks Mike
    The 79 and 80 share the same hose nissan P/N# 16578-p7100
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Can you make it over to Index, WA? http://seattle.craigslist.org/sno/pts/3305270485.html
    And, I'm not sure if the hose will work, but there's a 77 in Lynnwood - http://www.picknpull.com/check_inven...0&Distance=200
    You could also post here - http://www.datsunclassifieds.com/
  3. #3
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    You can also try NissanPartsZone
    http://www.nissanpartszone.com/Page_...mponentsNo=165
    They have is for $28.72 aftermarket.
    I made a couple of screen shots. You can order on-line.
    Sucess.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	57379   Click image for larger version.
  4. #4
    Registered User
    Member ID
    CZCC-28433
    Join Date
    Oct 2012
    Location
    Tahuya, wa
    Age
    51
    Posts
    6
    Default
    Quote Originally Posted by EuroDat View Post
    Sucess.
    Already chatted with them it is obsolete.
  5. #5
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    You could also give your local Nissan dealer a try.
    Part no. 16578-P7100. I ordered other parts for the intake on a 280Z 1977 no problems and not to much price difference with nissanpartszone.
    Goodluck searching
  6. #6
    Registered User
    Member ID
    CZCC-28433
    Join Date
    Oct 2012
    Location
    Tahuya, wa
    Age
    51
    Posts
    6
    Default
    Goodluck searching
    My local Nissan dealer says it is obsolete and no dealers across north america has this hose in stock.
  7. #7
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    You could try the hose for the 280zx 1980 model. You will need to block the extra side hose nozzle. MSA sell them, I think.
    Looks like your model is no longer stocked. Could be because it change over to the 1980 model soon after intro and therefore too little demond nowdays.
    I could order mine, for a 280Z 1977 model here in the Netherland last june no problems. Thats another type again. MSA
    Check MSA. They list them all, but yours is no longer available. http://www.thezstore.com/page/TZS/CTGY/SFC03A
  8. #8
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    They're all over e-bay, if I'm reading right or left to right.
  9. #9
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Expensive, but available - http://www.datsunstore.com/index.php...air-cleaners-4
    If I was in your boat I would go to Home Depot and look at plumbing adapters and vacuum hoses and cobble something together.
  10. #10
    Registered User
    Member ID
    CZCC-28433
    Join Date
    Oct 2012
    Location
    Tahuya, wa
    Age
    51
    Posts
    6
    Default
    Found a NOS updated part on Ebay. It coveres 77-80 z cars. thanks everone for your help.
  11. #11
    RAREZX ZXR616's Avatar
    Member ID
    CZCC-23146
    Join Date
    Dec 2010
    Location
    Macon GA
    Posts
    33
    Default
    You've probably found a cure for your prob, but...
    I had the same problem, a torn boot. Like you, I could not find a replacement, so I "engineered" it.
    I cleaned the area of the tear with acetone. I super glued as much of the tear as possible (maintaining the original shape). Then I coated the area (inside and out) with liquid rubber.
    Ta-Da...it worked!!!
  12. #12
    Registered User
    Member ID
    CZCC-22370
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5
    Default
    Same problem here on my 79. I got it free from my dad. There were a lot of older parts that needed replacement so I just used duct tape as a temporary fix. Ended up ordering one from zcarsource.com
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Throttle body ?
    By mjr45 in forum Fuel Injection (S30)
    Last Post: 01-11-2011, 08:02 AM
  2. Throttle body ?
    Last Post: 01-10-2011, 03:22 PM
  3. Throttle body
    By mholmes in forum Help Me !!
    Last Post: 10-09-2006, 11:48 AM
  4. 77 FI throttle body??
    By gator in forum Fuel Injection (S30)
    Last Post: 10-27-2005, 02:47 PM
  5. Throttle body
    By 1wildzer in forum Open Discussions
    Last Post: 09-11-2002, 12:50 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
