Results 1 to 13 of 13
Thread: n-42 Carburated Head
  1. #1
    Registered User
    Member ID
    CZCC-19951
    Join Date
    Aug 2009
    Location
    Ventura, CA. 93004
    Posts
    58
    Default n-42 Carburated Head
    Hello,
    I was under the impression that n-42 heads were only used on 75-76 280z's with EFI.
    I came across one which was not drilled for injectors and expressly for use with carburators.
    Which vehicles were these made for?
  2. #2
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I have never seen a datsun head drilled for injectors. They all use the manifold to mount the injectors.
    The N42 heads came out on the 75 - 76 280Z in the 48 states without catalytic convertor and using leaded fuel.
    As far as I know it only came with EFI. A po may have changed it over to SU's
  3. #3
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    I am currently running an N42 head with carbs. I think they were drilled for both a carb and a FI manifold.
    N42 head right there.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  4. #4
    Registered User
    Member ID
    CZCC-19951
    Join Date
    Aug 2009
    Location
    Ventura, CA. 93004
    Posts
    58
    Default
    I think I misunderstood the seller. I will ask him what he meant by "a carburated n-42 head". It 's been a little while since I saw the piece in question and I cannot remember any details.
    As always, thanks for the input...
    BTW Zedyone, sweet engine and compartment....
  5. #5
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    The N-42 heads have the threaded holes for mounting carburetors AND the notch in the intake for the injector tip. The injectors are mounted in the intake manifold and stick through in to the top of the head's intake port. So you can use EFI or carbs on the N-42 for sure, maybe on the N-47 also, not sure there.
    Apparently, in other non-domestic markets carburetors were used for quite a while after EFI was introduced in the states. I think that the big driver for EFI was the emissions regulations in the US market.
    1976 280Z, with some minor modifications
  6. #6
    '75 280z tamo3's Avatar
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default
    Click image for larger version.
    I think dhp123166 is talking about intake drilled for injector tips.
    Maybe the head is modified and filled the injector tips hole for intake port.
  7. #7
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    60
    Posts
    1,374
    Default
    I've had a couple N42 heads that were cast without the injector reliefs and were drilled only for carb manifolds. Don't know what Nissan application there were used on but both came on N42 blocks.
  8. #8
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Imported maybe? I recall a post from Hybridz, ozconnection (from Australia) had an N42 head with no notches. Post #59 - http://forums.hybridz.org/topic/6269...iptions/page-3
  9. #9
    Registered User
    Member ID
    CZCC-19951
    Join Date
    Aug 2009
    Location
    Ventura, CA. 93004
    Posts
    58
    Default
    Quote Originally Posted by John Coffey View Post
    I was back at the owners place today and this is the head it was, an N-42 w/out the injector reliefs.
    I still didn't buy it ha!
  10. #10
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    The N42 was used in Europe, SA and Australia/NZ with carbies on the 260Z until the 280ZX in 1979. They also used leaded fuel. It could be a import head.
  11. #11
    Registered User esmit208's Avatar
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    308 Palmetto Avenue Melbourne Florida 32901
    Age
    61
    Posts
    464
    Default
    Quote Originally Posted by Zedyone_kenobi View Post
    That Baby looks SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET ZED!
    "HAPPINESS"....isn't just around the corner......"HAPPINESS"....is the CORNER"
  12. #12
    Fumblin'Bumblin Z car fan
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    50
    Posts
    111
    Default
    I am currently about halfway done with my N42/L28 build - 10:5.1 flat top, with SU's. my N42 has no capacity to accept FI. I will upload pics when I get home.
    My build - motor above, .280 cam
    5 speed from 80 ZX
    4.11 R180 open
    MSA suspension (tokico) 1" drop, 3/4" sway bars
    I am hoping for around 200HP, hoping for stinkin quick more than 200HP.
  13. #13
    1980 Datsun 280zx 2+2 mazingerz1976's Avatar
    Member ID
    CZCC-8482
    Join Date
    Jun 2005
    Location
    Bogotá-Colombia
    Age
    44
    Posts
    117
    Default
    Old thread but I wanted to add some info. N42 carburated heads were used in the Datsun 280C, or Cedric 430.
    Camilo Monroy L.
    1980 280ZX 2+2
    1982 Bluebird 910 hardtop
    1973 260C hardtop
Thread Information
Users Browsing this Thread
Similar Threads
  1. Block head causing head block
    By Ttiger in forum Engine and Drivetrain (S30)
    Last Post: 05-25-2012, 04:54 PM
  2. Head or not to head...that is the question
    By studioti in forum Exhaust (S30)
    Last Post: 04-23-2012, 11:54 AM
  3. Turbo Carburated?
    By FairladyZS30 in forum Engine and Drivetrain (S30)
    Last Post: 06-02-2007, 04:19 PM
  4. P90 Head
    By MC75Z in forum Engine and Drivetrain (S30)
    Last Post: 02-28-2007, 09:15 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
