Results 1 to 36 of 36
Thread: Coilovers and brake question
  1. #1
    Registered User tez240k's Avatar
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default Coilovers and brake question
    How do you think these would go?
    http://item.mobileweb.ebay.com.au/vi...id=14494925318
    I was given supposed s13 coilovers to transfer to mine but I went down to datsport and they told me the ones I have wouldn't fit...
    Has anyone done a coil over conversion and is it difficult. I have the larger diameter 240k brakes. So was looking at the hilux/magna setup. I've read a couple threads on it but none were a straight answer on what caliper and disk off what model etc.
    Cheers
    Terry
    76' 240K - full resto project
  2. #2
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    yeh s13 wont fit because of different nuckle design. i bought a otomoto sleeve kit but haven't done anything to it yet
    Wanted: Hardtop interior pieces
  3. #3
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    It was meant to be just the threaded sleeve but still didn't fit.
    I'm keen to try a sleeve kit seems like a cost effective coilover. But I'd like to upgrade brakes too
  4. #4
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    you can get a rx7 conversion adapters with vented disk to suit for around 20ishk of yahoo and the calipers can be had here for 100~200. this is the path im goin but you need at leat 7.5 j wheels but can run 14's still unlike some other conversions
  5. #5
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Quote Originally Posted by tez240k View Post
    Cheers
    Terry
    http://noddle.clanteam.com/Front%20D...ade/index.html
    Datsun 240K
    Turboed L24, Megasquirt II, EDIS
    Current project
  6. #6
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    They look good nod, what are the details of your upgrade?
  7. #7
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Hi,
    You will need the 240K late-model struts (1975+ ?)
    1994 Toyota 4 Runner Calipers - S13WB type - suits 25m disc - 4 x 45mm pistons ( pads are dba 1149 )
    Mitsubishi Verada / Magana disc (dba part no. 425), center hole needs to be enlarged from 69mm to 73mm, mine were blank slotted rotors - specially ordered
    Use a 2mm washer between caliper and mounting ears on struts, to move the caliper inbound a small amount ( to clear my mags )
    there is a spacer between the rotor and hub, I think it was a 3.4mm
    I'm running a 7/8 master cylinder, with a larger booster than what was on the coupe, it's off a '73 4 door 240K, but is smaller than what on a 4 door '77 240K,
    The peddles feels good..
    I think that was all..
    Nigel
    Datsun 240K
    Current project
  8. #8
    Registered User fraz's Avatar
    Member ID
    CZCC-18420
    Join Date
    Dec 2008
    Location
    Tasmania
    Posts
    70
    Default
    Sorry to butt into the conversation but I also have a question relating to suspension setup also.
    Does anyone know if this setup will fit, or how much modifying it would need, is to suit a datto 1600.
    Front - height adjustable coilover kits with king springs, vented rotors, 4 pots, braided lines, camber tops, adjustable lca's, caster, heavy duty sway bar.
    Rear - Seam welded rear cross memeber, heavy duty rear sway bar, disc brakes, lowered springs and kyb struts.
    A bit of it is maddat stuff apparently need to find more info out, but if means need to change too much I won't go down this path.....
    Cheers!
  9. #9
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    Does anyone know if the 'anti rattle' clip and other brake pad clip come with new pads, because I noticed my pins are held in with bits of wire...
  10. #10
    Registered User
    Member ID
    CZCC-23866
    Join Date
    Mar 2011
    Location
    Brisbane Australia
    Age
    30
    Posts
    108
    Default
    They always have for me..
  11. #11
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    What other cars do the sumitomo brakes come off as I need 1 more caliper
  12. #12
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    Z's i think and maybe 200b's?
  13. #13
    Registered User Mastadd240K's Avatar
    Member ID
    CZCC-11978
    Join Date
    Jun 2006
    Location
    Melb, Victoria AUS
    Posts
    482
    Default
    I know 80's 200B's are Girlock
    Shannons 2014 Skyline Nationals :https://tinyurl.com/mcrtqux (ClassicZcars Thread)
  14. #14
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    The feed comes out a different spot on the sumi caliper which means the stock weird s shape Brake line doesn't fit. Needs pretty much 2 90s which I made a template out of wire. Was thinkin to take it to a brake place and get 2 made up?
    That what everyone else does?
  15. #15
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    ok i just read that VT v6 calipers are a direct bolt on to the 240K strut?? that would seem alot easier and i can get a pair of them for nothing quite easily! this true?! or sumitomos still better?
  16. #16
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    wonder what wheel clearance is like
  17. #17
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    They look pretty big. I'll grab one this week and try a 14 inch rim.
    I can't see te offset just lining up perfectly. Will find out tho
  18. #18
    Member ID
    CZCC-11978
    Join Date
    Jun 2006
    Location
    Melb, Victoria AUS
    Posts
    482
    Default
    yeah i have a set with Commo calipers on them, would assume you would need 15's at a minimum.
  19. #19
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    yeh im guessing 15's. what disked is used for the conversion?
  20. #20
    240Krazy! Adzmax's Avatar
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Surly the Sumitomo's are a nicer caliper?
  21. #21
    Member ID
    CZCC-11978
    Join Date
    Jun 2006
    Location
    Melb, Victoria AUS
    Posts
    482
    Default
    the commo ones Weigh HEAPS alot of un-sprung weight.
    ill get a photo tonight when im back at my parents
  22. #22
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Similar to 32 GTR Sumitomo's, pretty sure it's 16" rims to fit the caliper and disc.
  23. #23
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    Is 16" the smallest you can go on R32 suspension parts?
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  24. #24
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    type m calipers and u can go 15's i'm certain. will have a look around
  25. #25
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    Bit off topic, but putting the lower control arm on, do you just place the big bush in the crossmember and slide the spindle through? No washer between bush and crossmember?
    Just seems to be tight, like it doesn't freely move up and down easily. I'm greasing all the nolathane with molygrease
  26. #26
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    does this help
  27. #27
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    it certainly does mate cheers! one thing tho, would you be able to tell me what #19 is?
    putting this car back together i need one of these cd's!
  28. #28
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    Is that a workshop manual on CD?
    Adam
  29. #29
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    #19 tension rod bush. whiteline~super pro sell it I'm pretty sure
  30. #30
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    Hmm just looks odd. I've got nolathane bushes. I thought you have a bush on each side, the pin in the centre, two washers and a nut? But looks like there's something else
  31. #31
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    wil upload the next page for you
  32. #32
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
  33. #33
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    yeh I have c10~c110 manuals from varies years on cd
  34. #34
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    Pm'd you
  35. #35
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    41
    Posts
    186
    Default
    Any word if they are interchangeable?
  36. #36
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    33
    Posts
    211
    Default
    nah not too sure. from what i read you still need to run the thicker disk with them. But i ended up picking up a set of struts with sumis and new shock inserts
Thread Information
Users Browsing this Thread
Similar Threads
  1. Brake question
    By Tim B. in forum Wheels, Tires and Brakes (S30)
    Last Post: 06-15-2012, 06:42 PM
  2. Brake question
    By trforfun in forum Open S130 ZX Discussions
    Last Post: 01-07-2011, 08:46 AM
  3. Coilovers question
    By i3rfnp3 in forum Suspension and Steering (S30)
    Last Post: 07-22-2007, 02:07 PM
  4. Question about installing coilovers
    By speedyblue in forum Suspension and Steering (S30)
    Last Post: 09-12-2005, 08:25 PM
  5. brake question
    By bart in forum Wheels, Tires and Brakes (S30)
    Last Post: 08-03-2003, 07:31 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
