Results 1 to 29 of 29
Thread: Dome LED Light
  1. #1
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Unhappy Dome LED Light
    So I'm trying to replace my dome light with LEDs. *I check the LEDs on the battery and a nice bright light. So up at dome wires I check and get 12 V. but when I hook up the LEDs to the dome wires I get a real dim light.
    78 Z
  2. #2
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    56
    Posts
    631
    Default
    Perhaps the ground is bad. The power (+12V) is constant to the dome light. The ground is made when you open the door. Check the switches in the door jambs.
  3. #3
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    I have I'm stumped. All the switch are working fine.
  4. #4
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Polarity? Try turning the bulb around.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  5. #5
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    I have try that.
  6. #6
    Registered User
    Member ID
    CZCC-24552
    Join Date
    Jun 2011
    Location
    kona hawaii
    Age
    59
    Posts
    481
    Default test the voltage
    test the voltage at the dome light. try wiggling the door switches around see if light gets brighter momentarily. i've had corroded switches
    that did that
  7. #7
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Might you be checking the LEDS one at a time on the battery and all wired up at the dome light? If so check your wiring-you possibly have series where you should have parallel-or viceversa!
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  8. #8
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    I have check the light in series on the battery and nice and bright. Get 12 v on the dome wires, door switch works fine. I'm stumped
  9. #9
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Corrosion in the switch in the dome light or on the contacts?
    disconnect battery then measure resistance to ground through the circuit to see where the problem is.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  10. #10
    HLS30A 17574 djwarner's Avatar
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    Voltage is potential - not power. If there is a high resistance (compared to a light bulb) in the circui, it might be inconsequential to the very high resistance in your meter. This results in a very small voltage drop as read by your meter. When you insert a bulb, this resistance appears huge and drops a lot of voltage.
    Don't measure ohms, measure voltage across the socket contacts with the bulb out and then in. If there is a serious drop in voltage when you insert the bulb, you have high resistance somewhere in the circuit.
    As others have said, automotive LEDs usually only work mounted in one direction. First check is to reverse the mounting to see if things get better or worse.
    One last thing, I replaced the Malibu lamp bulbs with automotive LEDs. Found the cheap contacts in the lamps and cheap contacts in the Chinese LED didn't always make good contact. You may have the same situation and may have to scuff the contacts with some fine sandpaper to get a good contact.
    1971 240Z HLS30A 17574 L24-021025
  11. #11
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    I'm losing all the power when I plug in the LEDs. Could it be a amp drop because of corrosion?
  12. #12
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    Exactly, did your bulb work before you tried the LED? First place to look is corrosion in the door switches. These switched supply a ground to the circuit. Try opening each door, snapping the nylon button a couple times and then twisting th button while it is fully extended.
  13. #13
    Registered User esmit208's Avatar
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    308 Palmetto Avenue Melbourne Florida 32901
    Age
    61
    Posts
    464
    Default
    My plan is to intall the ZX map light where the 240Z dome light goes. I always liked the swivel aspect.
    "HAPPINESS"....isn't just around the corner......"HAPPINESS"....is the CORNER"
  14. #14
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    Yes the stock dome light work before I put the LED.
  15. #15
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    If you can insert the old bulb and it still works, you are making poor contact with the LED. I am assuming you bought one tha mimics the terminals of old bulb.
    Mine is a tube with terminal caps with points on each end. Scratch the contacts with a fine sandpaper or steelwool.
  16. #16
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    55
    Posts
    1,052
    Default
    Go get another bulb, I had the LED in my '78 and it was dim as well - I went back to the OEM style.
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
  17. #17
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    What sort of LED setup are you using. Im using standard LED replacements and they work excellent. See http://www.abc-led.nl/webshop/led-autoverlichting/ but Im sue you can get these in the states.
    Chas
  18. #18
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    I had no problem with the LED bulb I got from Superbrightleds once I turned the bulb around for proper polarity. Of course, I installed new door switches at the same time and cleaned the contact area for the switches to ensure good contact with the body.
    73 240Z
    74 260Z
    Georgia Z Club
  19. #19
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    Found the problem, had a bad connector on the power line. Thank all for your input.
  20. #20
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Great! btw I looked at the new LED dome lights when doing a resto but wanted to see if others had luck. What do you think? Is the cabin brighter with the LED vs incandescent dome light?
  21. #21
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    Yes and I ran wires down the foot wells a now light in the foot wells.
  22. #22
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Phil, I'm very pleased with the LED bulb I installed in the dome light.
    73 240Z
    74 260Z
    Georgia Z Club
  23. #23
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Great! Did anyone swap out the map light too?
  24. #24
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Of course, Phil. I put one into the 260Z. I think I needed to use a more powerful LED than I put in, though.
    73 240Z
    74 260Z
    Georgia Z Club
  25. #25
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Thanks Steve! You are the electric Guru here. I should have asked long ago.
  26. #26
    Supporting Member EScanlon's Avatar
    Member ID
    CZCC-1490
    Join Date
    Dec 2001
    Location
    Vancouver, WA
    Age
    64
    Posts
    4,874
    Default
    Quote Originally Posted by Yellow78 View Post
    Why did you need to do this?
    The OEM Wiring harness has the wiring already in it's circuits, and it's already connected to the door switches and the dome light switch.
    E
    71 240 920 Gold
    72 240 Orange
    73 240 Red
    67 1600 Sports Roadster Spicy Orange Mica
    68 2000 Sports Roadster Red
  27. #27
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    I did not any in the OEM wiring harness that I saw so I ran a new one.
  28. #28
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Yellow78 there is an obscured run that is unused in North American cars and tied back in the wiring harness. It is for lights in the door panels of some other regions.
    It is convenient to use but the trouble is knowing that it exists. I only learned of it last year.
    FYI: There is also an unused run to the fuel tank in some Z's.
  29. #29
    Member ID
    CZCC-1490
    Join Date
    Dec 2001
    Location
    Vancouver, WA
    Age
    64
    Posts
    4,874
    Default
    Look for a pair of bullet connectors taped back to the main harness rope with blue electrical tape. Same at the Fuel tank for the optional electric Fuel pump and at the front of the car for the optional Fog Lamps.
    The last two have their corresponding Fuse/Switch circuit finishers by the center console fuse box. The Fog Lamps feed off the Parking / Instrument light circuit and it is highly recommended that you use a switch to in turn operate a relay up front along with a fuse. The Fuel pump set up isn't safety wired, meaning that once you power the pump by inserting a fuse in between the connectors at the fuse box it will run continuously, so it is advisable to connect it also to a fused/relay setup but with an oil pressure (or similar device) kill switch.
    FWIW
    E
    71 240 920 Gold
    72 240 Orange
    73 240 Red
Thread Information
Users Browsing this Thread
Similar Threads
  1. Dome Light Help
    By ktm in forum Electrical (S30)
    Last Post: 10-13-2014, 05:26 PM
  2. Dome light
    By Pomorza in forum Interior (S30)
    Last Post: 11-25-2011, 05:10 PM
  3. Dead Dome Light
    By hornz in forum Electrical (S30)
    Last Post: 02-05-2008, 05:25 AM
  4. Dome light fix!
    By MEZZZ in forum Electrical (S30)
    Last Post: 10-27-2007, 11:43 AM
  5. Dome light not working
    By venom42 in forum Electrical (S30)
    Last Post: 02-25-2004, 10:46 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
