Results 1 to 14 of 14
Thread: Anyone changed their headlights?
  1. #1
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Cool Anyone changed their headlights?
    Have any of you guys changed out the original headlights for better setups??
    Not that HID stuff, but modern bright headlights!
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  2. #2
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    origanlly they are sealed beams but you can get semi sealed. Look on ebay and there is someone from thailand.
    Wanted: Hardtop interior pieces
  3. #3
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default
    I've owned 30 year old cars with sealed beam headlights just as bright as newer models. Brilliant white, not yellow.
    The trick is getting FULL voltage to the headlamps. If yo'uve got a .5 volt voltage drop due to thin wires, bad grounds (paint under the ground screw) , corroded connectors, etc. your headlights may be as much as 30% dimmer.
    So how do you do it. Wire in some headlight relays. Use 10AWG wire. Get new headlamp connectors. Newset of bulbs, they do get "tired" as the filament material plates out on the glass and blocks some % of the light trying to exit the headlight.
    NAPA and such places sell "headlamp relay kits" for wiring up foglamps you can use to add a relay to your "normal" headlamps. but even they typically use 12AWG wire instead of 10.
    The non-sealed beams with the bluish tinted bulbs really DO make a difference, stuff is noticeably easier to see at night. Esp if they're getting FULL alternator voltage.
    You don't need to get HIDs or go away from sealed beams. Just give a NEW set of bulbs full voltage. And if yo'ure in 240 or model with an external voltage regulator, tweak the set point up .5V for some real flame-throwers.
    My '82 Subaru beater, with such a setup, would turn night into day.
    It's an invaluable safety item if you do much driving at night.
    Cheers!
  4. #4
    240Krazy! Adzmax's Avatar
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Good info!!
  5. #5
    Registered User
    Member ID
    CZCC-16252
    Join Date
    Mar 2008
    Location
    New Jersey
    Posts
    203
    Default
    Quote Originally Posted by 240k Style View Post
    The best headlight options in the 70's and 80's were Hella, Marshal and Cibie, especially their "Z" beam model. Doing a quick Google search, it appears the "Z" beams may be out of production. But danielsternlighting.com and clearcorners.com offer 7" dia. Cibie headlights that look very similar to the "Z" beams. At $78-90 each, they are expensive but the lighting improvement is worth it. For more info, try a Cibie forum search.
  6. #6
    Registered User Stanley's Avatar
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Within a day or two of buying my car a few years back put in halogens and a new windshield. Noticeable difference in the lights even in the daytime. Unsafe to drive if you can't see. On a lonely desert freeway, the 8, found out the halogens aren't up to a top speed run, though.
  7. #7
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    Quote Originally Posted by Wade Nelson View Post
    Cheers!
    Now THAT is a great idea!!!
    Adam
  8. #8
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    I agree with Wade. My 260 race car lights are H4 Autopals from H4Lights.com. The biggest bang for the buck is the wiring. I did use 12 AWG wire and relays with great results. I can run two sets of H4 lights with my very old 50 amp alternator and they put out amazing light even at idle. You can upgrade the lights all you want, but without doing the wiring and relays, you will be disappointed. Once the wiring is upgraded, you can decide if the halogens are enough.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  9. #9
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Dave's headlight relay upgrade harness at MSA. Save the turn signal switch, they're expensive. Could make one cheaper yourself, with the know-how, but these are very nice, plug and play. Black Dragon has some ok stuff, but their cheapie relay harness from China didn't match any of my connectors, finally trashed it.
  10. #10
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Quote Originally Posted by Stanley View Post
    I'm not sure that Dave's setup would work in a 240K.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  11. #11
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Don't know.
  12. #12
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
  13. #13
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    So those lights in Uras's post plus wired in relays would be the way to go?
    Adam
  14. #14
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Unfortunately, the relay setups you can get are only for the 240Z, (and maybe the 260Z?) because you cannot get the headlamp connectors for the 280Z. I'm pretty sure they are the AMP brand, but the model/syle# is a mystery.
    The best thing I did so far on the '78 was a new set of lamps, and to go through all the associated connections with DeOxit, annually, or more often. I considered a set of the asian made lamp housings with the replaceable bulbs, but even those are hard to decipher.
    Drive Responsibly.
    enjoy classic Rock music.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Changed out my front bumper
    By mlobster in forum What I Did Today
    Last Post: 04-03-2012, 11:25 PM
  2. Floor's Need To Be Changed $$?
    By TTDRIVER in forum Body and Paint (S30)
    Last Post: 11-28-2003, 12:27 AM
  3. What Changed??
    By Daniel in forum Electrical (S30)
    Last Post: 08-21-2003, 05:53 AM
  4. Tie Rod Ends Changed OVer.
    By Gav240z in forum Suspension and Steering (S30)
    Last Post: 05-24-2003, 04:30 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
