Page 3 of 3 FirstFirst 123
Results 201 to 296 of 296
Thread: My Datsun 240Z
  1. #201
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hoi Bart,
    I changed mine a while back too. The right side coupling on the rack also had some play in it. You have to cut the tack weld to adjust it. Took me a while to get the pre-load right. After those two repairs, nearly all play in the steering is gone.
    Any luck with your vibration?
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  2. #202
    It's awesome bartsscooterservice's Avatar
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Gendt, The Netherlands
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by EuroDat View Post
    Hoi Bart,
    Chas
    The steering coupler also helped again with the vibration.. I have the rear wheel bearings in house now, still waiting for the axles with the new u-joints to arrive this week to replace. Hopefully that does alot
    HLS30 32581, 5/71 Matching numbers
    Jay Leno : You know one week after the Americans have walked on the moon, the Japanese introduced this sports car, and…if you’re a car guy pretty equal. I mean walking on the moon was pretty good, but how many times you’d gonna walk on the moon? But here was an affordable sports car that had real performance and looked like it cost a lot more than it did.
  3. #203
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Chas,
    I found the bearings closer to home than I thought. LemmTech in Zevenaar has them also the oil seals.. Around 25/30 euro for a bearing.
    Your information helped
    Gr Bart
  4. #204
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    The bearings are here, still waiting for the oil seals.
  5. #205
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Meanwhile this arrived today
  6. #206
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Okay... I got the rear wheel bearings in ! Also replaced the prop shaft and the 2 short shafts. I didn't take pictures when changing the bearings , but here are some of the result. I've made a home made puller to get the shaft out with a 15 kg weight but it didn't came loose. After I tried almost everything, I heated up the housing with a propane torch and voila one whack and it came out instantly ! So I'd recommend anyone who is going to do this, just use heat.. to make the job easier and save alot of time.
    The locking nut came of pretty easy, I used an impact wrench. First I used a chisel to whack off the flat spots on the security ring on the nut before loosening it.
    I found the grease reservoir to be completely dry on both sides ! Those bearings must have been in there a long time
    I found while replacing the prop shaft that the 4 bolts connecting the prop shaft flange to the differential flange where not original, but US size bolts. I found this may cause an alignment problem, Lucky I had the original metric bolts..
    I also freshed up the fuel cap/housing area, there was some rust there. And put some extra sealant between the gaskets to prevent leaking of fumes.
    Also a pic of the new original gearknob in the car.
  7. #207
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    After going to 3 wheel " specialists " , finally found one who found the following:
    2 bent rims
    and the holes will be drilled conical, so I can use conical lug nuts to center it just right.
    Fingers crossed !
  8. #208
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Bart, That sounds like good news. Hope it solves your problem after all the effort you have put in trying to find it.
    Chas
    Chas
  9. #209
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Well.. problem is still there...to bad
    I even cleaned the inside of the wheels, so they could balance it properly.
    What could be it ? It start's at 50 mph.. steering wheel wobble ( left to right )and vibration, also vibration on the chassis noticable. Could it still be the rims, or tires ? They are Dunlop..
    It's driving me nuts lol , but I will keep searching for the problem.
    Edit: I notice engine movement shaking the car a bit when running stationairy in the car, when parked or waiting in front of a traffic light. Not sure if this got anything to do with it. All mounts are replaced.
  10. #210
    Yellow Z-Car Club DougN's Avatar
    Member ID
    CZCC-8920
    Join Date
    Jul 2005
    Location
    Atlanta, GA
    Age
    56
    Posts
    681
    Default
    Could be a bump on the tire(s) itself or another issue with the tire itself, rather than the wheels.
    Doug
    Doug
    '73 240Z (HLS30-126840)(10/72) Yellow (64XXX original miles)
    '66 MGB (GHN3L108501)(12/14/66) BRG
    '10 BMW E93 Silver
  11. #211
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Bart,
    I thought you had it beat with the wheel runout. It could be something like a blister in the tyre that start to play up at higher speeds.
    You can try my wheels. I don't have any vibrations up to 80mph. That way you can eliminate the wheels or identify it as a wheel problem. Let me know and we can arrange something.
    Chas
    Chas
  12. #212
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Okay... I had another look and found a " knock '' sound in the steering housing ( rack ), when turning fast left to right on the steering wheel when parked. Als found play in the right side in the steering housing ( rack ). So I took the steering housing(rack) out for rebuild ( I guess it was never done since 1971. Hopefully this solves the problem. If not it should be the wheels or a hub that is bent I guess. I checked the brake discs and they are not warped.
  13. #213
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Bart,
    Chas
    Yes.. I will try one last time with the rack. If that doesn't solve it, I will try that. The steering rack is the last part I haven't replaced/rebuild.
  14. #214
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Steering rack arrived yesterday.
  15. #215
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Bart,
    The vibration problem is one hell of away to fast track your restoration.
    All jokes aside. If another set of wheels (mine) don't fix it, then I have no idea what will. It can't be in the engine or gearbox because you would feel that at lower speeds in the lower gears with the same revs and you have changed just about everthing that rotates.
    Chas
    Chas
  16. #216
    Registered User northernz's Avatar
    Member ID
    CZCC-18715
    Join Date
    Feb 2009
    Location
    Edmonton AB
    Age
    58
    Posts
    226
    Default
    Hey Bart, I was just reading a blog at White Head performance and it mentioned `typical brass bushing wear``at either end of the steering rack which can cause wheel shimmy at highway speeds, perhaps this is your problemÉ FWIW
    mark
  17. #217
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    If you feel it in the seat then it is coming from the drive train. Check drive shaft, half shafts, diff, mounts, etc. While cruising at highway speed when the vibration is there take it out of gear and see if it goes away or lessens.
  18. #218
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Hi Bart,
    Chas
    I bet it's the wheels/rims to ! I'm going to try yours..
    It looks like radial runout tire or rim
  19. #219
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by northernz View Post
    mark
    I allready tested yesterday with the new rebuild steering rack, slight difference but not much. I also read their site, and thought that could be it, that's why I let a shop rebuild the steering rack..it had to be done anyhow.
    @ rcb280z: allready tried that to, in our out of gear no difference !
  20. #220
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    Those vibrations / shimmy's are a PITA to find sometimes. Mine is about 95 percent gone and is one of those shimmy's that come and go. I'm just living with it for now. Went through the "rim repair" scenario etc, and nothing completely fixed it. Am curious to see what you find.
  21. #221
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I just picked up Chas wheels. I'm going to try them tomorrow on my Z and find out if this is the problem !
  22. #222
    Registered User olzed's Avatar
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Auckland. New Zealand.
    Age
    76
    Posts
    1,069
    Default
    Hey Bart. I once had an annoying bouncing in my 240, and the tyre shop traced it to four poor quality tyres which were impossible to balance. The inside bead of the tyre was not true with the tread area, resulting in a tyre that moved up and down when rotated. Tyre brand FALKEN. I could have named them something more appropriate.lol
    I kicked myself for buying cheap.
    Brian.
  23. #223
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Problem found... chas's wheels solved the problem, it was not even aligned yet, but a steady ride finally..
    now I know where to look, possibly other new rims and bolts..
  24. #224
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Age
    76
    Posts
    1,069
    Default
    Thats great.
  25. #225
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yup. I have been looking for classic 14 inch wheels, but it's going to be hard here.. I've called a dozen shops allready, but none seem to have.
  26. #226
    Member ID
    CZCC-8920
    Join Date
    Jul 2005
    Location
    Atlanta, GA
    Age
    56
    Posts
    681
    Default
    See if you can get a new set of American Racing Ansen Sprint wheels. They are one of the makers of the "original" dealer add on wheels (like on your car), but now they make them in 15" instead of 14". They were reasonably priced over here in the US at least.
    I've had them on my Z for a number of years now and they are great.
    Doug
    Doug
    '10 BMW E93 Silver
  27. #227
    Registered User
    Member ID
    CZCC-30365
    Join Date
    Apr 2014
    Location
    Inland Empire in Southern California
    Age
    61
    Posts
    3
    Default
    Bart,
    It sounds like you and I might have the same problem. To solve my vibration problems I put on new tires. I took it around to a few tire shops and most said the same thing: Putting new tires on it should take the shaking out of it. And it did! I was amazed!
    I'm only saying this after reading so many of the above posts... as I remember, your tires are older? 2002 if I remember correctly. It might be something to consider, especially if they are older and you would be replacing them at some point anyway. Hope this helps...
    SoCal-280zx
  28. #228
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Bart, Take the wheels to a tyre speacialist and ask them to remove the tyre and check the wheel for run-out on a tyre dalancer. You can rotate it by and check it against a dial indicator or screwdriver. Something to give you an idea if its bent or out of shape. If he doesn't see any run-out, remove all the weights and let him check the balance. If the balancer reads perfect, and I mean perfect because the balancer not so accurate on a light wheel. He will need to set it up for a 12" wheel to compensate a little for no tyre.
    I would then try a new set of tyres.
    You are looking for another set of 14" rims so if this doesn't work you can use the new tyres on them. I think its worth the gamble, if you can test the rim first.
    Goodluck
    Chas
    Chas
  29. #229
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by SoCal-280zx View Post
    Bart,
    SoCal-280zx
    the tires are new dunlop put on last year ! But it was the wheels I am sure now.
  30. #230
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Thanks for the info/help guys. I couldn't find any 14 inch wheels for now...damn hard to find here. Today I was able to pick up 15 inch 280zx turbo wheels with the original nuts with them ( just have to put new tires on them, these have a flat spot from sitting over 10 years and are old). So this should fix my vibration problem. I will keep looking out for 14 inch wheels.
    The problem with my current wheels is that 1 wheel has a different ET, the wheel is not the same as the others and it's some immitation brand, I'm not sure if it's worth fixing these, or just looking for a genuine wolfrace 14 inch set ? At least I have these 15 inch wheels for now, they don't look bad I picked them up fearly cheap, the guy was quitting his Datsun hobby. He had a solid euro 280zx turbo for sale !
  31. #231
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Goodluck
    Chas
    I'm thinking what to do, like said above it's some immitation brand, and one wheels has a different ET.. if the wheel goes on the balancer machine they use the center hole, but if the mounting is somewhere out, the rim could balance fine but it doesn't center on the axle..
  32. #232
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by DougN View Post
    Doug
    Hi Doug, If I can't get them here, I will order them in the USA for sure..
    It seems many brands make this kind of wheel, but the original ones seem to be the " wolfrace " brand ? I'm not sure. It's a pain anyhow to find classic car aluminium wheels in 14 inch here..
    Gr Bart
  33. #233
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Also new replacement rear brake drums arrived from the US. My old ones where really worn out.. this is one of the parts that still was to be replaced.
  34. #234
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    While waiting for the tires, started refurbing the turbo wheels today. I am sandblasting them, and giving them the silver finish ( no gloss ), motip wheelspray. I think it looks great..standard look, makes the wheel stand out more, then when it's polished, and I hate polishing by the way :P
  35. #235
    Registered User
    Member ID
    CZCC-30326
    Join Date
    Apr 2014
    Location
    Garner, NC
    Posts
    24
    Default
    you have a very clean 240Z
  36. #236
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Thanks. I finally installed the turbo wheels with michelin tires... and yes finally a smooth ride and steady steering wheel ! I will post some pics tomorrow. Doesn't look bad at all ! I'm also going to pick up 14 inch iron cross wheels saturday, so I don't have to waste my new 14 inch dunlop tires, and have 2 sets, they use the same lug nuts as the turbo wheels oem nissan.
  37. #237
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
  38. #238
    Member ID
    CZCC-8920
    Join Date
    Jul 2005
    Location
    Atlanta, GA
    Age
    56
    Posts
    681
    Default
    Quote Originally Posted by bartsscooterservice View Post
    Gr Bart
    Bart,
    There were a few different manufacturers of the "original" dealer add on 5 slot wheels - American Racing is one of those as mentioned, I think there is a thread somewhere that lists some of the others as well.
    The challenge with the 14' wheels is that no one makes them anymore so you're always stuck with used wheels and as you've seen, it's hard to know you're buying a good set
    Doug
    Doug
    '10 BMW E93 Silver
  39. #239
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I managed to pick up these 4 280zx 14 inch iron cross wheels today. So I can put my 195/70/14 Dunlop tires on these and be done with it. They use the same oem nissan lug nuts as the turbo wheels. I'll think I'll leave it this way for now...
  40. #240
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I placed the new brake drums and oem nissan brake pads also. But did not yet adjust the handbrake. I took an hour this evening to adjust them according to what's said in the FSM, and now it's 3/4 clicks and the wheels are locked..so that should be fine.
  41. #241
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by EhlersRS View Post
    Bart,
    It was great meeting you and glad to hear you enjoyed the photos of your car. I still can't believe not long ago it was just a few hours from here and now it's half way around the world! I've talked to all of the previous owners of my car, including the original owner who is now 81. He had some great stories to share about the car and his past experiences. I was hoping to located a photo of the car from the original and second owner, but they didn't seem to take any. Anyway, it looks like Alan VanGundy still lives in Iowa, so he would be easy to contact. Does the paperwork indicate how many previous owners there were? My car came with the maintainence records up to 1988, so I was able to track down the owners. I browsed through your previous rebuild posts and agree this new car is in much better condition than your last Z. I'd guess your previous car had more rust than mine and it spent most of it's life in Illinois. Well, if you'd like help tracking down the previous owners I'd be glad to help!
    Robert S.
    I'm still looking to find the first owner if that would be possible.. His name is on the warranty card that you can see in the first post.
    Hertel R E JR
    5244 Foxridge dr
    Shawnee Missionks 66202 ( Date 07/27/1971 )
    Gr Bart
  42. #242
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by pressedsteel View Post
    On the other hand, I never had and contact with the original owner and I'm not sure if there was anyone else before Campbell. It will be interesting to hear what develops! I'd be willing to help if needed as well.
    Alan V.
    Hi Alan,
    That would be the guy in the post above. I don't know how to track a person overthere in the US, but maybe somebody here can help in that.
  43. #243
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Drove it to a colleague in Amsterdam yesterday and it got alot of attention people making pictures, and one car opening it's windows on the motorway, and asked something like " what's the build date " I couldn't make it up haha.
  44. #244
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I was digging some information, and found what I think is the original color code of the car on the warranty card, if correct it should be 901 Silver.
    The other number is 954, but according to zhome.com that's not a 240z color code.
  45. #245
    Registered User EhlersRS's Avatar
    Member ID
    CZCC-21096
    Join Date
    Mar 2010
    Location
    Cedar Rapids, IA
    Age
    45
    Posts
    228
    Default
    Bart,
    I was looking at the photos of your Z from the start of your thread again and noticed the inside of your doors are silver. So yes, the original color of your car is 901 Silver. The original warranty card for my car also has an extra number next to the date, but the 5 digits don't seem to have any meaning. I'm still working on your request.
    Robert S.
    1971 240Z HLS30-21244
  46. #246
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I got a PM from Mike ( ZDaddyO) with an address in Kansas:
    Robert E Hertel, Jr
    Age 65 +
    10778 S Brownridge Street
    Olathe, KS
    66061-3111
    I wrote him a letter with a copy of the warranty card and my contact information, and posted it 2 days ago.
  47. #247
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Well... look what I got in the mailbox today:
    I was indeed the first owner of the car in question. It was one of the first in Kansas City and was purchased from Overland Park Datsun. I traded in my 1969 440 RT Dodge Charger for it. Car was never wrecked. We moved in the Spring after purchase to New Rochelle \., New York. There we had to have the 3rd gear synchro repaired under warranty. That was the only mechanical issue with the car. Rust along the rocker panels soon appeared, but we had it repaired and dar fully repainted after moving back to Kansas City in 1976 then sold the car to a dealer friend of mine in Leavenworth, Kansas ROUND 1978 - 79. Guess my friend drove it until 1987 or Mr. Campbell is not the second buyer.
    In New York the car was maintained by Bob Sharp Datsun. Sharp was an amazing race car driver and won the C production class of SCCA in the Z cars for many years. Hos son is Scott Sharp that races the Patron car in the Rolex series.
    Hope this info helps? Regards, Bob
  48. #248
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I'm just back from a 1 week holiday in the Czech Republic , visited Prague also. The last day we went to South/West Germany, Sinsheim Technical Museum, very nice ! I went with the 240Z no problems, the car ran fine all the way. ( more than 2000 km total) Here's some pictures..
  49. #249
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Age
    76
    Posts
    1,069
    Default
    Thanks for the pictures of your holiday Bart. Nice pictures.
  50. #250
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    Sounds like a great trip. Thanks for sharing the pictures.
    It's funny to see the old Caprice police car in the museum next to the DMC-12.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  51. #251
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Looks like an awesome trip! It's great to see the Z out and about in Europe-land.
    2/74 260Z
  52. #252
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yeah it was a fun trip, really nice landscape in parts of Germany and Czech Republic..
  53. #253
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Here are some pictures the first owner gave me last week by e-mail.
  54. #254
    Registered User alternativez's Avatar
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    66
    Posts
    116
    Default
    Wow! You've done an amazing job with your z, and it was surely a cool and exciting reward to take it on vacation! Thanks for sharing the story through this excellent thread!
  55. #255
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Age
    76
    Posts
    1,069
    Default
    It was cool of the first owner to reply to you Bart.
    14 years ago I contacted the first owner of my 240 after i had completed the restoration. He was not interested in seeing it, and said it was just a toy his wife drove.
  56. #256
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yeah, also amazed me I got a reply back so quick.. I didn't even count on a reaction to my letter at first.
    @ Alter: thanks yeah it was sure fun taking it out on a vacation.
    Only thing I have to do next week or the week after is to drop the gas tank, and replace the filler neck and fuel lines, also paint the tank. I have ordered these parts last week in the US.
  57. #257
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Last time I still had a knocking sound when braking coming from the rear, I allready had replaced both the shoes and drums. I found that I had to clean the glide surfaces on the backing plate, and put some copper grease. No more knocking since then. So if you have this problem, your brake shoes might nog be sliding properly on the backing plate.
  58. #258
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Finally made some time to take the gas tank out and replace all the fuel lines including the filler neck. Cleaned the tank from all dirt and resprayed it black. Also put in a new float.
  59. #259
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Made some time today and got 2 of the 4 14 inch iron cross wheels finished for balancing. The color is " steel wheel ".
  60. #260
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Wheel cleaned up nice. Must feel great to drive with out any vibrations.
    Chas
  61. #261
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yeah.. sandblasting them was most of the work. Painting went pretty quick. Yes the ride is so much more enjoyable without those vibrations !
    They are all under the car now with the Dunlop tires that I allready had bought and where on the old rims. No vibrations with these aswell ! Personally I think these look better on the 240Z with the fatter tires But now I have 2 sets so I can change them from time to time..
    Here's some pictures, the car in the back is the Chevrolet Caprice from 73 from my brother.
  62. #262
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Looking good, I like it
    Chas
  63. #263
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I went to Japan Classic Sunday 2014 today. Only 2 other 240Z's showed up. One Dutch " Euro " 240Z from late 73 I guess ( registery date showed april 74 ) with a 5 speed. And another 71 Z with a 4 speed imported from the US.
    Here's a few pictures I found on the facebook page.
  64. #264
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
  65. #265
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    The center caps on the 280ZX wheels where all gone, I bought new ones from total z parts, after some bargaining I got them for a good price.
  66. #266
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Bart, I'm curious to know the street price for your car in Euros if you were to sell it in Europe?
    Also, would you know if Z's are priced higher in other western European countries?
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  67. #267
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by Blue View Post
    I really have no idea , Japanese classic cars still don't seem to hold much value here, maybe the same situation as in the US ?
    I see Mustangs and Corvette's going for much higher prices, even a " project " will go for 8 to 10 k euro. I went to Stolze last time, and they asked 16k for a '' project '' C3 corvette from 1972 :S
    Don't know about othern Western countries, but I don't think much of a difference.
    It's going to get the roof removed and new paint this winter, which is now a minus factor if I would sell it, which I won't haha.
    We do have a new classic car rule here since last year, anything over 40 years old doesn't pay road tax, so cars from 1974 or earlier will be worth more here.
  68. #268
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    There are just a handfull of early Z cars here in The Netherlands. It was not that populair here then in the United States back then. My dad had one in the 70's here, and he said he almost never saw another 240Z back in the days here..
  69. #269
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I often see Z's that are not as nice as yours go listed at 20 to 25,000 Euros in Portugal. I'm not sure if they actually sell for this amount.
  70. #270
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    mmmm...that's alot more.. maybe here it will go for 14 to 15k. Maybe it also depends on how populair the car is in that country ?
  71. #271
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Here is a nicely restored one for 30k.... nice wheels
    http://bragacity.olx.pt/datsun-240z-iid-441918651
  72. #272
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    That's alot and it's a 73 also, not totally original , but would they actually go for that amount ?
  73. #273
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    I noticed I don't have a fuel smell anymore with the windows down, since I replaced the filler neck and hoses on the tank.
  74. #274
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Last saturday I went to another classic car event in the village of Borculo. ( I can't seem to find pictures of it so far ). Also saw a Nissan GTR and ended up talking with the director of Nissan, Herwers Group. He said he also had some classic Z's in the past, his thought's where that Nissan should go back to making an affordable sports car like the 240Z's goal was back in the time.
    On the way back I found the 240Z was running strange it would not go past 4.5 k rpm. Back home on Sunday I checked the ignition, and found the timing was shifted because the bolt that holds the distributor was worn out, when I tried to fasten it broke of. ( see picture ).
    Lucky a friend who has alot of 240Z parts had one laying around, and the problem was fixed in the evening.
  75. #275
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Today I went to a radiator repair shop to check about my temp meter, I thought the car was running to hot when pushed. But we checked with a heat gun, when the meter on the dash was showing 3/4 the car measured only 76 to 78c , according to the shop that was normal even a bit to low. So that's good news, I know now the meter is not that accurate.
  76. #276
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    A cool picture I made today
  77. #277
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    That photo looks firmiliar
    Chas
  78. #278
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I seen this 240Z 72 today when I was at the Nissan dealer next to them. http://www.erclassics.com/Datsun-240...-sale-931.phpn
    I don't think there is not a panel without a dint in it of some kind. Maybe the roof. Seats have been recovered and all the rubber is old and brittle. Might of been a Cal car before it came to Europe. At €9900 he is asking a lot imo.
    Chas
    Chas
    Chas
  79. #279
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    I don't know EU values, but that car seems like it is way overpriced. That would be a $2000 car in the states.
    Jeff
    IZCC #1285
  80. #280
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Quote Originally Posted by Jeff G 78 View Post
    Yup. But this is Europe
  81. #281
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yesterday recieved an e-mail from somebody that seemed from the Dutch 240Z club who lived in Den Haag and who had original 240z steel rims/tires/hubcaps and wheelnuts for sale for € 170, couldn't refuse that offer, since they are hard to find.
    I will pick them up next saturday...
  82. #282
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Thanks to a little help from Robert ( EhlersRS ) I managed to buy another classic car for restoration. It's a 1971 Ford Mustang Mach 1 with 302 ( not the biggest engine, but I will give it some upgrades for more power ). Car is located at Orlando Mustang in Florida. Currently arranging payment with them, and it will be shipped to The Netherlands later on.
    It's an original Mach 1 by VIN, the VIN : 1F05F217955
    Bought it for 3000 USD. Engine has water damage, but it will get a rebuild.
    The 240Z is mostly done and I need a new challenge, and always wanted an American muscle car !
    This is going to be fun !
  83. #283
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I can ship you mustangs every week if you can flip them....PM me if you want to experiment.
  84. #284
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Picked up the original steel wheels and hubcaps. Will store them away.
    Picture from today, on 21 september will join the last local classic car event, then I will try get it to the paint shop for a respray and sunroof removal.
  85. #285
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Dropped the original steel wheels of at the tire shop to get balanced. I want to try them on the car see if the ride is smoother. You won't believe it but I still have little vibration in the steering wheel and trough the car above 70 mph, not as bad as before, but it's still there and I find it annoying on the highway.
    On the car now are the 280ZX 15 inch turbo wheels with the original lug nuts, you would think it centered fine.. but this system does not use the conical lug nut like the original steel wheel of the 240z does. Now that I have the original lug nuts with the original wheels I wan't to try them out, who knows the ride if finally smooth as it should be..
    If this doesn't cure it, I will live with the little vibration and the turbo wheels will go back on.
  86. #286
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Tried the stock steel wheels and the vibration at higher speeds above 70 mph was much less id say 40% less. So it must be in the tire/wheel combo...
    The turbo wheels are now back on.
    I want to try one last thing: road force balancing on the hunter machine. I booked an appointment tomorrow morning, fingers crossed. This is the last thing I will try, if not cured I will live with it.
  87. #287
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Okay this morning the wheels where balanced with the hunter road force machine. 1 rim needed a tire rotation on the rim ( high/low spot matching ), the other 3 only weights. I have to say it's much better now only a small amount left ! But that's okay I can't expect a 100% steady steering wheel at higher speeds.
  88. #288
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Sunday drive through Flevoland
  89. #289
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    The world seems to work at 70% and "good enough". These days it seems you have to do it yourself to get it done right.
    Artisans, pride, and care are long gone..... except in a few isolated places.
    So if you want balanced tires the first time you need to buy a machine or you have to settle for the 20th attempt.
    A good friend had the same problem getting his suspension set.
  90. #290
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yesterday another local classic car event, this year was the second time, not so many cars, but still fun !
  91. #291
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Parked in by a VW...
  92. #292
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    The 240Z is heading to the painter tomorrow. I removed the bumpers and the headliner ( for sunroof removal ). The painter will remove all the windows/lights etc and replace all the rubber seals. ( all the seals are in the carton box in the rear of the 240z )
    I also managed to buy an original 1971 owners manual from Ebay. The owner said the following: Nissan Motor Corp. reprinted these in 1997 for the Nissan Z-Store- to put in the glove box of the Restored 1970-72 240Z's. I was part of that program restoring Z's. I got these direct from Nissan Motor Corp. So these are NOS of Nissan's reprint.
  93. #293
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Okay guys a little update from the paint shop. The sunroof is gone. It will take a few more weeks before the new paint is on.
  94. #294
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    The bumpers are also away for new chrome. I also ordered new rubber oem strips for the bumpers in the US.
  95. #295
    Member ID
    CZCC-8920
    Join Date
    Jul 2005
    Location
    Atlanta, GA
    Age
    56
    Posts
    681
    Default
    Are they painting the whole car, or just parts? Bet you can't wait to get it back!
    Doug
    '10 BMW E93 Silver
  96. #296
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    33
    Posts
    857
    Default
    Yes the whole car.. The windows will go out also, when it's painted, they will go back in with new seals.
    Sure, but I have to be patient
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. What a Datsun 240Z Looks Like Going 173 MPH
    By Mike in forum Publications
    Last Post: 10-30-2010, 08:09 AM
  2. 172.9 MPH in a Datsun 240Z!!
    By Carl Beck in forum Open Racing Discussions
    Last Post: 09-23-2010, 09:39 AM
  3. Mad Max Datsun 240Z
    Last Post: 10-14-2009, 02:59 PM
  4. Buy DATSUN 240Z??
    By mattbibbey in forum Open S30 Z Discussions
    Last Post: 05-27-2009, 07:54 AM
  5. my datsun 240Z
    By pwbull09 in forum Open Discussions
    Last Post: 10-01-2004, 07:46 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
