Results 1 to 13 of 13
Thread: Oil recommendation
  1. #1
    Registered User Zu Zu's Avatar
    Member ID
    CZCC-29025
    Join Date
    Feb 2013
    Location
    Saint Louis
    Age
    47
    Posts
    18
    Default Oil recommendation
    okay - hopefully an easy question for a Saturday. Just got my 260z and am going to change the oil today. Not sure how long the current oil has been in there. Looks ok and full but who knows. What type/brand do you all recommend? Will be light weekend driving in decent weather. Currently COLD here in the midwest Will change again in the late Spring.
    Thanks all!
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Nissan says 10w30. Some suggest using oil for diesel engines since it contains ZDDP, an additive no longer put into typical motor oil. Oh, the engine needs 5 quarts.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  3. #3
    Member ID
    CZCC-29025
    Join Date
    Feb 2013
    Location
    Saint Louis
    Age
    47
    Posts
    18
    Default
    Thanks Steve
  4. #4
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    After the spring oil change I'd use Valvoline VR1 10W30 Racing Oil, not for street use because of the converters, from O'rielly's. Seems like they had the best price and not all of them stock it, but can get it overnight. It's kinda expensive is why I say not for the 1st change.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  5. #5
    Registered User Dr. 240Z's Avatar
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    New Brunswick Canada
    Age
    69
    Posts
    228
    Default
    Hi,
    Please learn from my costly mistake from last October. Do not use synthetic oil. Use a quality 10-30 regular like Castrol GTX.
    Important: Always supplement your choice of oil with ZDDP - Especially if you are breaking in a new cam.
    ZDDP is cheap - $6 to $8 per oil change - On sale right now at Eastwoods
    Cheers,
    George
    Original Registration and Warranty Card
    Original owner of: HLS3018859 (Jan./71) ZCOOR Member # 178
    'Storms Never Last'
  6. #6
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    I've been using Mobil1 10W-30 full synthetic with no issues for 2.5 years.
    2/74 260Z
  7. #7
    Registered User Mike W's Avatar
    Member ID
    CZCC-19584
    Join Date
    Jun 2009
    Location
    Austin, TX
    Posts
    243
    Default
    So I just put in a stage 2 cam from Isky and they only recommend 2 brands of oils for higher performance engines mainly due to the inclusion of Zinc and other additives.
    Their number one recommendation is a brand call Brad Penn. Apparently this company purchased an older refinery from I believe Castrrol and continue to make oil with high zinc content and ZDDP. I believe that the refinery is in Brad Pennsylvania, which is where they get their name. I use 20W-50 and have had no issues with the Brad Penn oil. It is a little unusual as it is green in color but I suspect that is due to all of the additives. It is also on the expensive side as oil goes although probably not as much as synthetic. The only other brand they recommended was Valvoline VR1 racing, which I have also used with good success in the past.
    Hope this helps.
    Mike.
  8. #8
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    15/40 diesel oil, lots of ZDDP, lots of detergents, dirt cheap.
    1970 240Z HLS30 01955 March/70
  9. #9
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Quote Originally Posted by Mike W View Post
    Brad Penn is from the former Kendall Oil plant. Story goes that when Kendall was purchased by Exxon-Mobil, they sold this one refinery and the original Kendall GT-1 formula to one of their long-time engineers. The Kendall name went to Exxon-Mobil, but in general, Brad Penn is the old Kendall GT-1 formula, well-fortified with ZDDP. It is by far the favored oil in the USA by owners of air-cooled Porsches. (At $5-10k or more for a full rebuild of a 911 motor, you don't take too many chances with sub-standard oil.) Valvoline VR-1 is considered acceptable too. For full synthetics, some people run Mobil 1 V-twin (designed for Harleys) as it also contains good amounts of ZDDP. Some of the high-ZDDP oils are only available in thicker viscosities, which may be fine for my 911, but not as good in an L-series Z engine. I used to use 10W-30 year-round in the 240Z.
    Quote Originally Posted by grannyknot View Post
    Check the formulas carefully, as that is not always the case anymore. Many modern diesels now have catalytic converters and so ZDDP is now being phased out of diesel oil as well. There are now (I've been told) two different formulas for Shell Rotella, for example. As time goes on, I suspect the only oils that will contain reasonable amounts of ZDDP will be categorized as racing oils.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  10. #10
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    I run VR1 40wt in my 260Z race car. We run endurance races, so we are racing for up to 25.5 hours straight. I will gladly pay $6 per quart to finish a race and not have to rebuild the motor very often.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  11. #11
    Registered User doradox's Avatar
    Member ID
    CZCC-14809
    Join Date
    Aug 2007
    Location
    Colfax, IN
    Posts
    708
    Default
    Quote Originally Posted by LeonV View Post
    That's a good choice. I use Valvoline SynPower 10-30 in the Z and 5-30 in my other cars. My '81 Ford pickup gets the cheapest oil I can find and miraculously hasn't wiped its flat tappet cam yet despite all the "evidence" that says it should have. I took my 240SX (flat tappet) to 249,000 miles on SynPower and when I sold it it was running as well as the day I bought it. My 03 Suburban has 253,000 miles and is still running perfectly. ZDDP is cheap and effective. Other antiwear agents that replaced ZDDP in modern oils are effective as well just not as inexpensive. I don't see the need to pay more for a less expensive product, or to play chemical engineer and roll my own formulation, but to each his own.
    Here is a link to the flat tappet cam test that modern oils have to pass.
    SwRI: Sequence IVA Test Method for ILSAC GF-3/GF-4 and API SL/SM
    Steve
  12. #12
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    60
    Posts
    1,374
    Default
    Shell Rotella T Triple Protection has all the stuff you need and is designed for 2006 and earlier diesel engines. API CJ4. But oil selection doesn't matter much for a street engine that spends 95% of its time under light load.
  13. #13
    Member ID
    CZCC-29025
    Join Date
    Feb 2013
    Location
    Saint Louis
    Age
    47
    Posts
    18
    Default
    All fabulous information. Thanks all!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Silver Paint Recommendation?
    By tlorber in forum Body and Paint (S30)
    Last Post: 09-18-2011, 05:47 AM
  2. Machine shop recommendation
    By mbarjbar in forum Engine and Drivetrain (S30)
    Last Post: 11-15-2010, 08:59 PM
  3. Coil Recommendation 75-280Z
    By LBO730 in forum Electrical (S30)
    Last Post: 03-25-2010, 05:24 AM
  4. Vendor Recommendation
    By tlorber in forum Suspension and Steering (S30)
    Last Post: 12-16-2009, 01:43 PM
  5. what is your recommendation for suspension mods?
    By clutchdust in forum Suspension and Steering (S30)
    Last Post: 11-04-2003, 06:11 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
