Page 2 of 2 FirstFirst 12
Results 101 to 140 of 140
Thread: 240z fuel and brake line insulator sets and steering rack expansion reservoir
  1. #101
    Registered User nix240z's Avatar
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Handbrake dust cover in transmission tunnel.
    Click image for larger version.
    Datsun 240z rubber grommets & parts
  2. #102
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    front turn signal socket wire insulator.
  3. #103
    Z Club of San Diego Montezuma's Avatar
    Member ID
    CZCC-10665
    Join Date
    Feb 2006
    Location
    San Diego
    Age
    56
    Posts
    1,063
    Default
    Quote Originally Posted by nix240z View Post
    How much?
  4. #104
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Quote Originally Posted by Montezuma View Post
    How much?
    turn signal wire insulators are $20 a set... I am also working on the gasket for the socket.
    This is the location for the handbrake dust boot looking from the rear forward, it is on the left side of the transmission tunnel
  5. #105
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    update on the firewall speedocable grommet. The grommet is done and I am testing the glue to hold it together after cutting. Regular superglue works fine, I have the grommet glued back together and under a stretch test of 150% of the cable size, to see if it comes apart. I have also ordered some loctite 406 which is made for rubber and high heat. Once I complete the tests I will report my findings.
    Steve
    The stretch test is complete and both regular Super Glue and loctite 406 worked great. There should be no problem gluing the grommet back together. Just don't get the glue on your fingers because you will be glued to the grommet.
  6. #106
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I am working on a custom set of insulators for 240z's with a over sized return line, which will be the same size as the main fuel line.
    any other interest in these custom insulators? I have to machine, mold and cast the new custom insulators. The price will be more than what the regular set of insulators are and that is $150.
    also working on the engine bay light lens and the rubber gasket plus the wiper bottle motor rubber mounting insulator.
    Steve
  7. #107
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Engine bay light replacement lens and matching rubber seal.
    I am also working on a few other new items.
  8. #108
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    washer bottle motor cover insulator.
    check website for other new and up coming items.
  9. #109
    Member ID
    CZCC-10665
    Join Date
    Feb 2006
    Location
    San Diego
    Age
    56
    Posts
    1,063
    Default
    Datsun 240z rubber grommets & parts is making some really awesome parts, I really appreciate it and I am sure they will go a long way to help us get our cars looking original as possible.
    http://www.zcca.org/downloads/2012/Z...anual_2012.pdf
    If you are going to get your car judged at a ZCCA ZCON event these parts will help you very much.
  10. #110
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Thanks,
    I never noticed how many little rubber parts there is on a 240z until I started reproducing them for my restoration.
    Steve
  11. #111
    Frogsquisher Zup's Avatar
    Member ID
    CZCC-8151
    Join Date
    Apr 2005
    Location
    Bentonville, AR.(not Arizona)
    Age
    70
    Posts
    265
    Default
    I agree with Montezuma---totally awesome---could not be better!
    These small parts are very important to anyone wanting to truly restore their car and many have been unobtainable until now!
    Steve--
    Can you reproduce the rubber gasketing for the air cleaner housing. They look to me to be more like an extrusion, but I have no idea really, and I don't know the full extent of your production capabilities. No one offers these and most anyone restoring/repainting or powdercoating their air cleaner needs them.
    Maybe you have contacts that can if you can't??
    Also, I must mention the wiper linkage boot again---I need at least three.
    Thanks for all that you have done!
    Jim D.
    "Zup"
  12. #112
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Quote Originally Posted by Zup View Post
    Steve--
    Jim D.
    "Zup"
    Jim, wiper linkage boot is still in my plan. I will have to take my wiper assembly apart to get a sample for the mold, I am trying to put my car back together not take it apart again.
    The rubber gaskets for the air cleaner housing is too big of an item for my pressure pot, I have a 40 liter pressure pot.
    Steve
  13. #113
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Another small item that is missing 99%-100% of the time and you don't even know it.
    Look at your Escutcheons and you will see the hole.
    Door handle Escutcheon rubber bumper.
    Escutcheon not included rubber only.
  14. #114
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Steve,
    They look a lot better than the stuff you can buy at MSA. I thunk they just use the fuel lid rubber which is not the same.
    Your attention to detail is faultless.
    Now when are you going to start restoring a 280 Then I wont have to bother making all that stuff.
    My shopping list is getting bigger. I am planning on ordering some stuff, but I want to order everything at once to reduce the shipping.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  15. #115
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Thanks Chas, let me know when you would like to order, I will give a discount on a multi item order.
    Jim. D aka Zup the wiper linkage boot is now back off the car and getting ready for reproduction. Should be done in a week or so.
    Steve
  16. #116
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I love this thread and evertime I see a post by Nix I wonder what he has made now
    Steve, I'll be ordering but I put my 69 resto on hold until I finish the 77.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  17. #117
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Turn signal socket gasket.
    Also the end on both the turn signal and headlight wire harness.
  18. #118
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    wiper arm linkage boot under the cowl.
    steve
    www.240zrubberparts.com
  19. #119
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I am working on these items.
    - All 4 of the vent hose seals in rear hatch area with correct look, not just some grommets that fit the holes.
    - The license plate light wire grommet, even new units do not come with the grommet.
    - Hand throttle knob for 70-71.
    - Heater hose grommets on the fire wall.
  20. #120
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    vent hose grommets.
    license plate light wire grommet.
  21. #121
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
  22. #122
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    rear hinge boots. Industrial grade shore 90A, heavy duty.
  23. #123
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    heater hose firewall grommets
  24. #124
    Supporting Member 240dkw's Avatar
    Member ID
    CZCC-15138
    Join Date
    Sep 2007
    Location
    Powell River,BC, Canada
    Posts
    353
    Default
    Thought you might like to see a few of your parts on a car (Choke grommet,red check valve isolator and early hood bumpers). Very happy with the quality and fit of everything so far.
    Dan
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  25. #125
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    That transmission thinks its hunting season
  26. #126
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Glad that I could help you out, your car looks great.
    Steve
    Quote Originally Posted by 240dkw View Post
    Dan
  27. #127
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    70-71 console choke plate, a reproduction of the best one I could find, after a long search. Only a few minor dings on the plate but very nice.
    I am also working on the square plug.
    1969 240z maplight bezel in gray color.
  28. #128
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I have been working on a few other rare items.
    69 and early 70 plastic hood inspection clips, this is a sample of the smaller version from a 69 240z. I am working on testing the correct plastic type for this application, so they will not break once in use.
    The early round type choke and hand throttle knobs.
    more items are in the works.
    Steve
  29. #129
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Update: 69 and early 70 inspection clips. I tested the clips and after 200 open and close tests, the clips did not break. These are available in a clear amber color. The Black was only a test sample.
    Steve
  30. #130
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I also have the clips in clear, these are just a little more rigid than the amber clips.
    As you can see on the picture that I tested these also and they did not break after 100 open and closes. I will be offering these as a set of 4 clips, 2 amber and 2 clear.
    I will be doing more testing on the clips before I put them up for sale on website.
    Steve
  31. #131
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    choke plate plug for 70-71 center console.
    Reproduction plate also.
  32. #132
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I have added a few new items to webstore.
    Steve
  33. #133
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I have been working on a few new items, one is the rubber seal for the antenna to rear quarter panel.
    The second item, which is still in the development stage, is the voltage regulator 6 prong connector protective boot, this one is gone 99% of the time. Picture of new boot coming later this week.
  34. #134
    Registered User HaZmatt's Avatar
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    I'm working on a large list for you. A lot of these parts transfer over to the 280. How is your car coming along?
  35. #135
    Registered User zcarnut's Avatar
    Member ID
    CZCC-11468
    Join Date
    May 2006
    Posts
    90
    Default Some Items I would like to see you reproduce...
    Handbrake handle and pushbutton. These were never available separately and since NOS handbrakes are NLA we are forced to restore the originals. Unfortunately, these parts are destroyed during their removal.
    Early 240Z wiper motor cover. Before there was the bag Nissan used a plastic cover.
    Speedometer cable and hood opener cable grommet. The very early 240Zs lacked a separate hole in the firewall for the hood opener cable, so Nissan combined it with the speedo cable.
ID:	74373   Click image for larger version.
Name:	wiper motor cover for early 240Z.jpg
ID:	74374   Click image for larger version.
Name:	Hood opener speedo plug.jpg
    Steve Golik
    Huntsville, AL
    1970 240Z
    1974 260Z
    1979 810 Hardtop
    2008 G37S
    "35 years of Z car ownership"
  36. #136
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Quote Originally Posted by zcarnut View Post
    Early 240Z wiper motor cover. Before there was the “bag” Nissan used a plastic cover.
    Speedometer cable and hood opener cable grommet. The very early 240Z’s lacked a separate hole in the firewall for the hood opener cable, so Nissan combined it with the speedo cable.
    I have looked at the handbrake and it seems that the rubber is a different type than the urethane I use. I could do the Speedometer cable and hood opener cable grommet, I would just need a sample for correct measurements. I would also need a good sample of the Early 240Z wiper motor cover.
    Steve
  37. #137
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Quote Originally Posted by HaZmatt View Post
    Ok let me know when ready to order. Not much work on the car over the summer, making and selling parts takes up all my extra time. I have had over 16000 hits on the website and have filled over 100+ orders all over the world, thanks to all who have ordered parts from me.
    Steve
  38. #138
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Thats awesome! Thank you for everything you're doing.
  39. #139
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    preview of the voltage regulator 6 prong plug protective boot.
  40. #140
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    I am also working on the 240z rear interior strut cap, I should have a sample this week.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. fuel line and brake line insulator rubbers id help
    By nix240z in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-10-2013, 01:27 PM
  2. Brake and Fuel line insulator construction
    By GreenZZZ in forum Misc (S30)
    Last Post: 10-30-2011, 10:24 PM
  3. Brake line/Fuel line refinishing
    By kenz240z in forum Tech Pubs and HowTo
    Last Post: 12-11-2005, 08:55 AM
  4. Steering rack grease reservoir, made of plastic???
    By Da Flash in forum Suspension and Steering (S30)
    Last Post: 10-31-2005, 04:25 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
