Results 1 to 19 of 19
Thread: Repaired the dash!
  1. #1
    Registered User
    Member ID
    CZCC-22360
    Join Date
    Aug 2010
    Location
    San Francisco
    Posts
    129
    Default Repaired the dash!
    My friend and I both own 240z's, and both of us had cracked dashes. Also, both of us hate covering up problems so a simple dash cap was not gonna do it. However, we are both lacking in high monetary compensation from our jobs so we decided to experiment and find a cheaper way to repair our dashes. This involved the use of silicone, bondo, light gorilla glue, jb kwik, and finally "Flex Seal".
    We began with the silicone, but quickly found out this really only works well for larger cracks, and also tends to have some small air pockets as well as it tears away from inconvenient cracks, still leaving medium to small size cracks un-repaired. To remove the excess silicone a 3" sanding pad was used on a drill for speed, but in some tight areas, such as around the three small gauges, the 3" is too big and abrasive and starts to dig into the vinyl. However, in certain areas it is necessary to sand down to the foam for a smooth finish, as when the dash splits, the two separated pieces of vinyl stick up. This then led to the use of bondo for the small cracks, which worked for the small cracks, but not the bigger cracks, as it just crumbled out. Then I used some light gorilla glue for some really small cracks, and finally, jb kwik to fix any big crack and small cracks that the previous methods did not work for. In between each method, we sanded with 60, 180, 220, then 600 grit sand paper to make the finish as smooth as possible. We were originally going to use filller primer so I decided not to worry myself, or cause more damage, by sanding some areas down more. However, while at the hardware store, I realized we can use Flex Seal, that stuff you see on TV, and although steep in pricing, $18 a can, is perfect and only one can is needed. It is flexible should the dash flex, it fills in small cracks, its meant for outdoor roof repair so it is good against the sun, and the texture is close, but not exact, to the original dash texture. It worked! However, I later realized I should have sanded down some areas a little more, but it came out with no cracks, original looking, and doesn't add any parts like a dash cap! Now, on with the pictures!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	63616   Click image for larger version.
ID:	63617   Click image for larger version.
ID:	63618   Click image for larger version.
ID:	63619   Click image for larger version.
ID:	63621   Click image for larger version.
ID:	63622   Click image for larger version.
  2. #2
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Nice job Yoshi, you'll have to bring your Z by my place sometime!
    2/74 260Z
  3. #3
    Registered User HermanM's Avatar
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    35
    Posts
    164
    Default
    That looks pretty good man!!! Makes me want to see what I may be able to do with my dash. May have to host a BBQ/Get together in my neck of the woods to see what I can get done
  4. #4
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default
    Wow, wish I'd known about using Flex-Seal a week ago when I had the windshield out for replacement!
  5. #5
    Registered User mlc240z's Avatar
    Member ID
    CZCC-7517
    Join Date
    Dec 2004
    Location
    Central NJ
    Posts
    779
    Default
    Weird question, but what does it smell like?
    Figure it's some kind of rubber based sealer and might stink up the interior when sitting in the sun.
    Bart
    5/71 240z, HLS30-31306, mostly stock, ZTherapy SU's, Pertronix, Eibach ProKit, KYB, Poly bushings, 60 amp alternator w/Dave's plug bypass, headlight and parking light harness upgrades.
  6. #6
    Registered User zhead240's Avatar
    Member ID
    CZCC-5718
    Join Date
    Jan 2004
    Location
    ontario canada
    Age
    66
    Posts
    1,109
    Default
    wow!!!! that's got to be the worse cracked dash I've ever seen. I know you stipulated covering was out of the question but I think a full dash cap would be the way to go. turned out pretty good though.
    to be or not to be- shakespeare
    do be do be do- sinatra
    vehicles owned
    72 240z
    2009 honda civic exl
    1973 triumph tr6
    wife's
    2002 vw jetta
    68 390 mustang coup
  7. #7
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Too late, I guess, but I've got a full dash cap for sale... $50.
    Unfortunately, I'm at the other end of the country:
    There are a couple other pics in the craigslist ad:
    Datsun 240Z 260Z 280Z Dash Pad Cap Cover Nissan
  8. #8
    Registered User
    Member ID
    CZCC-22360
    Join Date
    Aug 2010
    Location
    San Francisco
    Posts
    129
    Default
    That dash cap looks nice! but I personally don't like just covering up problems, I'd rather try repairing them first. Thanks though! And Leon, I will drive over there as soon as the car is back together! Mlc240z, I have yet to put the dash back in the car as I am doing a full rewire, but I had it in the sun all day yesterday when I was installing gauges and what-not and it didn't smell at all, but inside the car it could be a different story, I'll try to keep this updated! I would also recommend to sand more than I did, but hey, live and learn and its still better than before! And thanks everyone else for the words of encouragement! I am also installing new vdo gauges (tachometer, oil pressure, and water temp), as well as an afr gauge as I just rebuilt the engine and the non-working stock gauges weren't cutting it. The oil pressure wasn't installed yet, but the vdo tach looks pretty much factory, and I relocated the gas/amp gauge to the driver side air vent. Probably not to everybody's liking, but hey, I think it's not half bad!
ID:	63641   Click image for larger version.
ID:	63642   Click image for larger version.
  9. #9
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    35
    Posts
    164
    Default
    Dude, you're rockin it! New location looks pretty cool. It's your car, make it how you want it. Thanks for the cool ideas
  10. #10
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    35
    Posts
    164
    Default
    How's the smell on the dash after a few more days?
  11. #11
    Registered User
    Member ID
    CZCC-21483
    Join Date
    Apr 2010
    Location
    Salem, OR
    Age
    37
    Posts
    33
    Default
    Looks pretty good. Here's how mine turned out...
    Before & After
ID:	64126Click image for larger version.
    The after picture is with texture coating only. After the picture I followed it up with SEM Landau black.
  12. #12
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I think when winter comes around again, this will be my next project. The results you guys are getting are excellent. Top job and motivating to say the least.
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  13. #13
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    I love threads like this.
    It inspires me to pull off my dashcap and see what lies underneath. I will have to try this before it gets to hot.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  14. #14
    Registered User
    Member ID
    CZCC-19999
    Join Date
    Sep 2009
    Location
    Tucson Az
    Posts
    696
    Default
    What did you use to texture the dash with?
    1976 280Z
    HLS30288273
  15. #15
    Registered User Hardway's Avatar
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    That looks GRRREEEAAAAAAAAAAAAAAT Scaotty! Please tell us more of what you used and where you got it. I bought a half cap for mine but now I thinking the same as EuroDat and Z_K of pulling mine over the fall and repairing it like you did. If you have any more pics we would love to see them as well.
    08/1970 240z Series-1 #8011 - Silver, black int., 2.4L I-6, 5spd, 90% restored.
    06/1973 VW Karmann Ghia - Black convertible, 4spd, 1600cc air-cooled engine.
    11/2013 Scion FR-S - Silver, 6spd, a car with the soul of a Z for the modern times.
    Restoration thread of my old '72 240z -> http://www.classiczcars.com/forums/o...1972-240z.html
  16. #16
    Registered User
    Member ID
    CZCC-21483
    Join Date
    Apr 2010
    Location
    Salem, OR
    Age
    37
    Posts
    33
    Default
    A friend of mine and I restored it. He builds and customizes dashes for a living. He does fantastic work as you can see. Im not sure of all the materials he used, but I know we used SEM texture paint. If anyone is interested in having theirs done, I can guarantee his price would be much more fair than most dash restoration places. Here is the final result.Click image for larger version.
ID:	64187Click image for larger version.
  17. #17
    Registered User
    Member ID
    CZCC-28860
    Join Date
    Dec 2012
    Location
    Charlotte NC
    Posts
    24
    Default
    Great work guys!
  18. #18
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    35
    Posts
    164
    Default
    Y'all have convinced me (who has no experience in dash repair) to repair my own as well. I will be picking up a spare dash for my early 260 soon and starting to restore it following everyone's tops and posts but I will be trying to do this with items that I can pick up at the local hardware store on a decent budge that anyone can do. Here goes nothing... Looking forward to seeing some results and sharing my progress
  19. #19
    Fumblin'Bumblin Z car fan
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    50
    Posts
    111
    Default
    I am going to do the same, with a spare 240 dash I have lying around. I'll post progress/results as well. If its any good, I'll install it in my project car and then fix the other one, and maybe sell it....start a mini business here in GA....to pay for the car..
Thread Information
Users Browsing this Thread
Similar Threads
  1. Can this crank damper be repaired?
    By Hype in forum Engine and Drivetrain (S30)
    Last Post: 10-10-2012, 10:12 PM
  2. Replies: 11
    Last Post: 10-03-2012, 06:19 AM
  3. can this rear quarter panel be repaired
    By 03redzo6 in forum Body and Paint (S30)
    Last Post: 08-19-2011, 03:30 AM
  4. Can Shelby wheels be located or repaired?
    By mikemeade in forum Wheels, Tires and Brakes (S30)
    Last Post: 08-11-2006, 07:56 AM
  5. rear end damage repaired I need some info.
    By beandip in forum Body and Paint (S30)
    Last Post: 09-02-2004, 12:33 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
