Results 1 to 10 of 10
Thread: Vacuum lines wrong and runs funky
  1. #1
    Registered User
    Member ID
    CZCC-29469
    Join Date
    Jul 2013
    Location
    Sacramento
    Age
    51
    Posts
    6
    Default Vacuum lines wrong and runs funky
    I need help with a 1977 280z. All the vacuum lines on the car where messed up and disconnected when I got it and I can't find a diagram anywhere. I guessed on a few. The car runs great for a minute then like garbage then great then garbage. It's really hard to start when she's cold and the rpm's are at 2000 until it warms up. It's not a CA car and has a 5 speed. Anyone know what the heck is going on
  2. #2
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default
    Here's a link to the Factory Service Manual (FSM) on the 1977.
    http://www.xenons30.com/files/FSM/77_datsun_280z.zip
    There should be a vacuum line diagram in there in the emissions section.
    Truly the fastest method would be to chase down another 280Z and take pictures, draw diagrams. The FSM is ...obtuse.
    I rather doubt your cold starting problems are related to vacuum lines. More likely your Auxiliary Air Valve isn't functioning properly, and/or your cold start injector isn't squirting. Suggest you SEARCH on AAV here and read up on theory of operation, cleaning/testing replacing.
  3. #3
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    Wade, the FSM is among the best I've seen for any car -- well organized, comprehensive, good diagrams. I don't know why you think it's obtuse.
    If half of the vacuum lines are hanging open, that could result in a rather lean condition, but I agree with Wade that your problems are probably greater than just vacuum lines. The 280's engine isn't particularly complicated. I'd recommend just going over it from end to end. Check and verify each part and move to the next. Pay special attention to the electrical connectors. Get them clean, and goop them with a bit of dielectric grease. The most problematic connectors are on the front of the engine on the thermo housing -- thermotime switch and coolant temp sensor.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  4. #4
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Posts
    692
    Default
    Fast -- I agree, it's a GREAT manual --- better than most. But the FSM vacuum line diagrams are virtually IMPOSSIBLE to translate into real world "this hose goes from here to here..."
    As often is the case with manuals, it makes PERFECT sense AFTER you get it all hooked up correctly...
  5. #5
    HLS30-454423 3/78 Virto's Avatar
    Member ID
    CZCC-9429
    Join Date
    Sep 2005
    Location
    Elgin, Illinois
    Age
    40
    Posts
    542
    Default
    Click image for larger version.
    Sadly I agree. The FSM as a whole is great, but the diagram for vacuum hose and fuel piping is not the easiest to read.
    Here is a better copy of it that I found on the internet. I'm in the same boat, preparing to rework all the lines - so I just happened to be looking for it last night.
    Kelly R. Johnson
    1978 280Z...yes it's automatic...but I'm fat.
  6. #6
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    That's the same diagram in my FSM for 75. If you're talking about the vacuum lines for the HVAC controls that's a different story, they are usually brittle and somewhat difficult to get placed on the proper ports, and you must constantly refer to the FSM diagram and trace all the lines.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  7. #7
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Many of the hoses came from the factory labeled with a letter on a small piece of tape. If you're lucky the piece of tape is still there. If you change a hose, move the label or put a new one on. The letters correspond to the diagram.
    1976 280Z, with some minor modifications
  8. #8
    Registered User
    Member ID
    CZCC-30910
    Join Date
    Oct 2014
    Location
    graham wa
    Posts
    1
    Default
    I need help with my 280zx 81 (2+2) model it was a turbo but the turbo got taken out by previas owner.
    The vaccume lines are all messed up any help
    SHUTS OFF UNTILL WORMED UP VACCUME ISSUE!!!
  9. #9
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Quote Originally Posted by Alexyu View Post
    You should start your own thread and put a little more work in to describing the problem. Can't tell what the question is. The caps and exclamation points don't really add anything.
  10. #10
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Ditto on putting the labels on the ventilation hoses. You might also make notes on the size and how long each is for the next time.
    Drive Responsibly.
    enjoy classic Rock music.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 1
    Last Post: 09-01-2012, 12:53 PM
  2. Who's got a 1980ishZX with vacuum lines all intact?
    By Wade Nelson in forum Engine and Drivetrain (280ZX)
    Last Post: 04-03-2012, 11:44 AM
  3. Need help with Vacuum lines, and identifying a part!!!!
    By e_yates_280zx in forum Engine and Drivetrain (280ZX)
    Last Post: 10-07-2011, 07:38 AM
  4. help with vacuum lines
    By 280ZCR8ZEE in forum Engine and Drivetrain (S30)
    Last Post: 04-24-2009, 10:20 PM
  5. Vacuum Lines for heater controls
    By TomoHawk in forum Misc (S30)
    Last Post: 08-11-2005, 08:06 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
