Results 1 to 12 of 12
Thread: New LED headlights
  1. #1
    Registered User
    Member ID
    CZCC-18739
    Join Date
    Feb 2009
    Location
    Louisville, KY
    Posts
    328
    Default New LED headlights
    I found this on motortrend yesterday. Aside from the bar across the center of the headlamps these look like they could be a good upgrade over our standard lighting. However, they are quite pricey.
    Bright Eyes for your Retro Ride?Peterson 701C LED replacement lamps. - Motor Trend Blog
  2. #2
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    56
    Posts
    873
    Default
    Little too expensive for me! Would have to come down half in price to consider it.
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    I have been very pleased with H4 lights and relays, and I will stay very pleased until the price comes down a lot on LED headlights.
    Note: To use LEDs in the S30 you WILL need to use relays or do extensive re-wiring. A couple of years ago, someone started a thread on installing LED headlights. He could not understand why they did not work. The LED headlights expect the 12VDC positive to come from the high/low beam switch with a common ground. In the Z, the headlight circuit is wired to provide a common 12VDC positive to the headlight and switches the ground between the high and low beams. Since the D in LED stands for diode, it means that current can only flow in one direction.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    Registered User
    Member ID
    CZCC-18739
    Join Date
    Feb 2009
    Location
    Louisville, KY
    Posts
    328
    Default
    Honestly, I can't complain about my headlights either. I have some cheapie sealed beams and a homeade relay harness.
    Too bad running LED's would require even more work to the current wiring. That kind of defeats the point of taking some load off of the original wiring.
  5. #5
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    As long as your relays switch the positive and not the negative, you wouldn't need to change that. Give the choice between adding relays or re-wiring, I would choose relays.
    73 240Z
    74 260Z
    Georgia Z Club
  6. #6
    Default
    I'm with SteveJ.
    Dave Irwin made a wiring harness for my stock 280 Z a few years ago and the headlights work great.
    76 280Z
  7. #7
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    By the way, I found the old thread I was referring to: http://www.classiczcars.com/forums/e...headlamps.html
    73 240Z
    74 260Z
    Georgia Z Club
  8. #8
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    In 1970 the Cibie Biode's were about #120.00 a pair. I guess adjusted for inflation - $500.00 to $600.00 today is about right.
    FWIW,
    Carl B.
  9. #9
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Quote Originally Posted by Carl Beck View Post
    FWIW,
    Carl B.
    But who wants 60 pound headlights?
    73 240Z
    74 260Z
    Georgia Z Club
  10. #10
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    56
    Posts
    873
    Default
    Dave also made me a PL harness and HL harness upgrade. They work perfect.
  11. #11
    Registered User Dr. 240Z's Avatar
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    New Brunswick Canada
    Age
    68
    Posts
    228
    Default
    Hi,
    Here's an alternative to sealed beams/LED's that really works well: Wire in Dave's HL harness and purchase a pair of Cibie H4's (google: Daniel Stern)
    Go with the bulbs DS recommends. I did and I'm very pleased as the illumination is as good as the xenons I've owned.
    Cheers,
    George
    Original Registration and Warranty Card
    Original owner of: HLS3018859 (Jan./71) ZCOOR Member # 178
    'Storms Never Last'
  12. #12
    Registered User
    Member ID
    CZCC-25800
    Join Date
    Dec 2011
    Location
    Central Coast California
    Age
    31
    Posts
    3
    Yep I saw them a few days ago. The stock cj headlights are so weak. Wish I could try the LED before I buy.
Thread Information
Users Browsing this Thread
Similar Threads
  1. No Headlights?
    By seattlejester in forum Help Me !!
    Last Post: 07-05-2012, 08:31 PM
  2. headlights
    By intangible3 in forum Help Me !!
    Last Post: 10-07-2010, 08:17 PM
  3. Help with headlights
    By 7277 in forum Electrical (S30)
    Last Post: 03-03-2008, 09:50 PM
  4. Dim headlights
    By 1 Bravo 6 in forum Open Discussions
    Last Post: 01-24-2005, 04:03 PM
  5. headlights (heehee..headlights...)
    By z_pyro in forum Electrical (S30)
    Last Post: 06-05-2002, 07:40 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
