Results 1 to 10 of 10
Thread: S30 Gas Tank - Paint Finish
  1. #1
    Registered User
    Member ID
    CZCC-28430
    Join Date
    Oct 2012
    Location
    Burlington, Ontario, Canada
    Posts
    37
    Default S30 Gas Tank - Paint Finish
    A very quick question for you wise folks - is the paint finish on the gas tank of my 1971 240 a gloss black or semi-gloss black ??
    Thanks
    Hank
    Hank
    1971 - HLS3034789 (silver, L28,5Speed, AZC suspension, Wildwood brakes,etc) - oh so close
    1971 - HLS3023650 (yellow, third owner all stock) - resto complete and sweet
  2. #2
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    I'd call it a gloss black - because when it was new, you could wash and wax the gas tank to bring out a high gloss.
    FWIW,
    Carl B.
  3. #3
    Registered User
    Member ID
    CZCC-28430
    Join Date
    Oct 2012
    Location
    Posts
    37
    Default
    Thanks so much for the quick reply Carl. As always, you are a wealth of knowledge.
    Hank
    Travel'n Man likes this.
    Hank
  4. #4
    Registered User jerz's Avatar
    Member ID
    CZCC-18775
    Join Date
    Feb 2009
    Location
    Kent, United Kingdom
    Posts
    36
    Default
    Here are a couple of photographs of a NOS S30 tank for reference, albeit a later version, but the same finish as on a 1971 model.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	66975   Click image for larger version.
  5. #5
    Registered User
    Member ID
    CZCC-28430
    Join Date
    Oct 2012
    Location
    Posts
    37
    Default
    Excellent. Thanks for the pics jerz.
    Hank
  6. #6
    Registered User
    Member ID
    CZCC-24101
    Join Date
    Apr 2011
    Location
    KY
    Posts
    393
    Default
    I know that this is not really part of this post; however, I thought it might be ok to tag on. I have a slight gas leak and it appears it is coming from the tank. Last year I dropped the tank and got out a ton of rust, acid cleaned and red koted. The rust must have been keeping a small hole from leaking and the red kote did not fully seal up.
    Any suggestions.
    How about a coating on the outside of the tank that might seal up the small pin hole? How about welding on the tank. I have seen other posts with tank welding. The school where I teach has a very good welding program and thought I would ask but not sure if ssafe.
    Thanks in advance.
  7. #7
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    check the fitting for the send and return, they can de-solder.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  8. #8
    Registered User
    Member ID
    CZCC-24101
    Join Date
    Apr 2011
    Location
    KY
    Posts
    393
    Default
    One reason I suspect the tank is that I believe the gas completely leaked out causing the car not to start. Not sure because the car had sat for a while and I charged the battery and added gas at the same time. I replaced all of the fuel lines at the tank, added 2 gallons of gas, and immediately took the car to the paint shop about 50 miles away. Thought that the leak was fixed (50 miles on 2 gallons); however, the paint shop said it was still leaking gas. They are looking at it to see if they can determine location. Again car is about an hour away and I have just not got an opportunity to look at myself.
    Suspected sending unit o-ring but there should be some gas below that to start car. Maybe just not thinking about this correctly.
  9. #9
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    50
    Posts
    468
    Default
    I think welding is a bad idea. A good welding program can probably do it without blowing themselves up (i.e. clean the tank, nitrogen purge etc.) but the coating on the inside will burn or char and if the metal has pinholes it will be hard to weld on it with out burning more holes in the thin metal of the tank. I had pin holes like this on one of my f-350's tanks where mud had collected on the tank and rusted pinholes in it. I got some stuff from advance auto. I believe it was called goop. It is a fuel safe product in a tube where the sealants are in the store. I put a couple of coats over the area on my tank with it empty of fuel. That was years ago, leaks never came back...I drive it nearly every day.
    Charles
  10. #10
    Registered User
    Member ID
    CZCC-24101
    Join Date
    Apr 2011
    Location
    KY
    Posts
    393
    Default
    The gas leak is a pin hole in the tank. Apparently at some point in its life one of the straps was in contact with the tank without the protector in between. When I dropped the tank some time back it must have caused the pin hole. I believe I will try the stuff from advanced auto or use jb weld. I would also like to recoat the outside with red kote or similar product.
Thread Information
Users Browsing this Thread
Similar Threads
  1. What paint finish for best value when sellling?
    By Webmanic70 in forum Body and Paint (S30)
    Last Post: 09-26-2013, 02:50 PM
  2. After 6 years, I need to finish it!
    By matria in forum Help Me !!
    Last Post: 09-01-2012, 04:29 PM
  3. I need the following to finish my 240....HELP
    By mally002 in forum Open S30 Z Discussions
    Last Post: 10-13-2010, 04:59 AM
  4. Tank paint finish question
    By 240znz in forum Body and Paint (S30)
    Last Post: 09-12-2008, 06:17 PM
  5. finish this 240?
    By Darrel in forum Open Discussions
    Last Post: 07-25-2006, 09:24 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
