Results 1 to 17 of 17
Thread: Electronic Ignition kit
  1. #1
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default Electronic Ignition kit
  2. #2
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Or know where I can get one in Australia?
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Can you get a Pertronix Ignitor in Australia?
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Just looked into it and looks like I can get it from bursons. Will try them tomorrow. Have you used that product?
  5. #5
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Personally, I have not, but lots of people in the 240Z world have. Search through the archives here. You'll find plenty pro & con.
    73 240Z
    74 260Z
    Georgia Z Club
  6. #6
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    Curious how you go mate
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  7. #7
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Went to bursons today and unit alone was 235 bucks. Went online and got same unit and high voltage coil for 160 delivered from u.s. I try to shop local but sometimes I just can't.
  8. #8
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    Review it for us when it's fitted
    Adam
  9. #9
    Registered User
    Member ID
    CZCC-29592
    Join Date
    Sep 2013
    Location
    Perth
    Posts
    39
    Default
    I'm in the US at the moment and bought a Petronix kit and coil. Will let you know how it goes when I fit it.
  10. #10
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Will have to wait a few weeks for mine but will keep you posted as well.
  11. #11
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Quote Originally Posted by Perth 240 View Post
    I was reading some of the posts in z section and saw they where buying reco dizzys for $125ish. So jealous of the parts prices in the U.S.
  12. #12
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Got my kit today, fitted it up easy as. I also replaced my dizzy with a spare one that had no play in the shaft which was probably most of my problem. Anyway kit in and set timing, had very smooth idle and still yet to drive. Plenty of pics in z section which explain it well. Only question I have is my original coil is 1.5 ohm with an external resistor of 1.6 ohm. Instructions say to leave all resistors in place but my new coil is 3 ohm so should I remove external resistor? Will hit the z section again I think. Will update when I drive it.:-)
  13. #13
    Registered User
    Member ID
    CZCC-29592
    Join Date
    Sep 2013
    Location
    Perth
    Posts
    39
    Default
    So I'm back and have installed the Pertronix kit, I got the ignitor 2 kit with the matching coil. Car starts well, and runs smoother. Definitely winds out a lot better than before. However, one unforeseen problem, is that with 36yo wiring there is a bit of a voltage drop at the coil, and at night when my headlights are on this gets worse. The module in the ignitor kit cuts out below a certain voltage, and at night with headlights, brake lights and indicator at idle the voltage drop will cause the car to stall.
    Obviously this isn't ideal, so I intend to run power from the battery to the coil, running it through a relay using the ignition power to switch it. This should keep voltage at the coil pretty constant irrelevant of revs/electric use. Will let everyone know how this fix goes.
  14. #14
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Turns out the resistor is only a noise suppressor. Perth 240 other option is to upgrade to 50 amp alternator which is what I am thinking of doing.
  15. #15
    Registered User
    Member ID
    CZCC-29592
    Join Date
    Sep 2013
    Location
    Perth
    Posts
    39
    Default
    is the 50amp alternator off a later model L motor, or somewhere different? Is it a direct bolt up, or is there some mucking about?
  16. #16
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Can't tell if you guys are driving 240K's or 240Z's but the 60 amp alternators from some of the late North American market 240Z's, 260z's and 75-77 280Z's used a 60 amp alternator with the external voltage regulator. Should be a straight bolt-in.
    1976 280Z, with some minor modifications
  17. #17
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    Thanks Zed Head, we both have 240k's. 60 amps would be great, mine doesn't stall but I do get some good fluctuation on my amp meter at idle(before and after ignition upgrade).
Thread Information
Users Browsing this Thread
Similar Threads
  1. Electronic Ignition Help
    By matt240Zee in forum Electrical (S30)
    Last Post: 09-14-2011, 01:07 AM
  2. electronic ignition
    By jorde in forum Engine and Drivetrain (S30)
    Last Post: 03-31-2009, 03:53 AM
  3. Electronic Ignition... DONE!
    By ZSaint in forum Engine and Drivetrain (S30)
    Last Post: 05-12-2006, 05:14 PM
  4. Electronic ignition
    By tanny in forum Open Discussions
    Last Post: 02-22-2003, 04:35 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
