Results 1 to 14 of 14
Thread: Wheel size 225/50/16 +6 off set will work?
  1. #1
    Registered User
    Member ID
    CZCC-28399
    Join Date
    Oct 2012
    Location
    black mountain
    Age
    49
    Posts
    99
    Default Wheel size 225/50/16 +6 off set will work?
    Has anybody tried it . I have looked but no real answer ... I think it will but thought maybe someone out there has tried it . Found some bought but never used for sale and am a little wary
    Thanks
    Dc
    1972 240z
  2. #2
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Dc, Thats the tyre size your quoting. Sort of depends on how wide the rims are and the brand of tyre also makes a difference. Are you using rolled fenders, car lowered etc?
    Basically not enough information so someone can give you any sort of reliable answer.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  3. #3
    Z Club of San Diego Montezuma's Avatar
    Member ID
    CZCC-10665
    Join Date
    Feb 2006
    Location
    San Diego
    Age
    56
    Posts
    1,063
    Default
    Coilovers? The fenders will have to be cut and overfenders will most likely be required...besides most likely coilovers.
  4. #4
    Registered User
    Member ID
    CZCC-28399
    Join Date
    Oct 2012
    Location
    black mountain
    Age
    49
    Posts
    99
    Default
    Sorry about that the wheels are panasports the ad just says that they are 225/50/16 +6 offset . The owner said they would not rub but I know they would be real close. I have two cars one is lowered 1" (don't think it will work) second car is a 71' with stock suspension. (maybe) nankang tire (never heard of it )
    hope this helps
    Thanks for input
    1972 240z
  5. #5
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    I plugged the following assumptions into a wheel offset calculator: stock wheel width 5" and zero offset, new wheel width 6", +6mm offset and got this back: inner clearance reduced by 19mm (about 3/4"), outer position extended by 7mm. If the Panasports are 7" wide the new numbers are: inner reduction 31mm, outer extension 19mm.
    That's why EuroDat asked about the true wheel size - it makes a difference. Those 225's will probably rub on the lowered car.
    1010TIRES.COM - Wheel Offset Calculator
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  6. #6
    Registered User an_unusual_eye's Avatar
    Member ID
    CZCC-25394
    Join Date
    Oct 2011
    Location
    raleigh, nc
    Age
    49
    Posts
    101
    Default
    205/55/16 on 16x7 pana -6 with a ~1.25" drop rubbed the front valance at lock. had to roll the lip with a 1/2" drive socket extension after chewing up a tire. 225 MIGHT be okay everywhere but at the valance.
    ~ rob.
    harrisburg, pa / raleigh, nc
    triangle z club
    1974 260z (early) ~ 302 green/black (sold)
    1971 240z (late) ~ 901 silver/black (sold)
    1978 280z 2+2 ~ 611 burgundy/black (parted out)
    1971 240z (early) ~ 907 green/black (my long term mistress)
  7. #7
    Registered User
    Member ID
    CZCC-28399
    Join Date
    Oct 2012
    Location
    black mountain
    Age
    49
    Posts
    99
    Default
    I am more interested on a stock car . I am in the process of buying a stock car with some ugly rims . I have 14" rewinds I my other one . Thanks for the time in putting it in the calculator. I have learned a bunch on off sets . Man I wish they were 15"
    1972 240z
  8. #8
    Registered User
    Member ID
    CZCC-10869
    Join Date
    Feb 2006
    Location
    Irvine, California
    Age
    49
    Posts
    755
    Default
    225s on a +6 offset (assuming they are 7-in. wide) may hit the front valence. When I was running 14x7 Western Turbines with 225/60 I would clip the front valence.
    I have 16x8 +10 on my car now with 245/50 tires. I need a 10mm spacer to clear my Toyota S12/w calipers. If I had stock calipers a 5mm spacer would probably suffice to help the tires clear the spring perch. I do not have a spacer in the rear but trimmed the spring perch for the 2mm or so of clearance I needed.
    My car is also dropped 1-inch. I rub on the fenders and wound up rolling them. A 225 tire should not rub.
    A 225 tire on a +6 wheel (assuming its 7 or 8 inches wide) should have no clearance issues save for the front valence. Again, I have 245mm wide rear tires on a +10 8-in. wide wheel and I barely rub on severe transitions in the road when the rear compresses. A 225mm tire on a +6 7-in. wide wheel should be ok.
    If you are really concerned, you can always test fit if the buyer will let you. The front is more of a concern than the rear.
    -Bo
    1972 240z - Not original and still not done.
    "Something wicked this way comes...."
  9. #9
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    225/50R16 on a 7" rim with +6mm offset should fit pretty well depending on the actual tire brand/model. From everything I have seen and read, there is car to car variability that will determine if you clear or rub. If you can get them for a decent price, go for it. Panasports are in high demand and you can always resell them if they rub more than you are willing to live with. I run the same, but with zero offset and they rubbed heavily until I trimmed the rear fender pinch flanges. If I had +6mm rims, they would have likely still rubbed, but a simple rolling would have fixed the issue rather than the need for trimming. The fronts will likely rub until you trim the valence and adjust it away from the tire path. Like new Panasports in that size are worth $800+. Depending on what the tires are, they could be worth another $200 - $400.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  10. #10
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    I have a set of 225/50R16 tires on 16X7 Panasports on both of my Zs. I think one set is +6 offset and one is 0 offset, but I got both sets secondhand. After mocking up both sets on one car, I think the tires make a bigger difference than the slight offset (although that helps). The RE-11As on the green car are quite a bit "bulgier" than the Turanzas on the orange car.
    The facts...
    - Orange car is on +6 offset with very old 225/50R16 Bridgestone Turanza rubber.
    - Green car is on +0 offset with 225/50R16 Bridgestone RE-11A rubber.
    - Green car has +0 deg of rear camber, orange car has -1.5 deg.
    - Green car has trimmed rear arch lips and front valence
    - Orange car has aftermarket air dam
    - Zero rubbing on either setup
    - Switch sets between the two and fatter rears will rub on orange car
    Click image for larger version.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    2/74 260Z
  11. #11
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    I just put a set of 16X8 rims with +0 offset and 205X55X16 tires on stock suspension with no issues, I've been told by my tire guy that you can actually use up to +20 offset, but I'm not real sure I'd try that setup. Just my 2˘.
    Mike
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  12. #12
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Mike
    75 280Z almost done
  13. #13
    Registered User
    Member ID
    CZCC-23182
    Join Date
    Dec 2010
    Location
    Mid-Atlantic
    Age
    49
    Posts
    148
    Default
ID:	70334Click image for larger version.
    These are 225/50/R16 on Konig wheels with no offset. They rubbed all the way around even with the fenders rolled.
  14. #14
    Fumblin'Bumblin Z car fan
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    50
    Posts
    111
    Default
    I am thinking 215/45/16. Think that would solve the issue, with the Konig Panasport knockoffs at 16X8 +6?
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Wheel size verification
    By ksechler in forum Wheels, Tires and Brakes (S30)
    Last Post: 12-21-2012, 08:43 PM
  2. Wheel size and tire size specific to performance driving
    By BTF/PTM in forum Wheels, Tires and Brakes (S30)
    Last Post: 01-18-2012, 07:35 PM
  3. Wheel size help?
    By monkytwn in forum Help Me !!
    Last Post: 01-04-2012, 02:08 PM
  4. Wheel lug size?
    By GunnerRob in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-02-2004, 04:04 PM
  5. Wheel size
    By psimkin in forum Wheels, Tires and Brakes (S30)
    Last Post: 08-21-2003, 09:30 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
