Results 1 to 7 of 7
Thread: 1972 240z gas tank
  1. #1
    Registered User
    Member ID
    CZCC-30237
    Join Date
    Mar 2014
    Location
    clarksville tn
    Age
    26
    Posts
    18
    Default 1972 240z gas tank
    I just bought 72 240z and there is rust in the gas tank/fuel lines. What is the best way to fix this without replacing the parts, and if i have to replace the parts where can i find them
  2. #2
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Here's a start, Z Tech Tips Ball and Socket Compression Rod (AtlanticZ.ca).
    I did it and coated mine with Red-Kote.
    EDIT; It's not about ball and socket compression rod, it's how to rehab your gas tank, click on it.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  3. #3
    Registered User
    Member ID
    CZCC-30237
    Join Date
    Mar 2014
    Location
    clarksville tn
    Age
    26
    Posts
    18
    Default
    I used an air compressor o blow rust out of my fuel lines and put an octane booster in the gas that i was told would break up the rust for me. Cleanedy filter out and got a huge pile of rust. Hopefully this will solve the issue with a couple weeks of repeated filter cleanings.
  4. #4
    Registered User
    Member ID
    CZCC-29883
    Join Date
    Nov 2013
    Location
    Portland, Or
    Age
    70
    Posts
    283
    Default
    Many years ago as I was driving my 71, the speed suddenly dropped to 45mph. 2nd, 3rd or 4th gear, same thing, 45mph. The engine would still sing at 6000rpms with the clutch in. It ran great up to 45, then nothing, no cut-out, no more power. My dad was the riding mechanic that day. Fortunately for me, he knew that it was lack of fuel & and it didn't matter what gear I was in, the engine only had enough fuel to push the car that speed. We pulled to the roadside, pulled the clear filter on the fire wall, blew it out ,yuck!, reinstalled it & problem was cured. I did change the filter that same day. I've shared this because it's possible you may run into this symptom in the future. It may be a good idea to carry spare filters & tools to replace them for a while.
    Mark in Portland
  5. #5
    Barn Find Daily Driver Captain_Zeros's Avatar
    Member ID
    CZCC-21373
    Join Date
    Apr 2010
    Location
    Kirkland, WA
    Age
    30
    Posts
    316
    Default
    Hah, just an aside, I also had a 45 mph clogged filter once, it just took me more than one day to find it though. Had to stick to surface streets!
    1973 240Z w/ roundtop carbs, 280zx e12-80 distributor, 280zx alternator, late model Altima junkyard electric fans. 115 Blue Metallic & white side stripes.
  6. #6
    Registered User
    Member ID
    CZCC-30237
    Join Date
    Mar 2014
    Location
    clarksville tn
    Age
    26
    Posts
    18
    Default
    When my filter clogs it just kills the car. I used a compressor to blow out the fule lines and put a magnet in the tank as a temporary solution untill i have time/money to fix the tank
  7. #7
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    If the lines are bad, my Dad cleaned some in an old truck he had by blowing a heavy fishing line through the line with a compressor. Then tied a .22 caliber wire gun cleaner tip and pulled it through. He had to do it a few times because of the rust but it must have worked, he drove it for years. I'd be scared of getting it stuck myself but you don't necessarily have to use the gun cleaner, maybe something smaller?
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 1972 gas tank in a 1971 240Z?
    By steve91tt in forum Help Me !!
    Last Post: 05-03-2011, 07:37 AM
  2. 1972 gas tank rusted out
    By T-stone in forum Help Me !!
    Last Post: 08-06-2010, 10:46 AM
  3. 1972 240z
    By gaetano in forum Help Me !!
    Last Post: 09-17-2009, 05:50 AM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
