Results 1 to 10 of 10
Thread: Tachometer does not go over 500 rpms. What can cause this?
  1. #1
    Registered User
    Member ID
    CZCC-29487
    Join Date
    Jul 2013
    Location
    Norway
    Age
    30
    Posts
    31
    Default Tachometer does not go over 500 rpms. What can cause this?
    Hi!
    I have a problem with my tach. It only goes up to 500 rpms. It moves a little bit when I rev the engine, but no more than 550rpms at the most. When I stop the engine it goes back to 0 rpms, so there is a signal there.
    What is most likely to be the problem here? I just got a new 1.6ohm resistor and the coil is stock (I think).
    Regards,
    Tomzern
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Do you have a ballast resistor? Is it a 4 wire or 3 wire tach?
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  3. #3
    Registered User
    Member ID
    CZCC-29487
    Join Date
    Jul 2013
    Location
    Norway
    Age
    30
    Posts
    31
    Default
    In my first post I wrote that I just installed a new ballast resistor. The car runs as normal. I don't know if the tach is 3 or 4-wire, but the car is a 1970-model and the tach has a small square connector if that tells you enough?
    Thanks,
    Tomzern
  4. #4
    Registered User
    Member ID
    CZCC-29487
    Join Date
    Jul 2013
    Location
    Norway
    Age
    30
    Posts
    31
    Default
    Anyone? =)
  5. #5
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Why did you get a new resistor? What's the resistance of the coil you're using. You're not giving much information.
    I've read that the 240Z tachs require a certain amount of current in the wire to the tach. You might have too much resistance on your primary circuit. Maybe you don't need that resistor.
    1976 280Z, with some minor modifications
  6. #6
    Registered User
    Member ID
    CZCC-29487
    Join Date
    Jul 2013
    Location
    Norway
    Age
    30
    Posts
    31
    Default
    Sorry about that :/
    I bought a new coil resistor because I read somewhere that if the coil was a stock type the correct resistor value would be 1,6ohm. I measured the one I had to be 2,2ohm and the tach didn't work so I thought a new resistor with a lower value would fix it, but no.
    So you suggest I should try to bypass the resistor? Can't that be harmful to the tach?
  7. #7
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    What is the resistance on the coil? The 1972 points coils had a resistance of 1.5 to 1.7. Looks like the resistor is 1.6 ohms, as you saw. So total resistance on the primary circuit would be 3.1 to 3.3 ohms. Maybe you have a low resistance coil and you need more resistance. Or a different coil.
    Sorry, I might be confusing things. It's better to give too many facts rather than one at a time. If everything is right in the ignition system, it might just be bad tachometer. Has the tachometer ever worked correctly?
  8. #8
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    56
    Posts
    631
    Default
    Using the incorrect ballast resistor won't hurt the tach but it can damage the coil and points if the resistance is too low or it is removed. From what you have said it sounds like the tach is bad. Check the wiring at the back of the tach. It needs 12 volts and ground from the primary circuit in addition to the signal from the coil.
  9. #9
    Registered User
    Member ID
    CZCC-29487
    Join Date
    Jul 2013
    Location
    Norway
    Age
    30
    Posts
    31
    Default
    Hi again
    So I measured the voltage on the coil with the ignition turned on and it was only 3-4 volts. I then tried to bypass the resistor and got the voltage on the coil up to about 6-7 volts (where it should be). Tried to start it with the resistor bypassed, but the tach is still not working. Only shows about 500-600 rpms, and the needle moves just a tiny bit when I rev the engine.
    Tried with a different coil and the resistor still bypassed. Measured the coil voltage to 8-9 volts, but tach still not working, so maybe it is the tach itself that is faulty.
    I have just driven the car about 200 meters after I bought it, and the tach did not work then either, but I found out I had the wrong engine wiring harness and thought that could be the reason, but no.
  10. #10
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Age
    56
    Posts
    631
    Default
    It sounds like you have voltage drop in the wiring to the ballast and coil. There should be a solid 12 volts before the ballast and about 9 volts after the ballast (on the coil).
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Hesitation when increasing RPMS
    By JoelZ in forum Engine and Drivetrain (S30)
    Last Post: 03-22-2010, 05:35 PM
  2. No power over 4000 rpms...
    By code3z in forum Engine and Drivetrain (S30)
    Last Post: 01-25-2007, 07:08 AM
  3. Automatic Tranny RPMs?
    By Montezuma in forum Engine and Drivetrain (S30)
    Last Post: 09-23-2006, 06:44 AM
  4. car misses at high rpms (4500)
    By e_racer1999 in forum Engine and Drivetrain (S30)
    Last Post: 09-11-2004, 08:19 AM
  5. rpms/transmission question
    By go z racer, go in forum Open Discussions
    Last Post: 05-07-2003, 04:10 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
