Results 1 to 3 of 3
Thread: R200 Parts Search
  1. #1
    Registered User
    Member ID
    CZCC-28130
    Join Date
    Sep 2012
    Location
    Southern Calf.
    Posts
    2
    Default R200 Parts Search
    I've got a 1971 240Z with an R200 rear and a SBC 383 stroker motor. The beast is making around 450 HP and has worn out the rear end. I'm looking for a source who can provide a new ring and pinion set hopefully with a ratio of 3:70 (It currently has a 4:ll in it and that's to much). I'm open to any and all suggestions.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    I think that I saw your post on another forum about the same issue. It will be much easier to just source a complete R200 differential. You have to take the whole thing out anyway to replace the ring and pinion. They're not like Fords or Chevys that can be serviced from underneath the car.
    The easiest direct replacement for you would be a 3.7 R200 from a 1979 280ZX. Everything will be the same as what you're using now (unless somebody swapped in a 1975 R200, which are unique in the driveshaft bolt pattern). Second easy is a Z31 R200. You'll need to swap the pinion flanges because the Z31's use a different bolt pattern (oddly, they use the 1975 280Z bolt pattern, apparently).
    If you want new there's always Nissan. Spendy. Here's the cost of a 3.54 ratio R200 - CARRIER-W/ :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com You'd have to ask around to get the part number for a 3.7.
    Good luck.
    1976 280Z, with some minor modifications
  3. #3
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    60
    Posts
    1,374
    Default
    New R&P for long nose R200s are basically NLA. You might get lucky if you call Nissan Motorsports directly and they can find something on the shelf.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1972 Odd Parts Search (Wiper & Heater Restoration)
    By cnwayland in forum Open S30 Z Discussions
    Last Post: 06-09-2013, 07:38 PM
  2. Parts for R200 swap...
    By CarolinaTZ in forum Suspension and Steering (S30)
    Last Post: 10-17-2010, 07:59 PM
  3. Power Brute Group Buy R200 Carrier (Best PB They Make for R200) - $450
    By Mike1234 in forum Engine and Drivetrain (240K)
    Last Post: 05-10-2007, 09:19 AM
  4. NEW Power Brute Group Buy R200 Carrier (Best PB Available R200) - $450
    By Mike1234 in forum Engine and Drivetrain (S30)
    Last Post: 10-17-2006, 06:49 AM
  5. R32 R200 diff center -> 260Z R200?
    By Murph in forum Suspension and Steering (S30)
    Last Post: 02-10-2004, 02:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
