Results 1 to 5 of 5
Thread: Well here is my 78 280 Z build
  1. #1
    Registered User
    Member ID
    CZCC-30326
    Join Date
    Apr 2014
    Location
    Garner, NC
    Posts
    24
    Default Well here is my 78 280 Z build
    This is my build, I was originally working on it for a customer when his work van blew the engine. He traded me the car for installing the engine.
    Here is what I have accomplished so far and how I got the car.
    When it arrived
    The engine needed some tlc I replaced the Valve cover gasket, intake and exhaust gasket, water pump, thermostat. I also repaired the fuel injector connectors and the po installed new fuel injectors, I also install the torn boot between the MAF and throttle body. The true talent was completely removing the EGR from under the intake (wait before you complain) some time in the cars life the EGR port was filled with corrosion and was cracked under the intake. I spent 8 hours removing the whole EGR system and plugging the six holes with pipe plugs.
    Here is the engine bay clean up pics with a new aluminum rad.
    Last but not least I hand hammered a floor pan cleaned up the interior
  2. #2
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Keep the Hurricane wheels, I think they work well on a Z.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  3. #3
    Registered User
    Member ID
    CZCC-30326
    Join Date
    Apr 2014
    Location
    Garner, NC
    Posts
    24
    Default
    I plan on it for a while but might get a set of BBS later
  4. #4
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    You got a helluva deal, I paid $700 to R&R a '01 Camry motor a couple of months ago, it came out from the bottom. White interiored cars are scarce, keep the pictures coming!
    Here's a good deal on a common to Zs wheel, Wheel Details - Discount Tire Direct
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  5. #5
    Registered User
    Member ID
    CZCC-30326
    Join Date
    Apr 2014
    Location
    Garner, NC
    Posts
    24
    Default
    The interior is in really good shape I just need to get carpet. I also need to figure out my turn signals and high beam head lamps and wipers
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. My Z build
    By Jonu in forum Check Out My Ride
    Last Post: 04-15-2013, 07:41 PM
  2. My Z Build
    By overdrivex in forum Open S30 Z Discussions
    Last Post: 04-12-2009, 07:52 AM
  3. If you build it, they will die.
    By theianmonster in forum Open S30 Z Discussions
    Last Post: 01-29-2008, 04:47 PM
  4. Build or buy?
    By Bill.Oakes in forum Open Racing Discussions
    Last Post: 05-16-2006, 09:49 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
