Page 2 of 2 FirstFirst 12
Results 101 to 195 of 195
Thread: My Datsun 280Z "Rustoration"
  1. #101
    Registered User HaZmatt's Avatar
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by Blue View Post
    You can soak the differential air breather in a clear glass of peroxide on a sunny day to whiten it.
    Ahh good to know thanks!
  2. #102
    Registered User Nite_Grind's Avatar
    Member ID
    CZCC-30548
    Join Date
    Jun 2014
    Location
    sOuL-CaL
    Age
    37
    Posts
    43
    Default
    Great stuff man! Empowering!
  3. #103
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I was cleaning mine and it broke. Then I found out you can order them from Nissan for less than €1.50.
    Also helps if you fit the breather before you mount the diff under the car. They can be a tight fit and not much roomto move.
    BREATHER-C :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  4. #104
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    I reached a milestone today. The car is officially a rolling chassis!
    Rear drum brakes installed with all new parts.
    Click image for larger version.
    Back on the ground! Not sure why its sitting so high in the rear. Hopefully it will settle down once the motor is in.
    Also installed the wiper assembly today.
  5. #105
    It's awesome bartsscooterservice's Avatar
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Gendt, The Netherlands
    Age
    32
    Posts
    857
    Default
    It's normal, the suspension settles to normal position once you start riding the car.
    HLS30 32581, 5/71 Matching numbers
    Jay Leno : You know one week after the Americans have walked on the moon, the Japanese introduced this sports car, and…if you’re a car guy pretty equal. I mean walking on the moon was pretty good, but how many times you’d gonna walk on the moon? But here was an affordable sports car that had real performance and looked like it cost a lot more than it did.
  6. #106
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    53
    Posts
    1,895
    Default
    Matt, Have you rolled the car forward or backwards yet? If not, the tires will grab the floor and keep it from settling.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  7. #107
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Yea I rolled it about a car length back and forth. Also the control arm bushings and spindle nuts are still loose. The only thing I can think of is that I tightened the sway bar while it was still up on jacks. Not sure if that would matter? ?
  8. #108
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    i believe the sway bar should rotate freely in its bushings, so it wouldn't present any resistance to the car settling.
    are you sure the springs are set correctly in the perches? also, are you sure you have the correct springs (front in front, rear in rear)?
    '78 280z - Daily driver/work in progress...
  9. #109
    Lance Corporal of Marines TheCrazySwede's Avatar
    Member ID
    CZCC-27820
    Join Date
    Aug 2012
    Location
    United States
    Age
    25
    Posts
    76
    Default
    This is incredible. I am very, very jealous! Thanks for sharing your re-build. Looking forward to seeing how this goes
    The car looks great.
  10. #110
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by rossiz View Post
    Yea I triple checked the placement of the springs. The longer ones are in the rear. I'll wait until the motor is in before I worry about it.
  11. #111
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by TheCrazySwede View Post
    Thanks man!
  12. #112
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    I wouldn't worry about the height yet.
    No glass or seats or anything else in the interior for that matter. What about gas tank and differential? Spare tire?
    I'm thinking you're going to be adding hundreds of pounds before your done, so I wouldn't worry until you have it loaded and then see where you're at.
  13. #113
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by HaZmatt View Post
    I've heard that once or ten times before! If they're Eibachs, look at the part numbers on the springs. The ones ending in .001 go in front and .002 in back.
    2/74 260Z
  14. #114
    Registered User CG240Z's Avatar
    Member ID
    CZCC-25778
    Join Date
    Dec 2011
    Location
    San Diego, land of hippies and SMOG tests
    Posts
    170
    Default
    I'm running Eibachs and my car isn't sitting anywhere that high. Like others have said, check the part numbers, fully assemble the car, then see where you're sitting. I installed mine, then checked the part numbers and realized I had them in backwards.
    1978 280Z (Current Project) (Bought from original owner)
    (6/70) 240Z (In the family since 1973) (Project currently on hold)
    Car's instagram: @eleanorz_78
    "It's the Dodge Viper of 1970, in Japan"
  15. #115
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Yea the springs with the .01 # are up front. I'm sure once it's assembled and the motor is back in it will sit nice.
  16. #116
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Got some stuff installed in the engine bay.
    Horns
    Inspection light
    Hood latch and misc..
    Pedal box and steering wheel painted and installed. (new steering wheel coming)
    New Muteki black wheel lugs
    Also just ordered:
    Brake booster
    Brake master cylinder
    Clutch cylinder
    Speedometer cable
    New engine mounts
  17. #117
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    dash goes on then the bolts for the steering column holder... don't tighten too much now
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  18. #118
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Hazmatt, you are doing great work, don't worry about the height of the wheel arches. Once the engine/tranny are in things will even out more and you will be surprised how much the weight of the interior fittings affect the stance.
    The detail is superb! But with that white engine bay I can see how your weekends are going to be spent once she is on the road.
    Chris
    1970 240Z HLS30 01955 March/70
  19. #119
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Yes, thanks. I needed to temporarily mount it so I can wheel it around.
  20. #120
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by grannyknot View Post
    Chris
    Beats the hell outta cleaning the house
  21. #121
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    33
    Posts
    125
    Default
    What did you do to paint the wheels black? They were silver previously
  22. #122
    Registered User S30Driver's Avatar
    Member ID
    CZCC-21075
    Join Date
    Mar 2010
    Location
    Seattle Washington
    Posts
    163
    Default
    He mentioned that he had them powder coated.
    They look great.
    1977 280z 06/77
  23. #123
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Yep had them powder coated.
  24. #124
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Been busy with family the last couple weeks so I havent had the time to work on the Z till now.
    I covered the floor pans, headliner, door panels, and a few other inner panels with Dynamat. I used the 34 sq ft kit and worked out pretty well. Should be nice and quiet now.
    Also installed the door handles and hinge hardware.
  25. #125
    Registered User
    Member ID
    CZCC-29634
    Join Date
    Sep 2013
    Location
    Maryville, Tennessee
    Posts
    20
    Default
    Hazmatt, love this resto thread, you are doing awesome work. I'm in the middle of my own restoration, and am actually putting in Fatmat Rattletrap these days. I've been wondering about how much coverage I should do, reading all the other posts about this I can find (this club is such a good resource!) but getting confused about how extensively I need to cover everything. Some posts show every square inch covered with this stuff, others not so much. It seems to me that this material really only serves its purpose on the "flimsier" panels, like the floorpans, left rear quarter panel, headliner, and door panels, since it is meant to reduce or deaden vibrations, and slapping it on every square inch isn't necessary. That said, I find myself nodding at your placement scheme. Are you also going to put it on your tranny tunnel and on the rear deck? What is your thinking on how much to use and where to put it? Finally, do you also plan on putting down any kind of padding or foam for sound reduction? Thanks for any advice!
  26. #126
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    for sound deadening you can do the tap test to hear what vibrates.
    Another way would be to mount a speaker on a location then use a software tool to do a frequency sweep. You should hear the points were resonance occurs (excitation of the metal). The speaker's magnets and steel car shell make this easy to do but a super magnet may also help couple the speaker to the metal. If you use a magnetic parts bowl to couple the speaker, remove the rubber base as you do not want isolation of the speaker from the body.
  27. #127
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by 240tom View Post
    Hi 240tom!
    Thanks for the compliment. Ive heard good things about the Fatmat as well. In my opinion, you can go as far as you want with sound deadening. The sky is the limit. I think going all out is a little unnecessary unless you are doing a stereo competition car. For me, I am mainly concerned with replacing the factory sound deadening that I removed on the floor pans. Along with taking care of some trouble areas like the doors, roof, and rear hatch area. I don't want to add too much because this stuff is actually pretty heavy. I have a little leftover so I will wait until I start driving it and i'm sure ill find a few more areas to put it. I'll probably wait till then to see if I need the padding or not as well.
  28. #128
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    53
    Posts
    1,895
    Default
    Any idea how much weight the Dynamat added?
    Jeff
    IZCC #1285
  29. #129
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by Jeff G 78 View Post
    I believe the shipping weight was 15 lbs.
  30. #130
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    53
    Posts
    1,895
    Default
    Thanks. Adding 15 lbs. isn't terrible for a street car to get the NVH better.
    Jeff
    IZCC #1285
  31. #131
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Hello, Im back. It ended up being an expensive weekend for me. I just bought my first brand new vehicle, a '14 Jeep Grand Cherokee. I really like it so far.
    Ok back to the Z....
    I also purchased this bad boy.
    A 5 speed close ratio out of an 80 ZX. Now all I need is a new rear diff with some 3.90 gears and I'll be good to go. I may run the original diff for awhile but I think the gearing will make it sluggish on the low end. Maybe the torque of the 3.1 might make up for it, we will have to wait and see. I couldn't pass up the deal on craigslist for the tranny.
    I also installed my firewall insulator I got from Black Dragon. Its good quality material but the fit isnt the greatest. It required some trimming.
    I then spent most of my weekend rebuilding my heater box. The entire box was disassembled and cleaned. Replaced heater core, hoses, blower motor, foam seals, and re-greased all moving parts. It should work like new now.
    This was nasty.
    Clean blower fan and new blower motor.
    New heater core on the right.
    Hoses were brittle and leaking.
    New hoses and reassembled.
    Then I went to work on the wiring harness. Just scrubbed it down with degreaser and re-wrapped it with new harness tape. It turned out really good.
    I hope to have the motor back from Rebello soon!
  32. #132
    Registered User Hardway's Avatar
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    First off, you are making awesome progress with your build. I love the attention to detail! Keep the pics coming.
    I have a ZX 5spd in my '71 240z and it still has the stock R180 diff in it. I don't know what gears are in it but I know its not anywhere near 3.90. However, cruising around town and even fast sprints on to highway on-ramps are no problem whatsoever. The car makes plenty of power and doesn't strain the motor. I personally like it as it lets me take advantage of the full power range of the engine.
    08/1970 240z Series-1 #8011 - Silver, black int., 2.4L I-6, 5spd, 90% restored.
    06/1973 VW Karmann Ghia - Black convertible, 4spd, 1600cc air-cooled engine.
    11/2013 Scion FR-S - Silver, 6spd, a car with the soul of a Z for the modern times.
    Restoration thread of my old '72 240z -> http://www.classiczcars.com/forums/o...1972-240z.html
  33. #133
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by Hardway View Post
    Thank you! Thats good to hear about your 5 spd /rear diff combo. I will try my setup as it is and hopefully it will work for me.
  34. #134
    Registered User Pop's Z's Avatar
    Member ID
    CZCC-8342
    Join Date
    May 2005
    Location
    Fort Collins, Colorado
    Age
    74
    Posts
    430
    Default
    FWIW, I used a 4:11 rear from a 200sx to replace my stock 3:36 R180. The difference is amazing. For long highway trips the 3:36 was great, very "long-legged", but for canyon carving which is what I mostly use the car for the 4:11 is terrific. I have taken the car on long road trips to SW Colorado on the beautiful twisty roads we have here ( the north side of the Black Canyon comes to mind) and I feel the 4:11 was the way to go. I turn about 3200 rpms @ 70 mph. The front diffy on Nissan 4X4 trucks is an R180 3:90, and they are also great. I started with the stock diffy, but changed after I had to shift down to first in some of the tighter corners. Enjoy the ride...I really like your resto.
    Cheers, Mike
    '73 240Z, 80,000 original miles, F54, N42 massaged and shaved (10.5-1 comp.), stage 2 cam, ZX ignition, Header, 2 1/2" exhaust w/ magnaflow muffler, 5 spd (Maxima), 4:11 R180 (200SX), 15" Rota RBs 205-60/15 Bridgestone Grid 109s, KYB struts, stock springs, rubber bushings, MSA sway bars and strut bars, HotRod Air hvac system, '90 300ZX seats, upgraded sound system, BRE-type spook and spoiler
  35. #135
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Cleaned up and painted the 5 speed today. Looks brand new again!
ID:	73208 Click image for larger version.
    Installed filler tube and replated gas cap and chain. Also put in a new rubber flap.
  36. #136
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    Gotta hand it to you HaZmatt, you are doing a fantastic job!
  37. #137
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Thank you sir!
  38. #138
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    Let me know when you are ready to do another one....hint, hint. The one in my avatar needs a resto.
  39. #139
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Sure, no problem!
  40. #140
    Registered User
    Member ID
    CZCC-30713
    Join Date
    Aug 2014
    Location
    Palmer Lake, CO
    Age
    35
    Posts
    3
    Default
    Really enjoying this thread! Lot of quality work being done quickly! Great color choice on the car too!
    I work in Sedalia, and wondered if I could get the name and number of your painter since he's local and you seem to be pretty happy with his work?
    I need some minor repair done on the z I just picked up.
    Also, are you staying fuel injected with the rebello rebuild?
    Also curious where you get your sem products? I need to repair my dash as well!
  41. #141
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
  42. #142
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Hi, I just got my SEM stuff on Amazon. I've decided to do a triple carb setup after talking to Dave at Rebello. Here is the link to my painter. His name is Ryan and does excellent work. From insurance repair to concourse quality paint jobs. Automotive Restorations and Concours Quality Paint
    Funny, we just got back from eating down at Palmer Lake tonight.
  43. #143
    Registered User
    Member ID
    CZCC-30713
    Join Date
    Aug 2014
    Location
    Palmer Lake, CO
    Age
    35
    Posts
    3
    Default
    Palmer Lake is a nice, quiet place to live! I haven't had a chance to really try the restaurants out since I bought my place here in July. It's on the to do list for this weekend though!
    Thanks for the tips on the SEM products.
    If you ever need a hand with your car, let me know. I get off work from IREA every day at 4:30 and would be glad to lend a hand just to meet a fellow z owner!
  44. #144
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by CoeGuthrie View Post
    You got a PM
  45. #145
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Got a few goodies today in anticipation of my motor coming in soon.
    Centerforce clutch and Fidanza lightweight flywheel
    Pacesetter ceramic coated 3-2-1 header
  46. #146
    Member ID
    CZCC-21075
    Join Date
    Mar 2010
    Location
    Seattle Washington
    Posts
    163
    Default
    Always interesting to check in on this thread...
    Great attention to detail.
    And nice goody choices!
    1977 280z 06/77
  47. #147
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by S30Driver View Post
    Thanks!
  48. #148
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Out of curiosity, do you know the the flywheel, clutch and pressure plate weighs? I see different fiqures quoted for the presure plates and can't remember seeing what the clutch disc weighs.
    Chas
    Chas
  49. #149
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    The flywheel is 10.5 lbs. I will weigh the clutch and pressure plate for you and post it.
  50. #150
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    According to my bathroom scale.... the flywheel is about 10.3 lbs and the pressure plate is about the same. The clutch disc is only 2 or 3 lbs.
  51. #151
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Thanks. I can't remember what the 280Z pressure plates weigh. I think a bit under 10kg, but I might be thinking of the thinner 240Z early model.
    Its a nice looking set-up you have.
    Cheers
    Chas
    Chas
  52. #152
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default Hardware list
    Here are the receipts from Fastenal and Clipsandfasteners.com for all of my yellow zinc hardware. I bought a little extra just to be safe so this list is NOT exact. Hope it helps someone.
  53. #153
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default Need some help!
    Hey guys, I bought a 240Z steering wheel and i'm in need of a horn pad and the pieces that mount it to the wheel. If anyone has one laying around let me know how much.
  54. #154
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Haz, you are doing an amazing job!! You should bring up to my place for the "Aspen changing" would love to see the ride in person. Sorry, can't help you with the steering wheel, I replaced mine with a 14" wheel, but I can't remember the name of the company(old timers disease kicked in). Anyway, my wheel looks very nice and I love the finger grips on it. Keep up the great work.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  55. #155
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by mjr45 View Post
    I would love to but I dont see this thing on the road anytime soon. Hopefully next spring! I was able to find a new horn mechanism on ebay so I will be able to make mine work.
  56. #156
    Registered User 2sixTZombii's Avatar
    Member ID
    CZCC-29696
    Join Date
    Oct 2013
    Location
    Sioux City ,IA
    Posts
    172
    Default
    I used the 260/280 horn on the 240 wheel I put it my car, it required making a little mount bracket and was overall a horrible experience where I convinced all my neighbors that I'm a psycho who honks at everyone that drives by, but it works great now.
    1974 early 260z, Weber DGVs killed my motor.....
  57. #157
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Quote Originally Posted by 2sixTZombii View Post
    That made my day...thanks!
    1DPONG||
  58. #158
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Haha thats funny. I thought about doing that too but I just like the smaller size of the 240 horn.
  59. #159
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Just finished a few more things on the list.
    Installed the vinyl trim on my pillars and did my headliner. I followed this link from Blue and worked great. Only difference is I bought the kit from Motorsport.
    http://www.classiczcars.com/forums/i...tallation.html
    The glue they send with their headliner kit is garbage, throw it away or give it to your wife to do crafts and stuff.
    I went to Autozone and bought this:
    Its pricey ($25 a can) but its the real deal. This is the same stuff they use at Automotive upholstery shops. (I used to work at an upholstery shop).
    I also put in the dash and finished most of the wiring.
  60. #160
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    And some random pics of how its sitting right now. Im waiting VERY patiently for my motor to get here from Rebello so I can get to the fun stuff!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  61. #161
    Registered User
    Member ID
    CZCC-30484
    Join Date
    May 2014
    Location
    Ocean Springs, MS
    Posts
    9
    Default
    Really nice work on the headliner, good tip on the glue, too.
    1974 260Z
    Gary
  62. #162
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    looking great - love watching the progress.
    btw - i also bought the headliner kit from msa but used their spray glue. it seems to be holding up just fine for me. i put sound mat on the ceiling and used pretty much the whole can. the only issue i ran into was my lack of experience doing a headliner (it's tricky and in a cramped car working upside down i made a couple of mistakes)
    maybe i'll be re-doing it in a few years if the glue doesn't hold, but it's been almost a year, through a winter and a hot summer and so far so good...
  63. #163
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Thanks. Glad to hear it worked out for you, I couldnt get it to stick. Did you do the pillars too or just the headliner? Because I dont think the headliner needs as much to stick.
  64. #164
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    just the headliner - glue sticks to the foam headliner backing and foil faced sound mat.
    my pillars are not vinyl-wrapped, they are integral color plastic. (1978)
  65. #165
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Ah I see. Yea you should be good then.
  66. #166
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    The dash looks fantastic! Wish I took pics of mine before I covered it with the full face dash cover. I don't think mine is repairable, that's how bad it looked!
  67. #167
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Yea I have a cover too, if I didnt like the way it turned out I was going to just slap on the cover. Try it you may be surprised how well it turns out.
  68. #168
    Member ID
    CZCC-21075
    Join Date
    Mar 2010
    Location
    Seattle Washington
    Posts
    163
    Default
    Matt
    Does a new set of hardware, bolts come with the Fidanza flywheel to prevent embedment of the bolts?
    Hope your motor gets to you soon.
    1977 280z 06/77
  69. #169
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Matt
    No such luck. I'll buy a new set from Nissan and use some loctite. The list of things I need keeps getting bigger and bigger....
  70. #170
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    50
    Posts
    468
    Default
    HaZmatt,
    When you worked on the rubber parts, what product did you use for the degreasing?
    Thanks, Charles
  71. #171
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by Patcon View Post
    HaZmatt,
    Thanks, Charles
    Purple power. Full strength
  72. #172
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    50
    Posts
    468
    Default
    Thanks
    C
  73. #173
    Registered User
    Member ID
    CZCC-30732
    Join Date
    Aug 2014
    Location
    Central Ohio
    Posts
    35
    Default
    Keep up the good work and keep posting pictures! I love it!
  74. #174
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default Small update
    I took my gas tank to a local radiator shop and had them hot tank and seal it. They also painted it black for me.
    Installed new rubber insulators on the straps
    Cleaned up the filler hose and installed it.
    And finally got my tank in.
    Now I just need to figure out where all of these fuel lines go
    Also bought a new side mirror from a 240Z
    Holes dont line up so I had to drill a new hole and make the other one larger
    And installed pic
    Much better than the plastic 280Z mirrors I think.
  75. #175
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Started assembling my door glass. Polished them up a little to take some of the fine scratches out.
    Smooth as.... well, glass.
    Freshly plated hardware
    Now I need to source some new window regulators because I had mine plated and it destroyed the plastic rollers and the crank mechanism in the process
    On a happier note I talked to Dave Rebello and he told me my motor was finished and he just needs to do the dyno testing on it. So if all goes well it should be shipping out soon!
  76. #176
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Looks great!
  77. #177
    Registered User
    Member ID
    CZCC-30732
    Join Date
    Aug 2014
    Location
    Central Ohio
    Posts
    35
    Default
    What did you use to polish the glass? My windshield has minor surface things I'd like to polish off.
    John
  78. #178
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Looks great!
    Thanks Blue!
    Quote Originally Posted by JR Ohio View Post
    John
    I just used a buffing compound with an aggressive pad. It took out most of the fine scratches and haziness. There are some deeper ones that I may try to get out with a glass polish kit.
  79. #179
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    New brake booster painted black and installed with new master cylinder. Also installed misc brake lines.
  80. #180
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    32
    Posts
    857
    Default
    nice work so far !
  81. #181
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Where did you get your heater core hoses, please sir. The work you're doing amazes me. Is this your 1st restore?
    Oh yeah, what are you gonna do for the bumpers? futofab.com has some 240Z black powder coated ones for $240, haven't seen the sheen yet but the semi gloss you're using would work for me. Look at post #13, http://www.classiczcars.com/forums/b...s-bumpers.html
    Thanks,
    Cliff
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  82. #182
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Thanks! I just took my old hoses to the local Autozone and they matched them up pretty good. I currently have the fiberglass bumpers but the Futufab bumpers look enticing.
  83. #183
    Registered User
    Member ID
    CZCC-24552
    Join Date
    Jun 2011
    Location
    kona hawaii
    Age
    58
    Posts
    481
    Default
    Did you have the name of the company that did the plating work for you?
  84. #184
    Registered User
    Member ID
    CZCC-25066
    Join Date
    Aug 2011
    Location
    Zurich, Switzerland
    Posts
    19
    Default
    is in this list (pics) with the plated screws those for drivetrain and underbody included? you must have had a lot of time to measure all..
    Nice Info
  85. #185
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by hr369 View Post
    Specialty Plating here in Denver
    Specialty Plating Services | Denver, Auora, Boulder, CO
  86. #186
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by munters View Post
    Nice Info
    Yeah pretty much the whole car and then some. There are a few specialty bolts that I had to have plated or I just reused.
  87. #187
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default Lights!!
    After a much needed week long vacay in Maui, I'm back to work on the Z. I focused my attention on the lights and the rear area of the car.
    Pretty rough shape.
    Repainted the taillight panel in factory gunmetal
    Disassembled
    Cleaned housings
    Then polished the lenses.
    New foam gaskets.
    Installed new bulbs.
    Purchased some cleaner chrome bezels off Ebay. I still may get mine replated in the future.
    And.......Walahhh!
    On to the front turn signals. I purchased the 240Z turn signals off Ebay as well. I got them fairly cheap but they were rough. The lenses were in decent shape though.
    First I disassembled them and soaked everything in degreaser overnight.
    As you can see, it stripped the chrome off of reflector piece. So I got some chrome vinyl wrap and covered it.
    Turned out pretty good I think. Hopefully it holds up to the heat.
    Cleaned everything up and reassembled.
    Also polished up the lenses.
  88. #188
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    I wasnt happy with the hatch seal that came in my Precision kit so I bought a NOS one.
    Installed my spoiler.
    Also put in my rear quarter windows.
    New rubber.
  89. #189
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    57
    Posts
    873
    Default
    Amazing job Haz! Did you use the gunmetal spray from SEM? Its what I used and then I sprayed them with a satin clear also from SEM.
    Amazing what a little polish and a buffing wheel will do! Those lenses look awesome!
    Oh, what was wrong with the precision hatch seal....I need a new one.
  90. #190
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Your project is coming along nicly. Really looking good. Nice job on the lenses. My taillights were just as bad and the chrome bezels were painted black by the po. I have a set of 240Z lenses for the front, just haven't got around to doing the air dam yet. Ended up cleaning up the 280 units in the grill. http://www.classiczcars.com/forums/e...l-refresh.html
    Looking forward to seeing the projects journey to completion.
    Chas
    Chas
  91. #191
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by rcb280z View Post
    Thank you sir. I actually ended up using a wheel paint that I had. The color matched pretty good. The seal from the kit seemed like it was too thick and the hatch didnt want to close very well. The OEM one is still a little thick but its better. I think it just needs to be broken in.
  92. #192
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    43
    Posts
    160
    Default
    Quote Originally Posted by EuroDat View Post
    Chas
    Thanks Chas! Are you doing the 240 bumper as well?
  93. #193
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Haz, that is some amazing work, can't wait to see it completed. If I can help let me know. I live up in Divide but don't mind a road trip every so often but I don't take the Z out in the winter I've put in way to much work to end up in a ditch if you know what I mean, scheesh Colorado drivers!
    75 280Z almost done
  94. #194
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Yes, I have the MSA fibre glass bumper already fitted, but still using the 280Z valance. The problem with that combination is it leaves a rather large air gap between the bottom two row grille and the bumper. The 240Z valance wont fit because the front frame section drops down to low for the larger 280Z radiator.
    I had two options:
    1- Fit the 240Z bumper with the 280Z valance or 280Z air-dam and make a new lower grille (parts out of a 240Z grille) to fill the gap.
    2- go full 240Z look with the indicators under the bumper, 240Z grille and a 240Z air-dam.
    I found a 240Z grille in good condition, but then decided to go with option 2. Now I have a 240Z air-dam and plan on fitting it in the next months.
    Chas
    Chas
  95. #195
    Registered User
    Member ID
    CZCC-26387
    Join Date
    Feb 2012
    Location
    SD
    Age
    29
    Posts
    7
    Default My Datsun 280Z "Rustoration"
    Es que ya traer un tsuru en estos dias es como seguir usando los celulares del oxxo "por que son baratos y les rinde la bateria" aplicando el típico "pa que quiero mas?.
    http://nwoldgrowth.org/the-worlds-mo...-private-jets/
Thread Information
Users Browsing this Thread
Similar Threads
  1. source for "DATSUN" door sill thresholds new/nos..?
    By an_unusual_eye in forum Open Discussions
    Last Post: 01-06-2014, 09:08 PM
  2. Replies: 4
    Last Post: 02-26-2012, 05:18 AM
  3. UK, NZ, AUS, Other "DATSUN" or "DOTSUN"
    By Blue in forum Open S30 Z Discussions
    Last Post: 01-19-2012, 08:48 AM
  4. 10th Anniversary 1980 Datsun 280ZX "Black And Gold"
    By 280~Master in forum Open Discussions
    Last Post: 03-29-2009, 09:45 PM
  5. Early 240z "Datsun" hatch emblem
    By Mike B in forum Open S30 Z Discussions
    Last Post: 11-10-2007, 07:03 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
