Results 1 to 7 of 7
Thread: Part throttle issues.
  1. #1
    Registered User
    Member ID
    CZCC-26118
    Join Date
    Jan 2012
    Location
    california
    Posts
    52
    Default Part throttle issues.
    Despite my best efforts, i cannot seem to get them to run as one would hope they should. At hard throttle, i have zero issue, and at idle and very light throttle, i have no issue, but part throttle cruise just starts to burble and pop, like it must be over fueling or something.
    With application of carb stray to the throttle shaft, you can hear a slight rpm change, and have begun to think that its air leaking past and changing the mix for me as I drive. I have done the whole all the way in, 2.5 turns out thing, there is proper oil, they are equal flow at 1500 rpm, but they just start bogging till i push through. Could I doubt highly the dashpots are getting hung up, but its something that has crossed my mind, but how to test that, as i cannot really see them while i'm driving
    The car is a 1970 240z, with factory l24.
    1970 240z
    HLS30 03017
  2. #2
    Registered User BadDog's Avatar
    Member ID
    CZCC-1680
    Join Date
    Feb 2002
    Location
    Oswego, NY
    Posts
    375
    Default
    I was having a bugger of a time figuring out why I had lean ping (sounds like shaking a spray paint can) under load until I found that my front crab's float level was way lower than the rear. All these years I've been adjusting my fuel mixture knobs the same amount, I forgot to check them individually for mixture. Try the tips on this page: Technical Information Page ..... Carburation
    The technique recommended there for checking mixture by raising the lift pin in the underside of the dashpot mount is where it clicked for me. That's when I found that my front carb needed over 2 full turns out more than my rear carb needed.
    I still have to do something about my float levels, but this helped so much its not even funny.
    1973 240Z Silver, 5 spd., 4.11 diff., 150,000+ miles
    2013 Subaru Impreza 5-door
  3. #3
    Registered User
    Member ID
    CZCC-26118
    Join Date
    Jan 2012
    Location
    california
    Posts
    52
    Default
    if fueling was an issue, would it not affect at all speeds, and loads. This is kinda a specific range. When cruising in 4th no real issues, and hard throttle no issiues. But it just starts backfire and burble at part. I'll look into the stuff on that page, but man, this is driving me nuts.
    1970 240z
    HLS30 03017
  4. #4
    Member ID
    CZCC-1680
    Join Date
    Feb 2002
    Location
    Oswego, NY
    Posts
    375
    Default
    I missed that full throttle had no issues. What are you using for damper oil?
  5. #5
    Registered User
    Member ID
    CZCC-29883
    Join Date
    Nov 2013
    Location
    Portland, Or
    Age
    71
    Posts
    283
    Default
    What color are your plugs? This will tell you which carb needs adjusting. If the mixture screw adj. is substatially different between the two the float level is off. The best source of info on SUs is the SU DVD from ZTherapy.
  6. #6
    Registered User
    Member ID
    CZCC-26118
    Join Date
    Jan 2012
    Location
    california
    Posts
    52
    Default
    Im using the "su" oil from MSA, and my plugs are fine. I'm fairly sure air is leaking right on past the throttle shaft, as when i give it a little bit of propane, rpm changes. I'm thinking I may just pull the trigger on sending them off to z therapy.
    1970 240z
    HLS30 03017
  7. #7
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    After watching "Just SU's" for the first time, your symptoms are describing a leak in the throttle shaft to a T. I'm a novice for sure, but from watching the video that is what he describes exactly.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Have resolved some issues, but still won't take much throttle
    By 81 ZXT in forum Fuel Injection (S30)
    Last Post: 03-19-2009, 06:31 AM
  2. Mikuni PHH backfires at part-throttle
    By EricB in forum Carburetors (S30)
    Last Post: 11-01-2005, 11:14 AM
  3. throttle linkage missing part?
    By Ricklandia in forum Engine and Drivetrain (S30)
    Last Post: 05-08-2005, 07:45 PM
  4. Starter issues, Brake Issues, Electrical Issues
    By superwombat in forum Help Me !!
    Last Post: 03-29-2005, 10:42 AM
  5. Engine stalls/stumbles at part throttle
    By TomoHawk in forum Help Me !!
    Last Post: 09-04-2004, 01:57 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
