Results 1 to 14 of 14
Thread: Squealy steering
  1. #1
    Formerly known as Koalia Reverend's Avatar
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default Squealy steering
    Seems like my car has gone old, it has started squealing from everywhere lol.
    This aint a problem in daily drive, it's just embarrasing when parking and leaving, happens in low speeds. Also like the other noise (from transmission/clutch) this is LOUD. Friend of mine suggested that it comes from bearing between spring dish and that rubber insulator, but it sounds like its coming from lower, area of ball joint. I greased practically everything i could see behind wheel (except brakes..lol) but the sound aint going away.
    https://www.dropbox.com/s/iid5qf9tq0...609_214601.mp4
    to clarify that only comes from driver side
    -72 240Z "Goldie"
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    that is a funny sound... like trying to make a balloon animal.
    I could only guess the tire on the concrete but I know it is wrong.
    Is an endlink rubbing on a control arm?
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Registered User
    Member ID
    CZCC-29883
    Join Date
    Nov 2013
    Location
    Portland, Or
    Age
    70
    Posts
    283
    Default
    Wow, That's impressive if nothing else, That noise just topped my list of strange noises from machines. I'm with Blue, Tires on painted concrete was my first thought. Second was a puppy under the tire, I'd go to my 3' garden hose stethescope. With the help of a friend moving the s-wheel( I'm assuming that is what you're doing when the noise appears), you should be able to poke 1 end of the hose toward the noise from above or below, the other end to an ear & locate the sound. An ear plug in the other ear may help muffle the noise. Please follow up & let me know what you discovered. I need closure. Mark
  4. #4
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default
    Hah, okay thanks No balloon animals or puppies. It really is weird sound and it appears on all surfaces. Usually noise emerges when steering wheel is barely moved, when you turn it quikly or forcefully, no sound, when doing slight alterations SQUEEEEEKKK. I removed the tire and the sound went off. Maybe it actually is the strut bearing because when there is no tire, also no pressure to strut dish/insulator/bearing...
    -72 240Z "Goldie"
  5. #5
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    That makes sense. Maybe the rubber insert spacers were accidentally used in the front where the bearing is supposed to go?
  6. #6
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I'm still laughing at the sound your car makes Sooooo funny.
  7. #7
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default
    Hah youre welcome, feel free to use that as your phone ringtone or something
    Just noted that i can get the same sound by pressing front left strut downwards (aka. hopping over hood) ... could it still be the bearing?
    -72 240Z "Goldie"
  8. #8
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I am nearly certain the sound is from something rubber. The steering related items to check/listen closely would be:
    rubber dust cover on tie rod end
    rubber bump stop at top of strut
    rubber damper in strut mount
    rubber bellows dust seal on strut
    Some pics here: http://www.atlanticz.ca/zclub/techti...stallfront.htm
    As Mark says, try to listen closely to each.
    You can also try lubricating each with lithium grease spray
    Click image for larger version.
  9. #9
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    hmmm looking at my tech tip I am wondering if upside down thrust bearings could be a cause?
    As mentioned, the rears have no thrust bearing but rather a rubber doughnut shaped spacer.
  10. #10
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    i bet i know what it is - my car was doing the same thing after i updated the suspension...
    the top of the spring perch has a big rubber isolator that has a sealing lip against the perch which keeps the thrust bearing protected from dust & debris - i cleaned that off really well and wire-wheeled and painted the spring perch, and the isolator sealing lip was squeaking as the perch twisted with the steering. had to pull it all apart and apply a liberal smear of lithium grease to the top of the perch and the rubber isolator sealing lip and presto! no more squeaky toy ;}
    '78 280z - Daily driver/work in progress...
  11. #11
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default
    I took that bearing off, it was completely dry and it was rattling. Even if the sound was not coming from there, i will change it. Mucho grease will definetly help!
    -72 240Z "Goldie"
  12. #12
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
  13. #13
    Barn Find Daily Driver Captain_Zeros's Avatar
    Member ID
    CZCC-21373
    Join Date
    Apr 2010
    Location
    Kirkland, WA
    Age
    31
    Posts
    316
    Default
    I'm having flashbacks at all this talk of the thrust bearing....... when I went through my Z's suspension one of mine was straight up missing..... only one too.
    I'm surprised the steering wasn't very heavy without it, and nothing seemed to actually be worn because of it. Ain't life weird.
    1973 240Z w/ roundtop carbs, 280zx e12-80 distributor, 280zx alternator, late model Altima junkyard electric fans. 115 Blue Metallic & white side stripes.
  14. #14
    Member ID
    CZCC-20168
    Join Date
    Sep 2009
    Location
    Finland
    Posts
    954
    Default
    Dang bearing shop... they did not have that kind of bearing, well i completely washed it with degreaser and put new greases in. No more squeal! Hopefully that old bearing lasts...
    -72 240Z "Goldie"
Thread Information
Users Browsing this Thread
Similar Threads
  1. Steering help
    By kelly in forum Suspension and Steering (S30)
    Last Post: 10-27-2010, 04:30 PM
  2. steering help!!!!!!
    By yoshi_w in forum Suspension and Steering (S30)
    Last Post: 09-03-2010, 06:11 PM
  3. Steering rack
    By olzed in forum Help Me !!
    Last Post: 04-18-2010, 06:52 PM
  4. Replies: 1
    Last Post: 10-14-2009, 07:12 PM
  5. Steering help.
    By Fun_in_my_z in forum Suspension and Steering (S30)
    Last Post: 07-03-2005, 06:37 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
